Question about Maytag MTB2156GES Top Freezer Refrigerator
Maytag MTB1956GE Top Freezer sometimes makes a loud whistle sound. Seems to be coming from a fan which has a cover labeled Dual Cool.
  • 159 Answers
SOURCE: Maytag MFD2561HEQ Bottom Freezer Refrigerator - Freezer working, refrigerator not
Marc of Nc. check to make sure the fan in the freezer is operating when the compressor is on. The only thing the fresh food section gets its cool air from is the freezer. and if the fan is not operating no cold air will get up there. If the fan is running you need to make sure the air duct is not blocked with frost of the evaporator is not iced up. Check that out and get back with me if there still is a problem. Good Luck
Posted on Aug 06, 2007
SOURCE: 2003 Maytag Plus Dual Cool Side by Side
Check to see if the bacl of the fridge is iced over, if it is the fridge is not defrosting, 99% of the time it is the defrost control circuit board located in the upper right hand corner of the fridge.
Posted on Jun 12, 2008
  • 16 Answers
SOURCE: Maytag refrigerator clicking noise and stopped working
either inside fan out of alignment or defrost timer could be bad
Posted on Jun 02, 2009
SOURCE: Maytag Performance PTB1953GR making buzzing noise
refrigerator and freezer not getting cold
Posted on Mar 09, 2010
espressonist
  • 1711 Answers
SOURCE: Loud whistling sound
We have summarised all possible problem for this case here to this link
http://www.fixya.com/support/r6008187-side_side_refrigerator_whistling_sound
Posted on Sep 15, 2010
My Maytag MFF2558VEM Bottom Freezer French Door Refrigerator doesn't keep cool
What you should be looking for is a blocked air flow. The fan in the freezer will push air up to the fridge and cool it off. Look for a dead fan motor in the freezer or a blocked air vent Good luck
Sep 08, 2012 | Maytag MFF2558VEM Bottom Freezer French...
Tip
Side by side refrigerator whistling sound coming from freezer fan area
We had a lot of inquiries with what we call whistling appear to be from different problems which here below:
First case, whistling sound is what we call "Ghosting". To get rid of this sound one needs to put more gas into the system, but more gas will create the suction pipe to frost up and reducing the gas level will create less cooling. The best solution were to full regenerating Freon gas mean remove it filter it out and charge it back. However this will cost more $100 and basically you can leave it and live with it. No harm is created only the sound appears while running.
Second case were with a loud whistling, like a dying bird stuck in your freezer, you likely have a faulty freezer fan motor and you need to be replaced
Third case were with a lower pitched, sort of gentle whistling sound then you have an issue with the door damper, which allows the air flow from the freezer into the refrigerator. And assuming you don't have any cooling problems, it may simply be a normal occurrence, as some makes and models open and close this damper door automatically, and when it is closed, can sometimes cause a low whistling noise
Fourth case was making a moaning, whistling noise coming from just above the ice maker. It happened when the fan speed changed. We found out that the motherboard was probably defective.
Rather than go thru GE, you can found a new one online for 66 bucks. You can replaced it in about ten minutes and it's all fixed.
Fifth the evaporator fan motor should not change speeds in less than 1 minute of time. The fan motor has two speeds. Usually this is a indication of a failing main board. If you have a meter you can do a voltage check at the J-2 connector on the board. Check for 13VDC between pins J2-3 and J2-8 and 8 to 13VDC between J2-3 and J2-4. If this voltage stays steady, your problem lies in the evaporator fan motor. If this voltage drops out or fluctuates, it's more than likely the board need to be replaced
on Sep 14, 2010 | Refrigerators
I have a model MTB1956GE Maytag Fridge, Frezzer
Can you feel air moving or hear the fan running in the freezer section? You said the freezer section is freezing well, but is it freezing really hard?
Regards,Richard
Dec 12, 2011 | Maytag MTB2156GES Top Freezer Refrigerator
My refrigerator makes a loud humming sound.
sounds like its bearings in a fan motor probably your evaporator fan motor it is located behind the plastic shell in your refrig. you have to take out the lining and then you will see the fan, evapartor and etc.
Jul 15, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
My Maytag MFD2560HES bottom fridge is making a loud humming noise.
Any time there is the sound of humming it is important to locate where the noise is coming from. Sometimes fans wear to a point that at one speed the sound as if humming. Sometimes compressors hum with more catastrophic results. Because your model is a bottom freezer it would be a good idea to open drawer to freezer and see if the sound is from fan in freezer or if pulled away from wall is the sound the fan or compressor area? I believe I will be able to locate a service manual but I will need you to help me pinpoint the location of the loud sound so we can get the sounds back to normal. Let me know if you are able to try that and what you find, Sea Breeze
Mar 23, 2010 | Maytag MFD2560HES Bottom Freezer French...
Whistling sound from inside freezer compartment
is this a loud whistling, like a dying bird stuck in your freezer, or is this a lower pitched, sort of gentle whistling sound. If its the former, you likely have a faulty freezer fan motor. replace
if its the latter, sounds like you may have a issue with the door damper, which allows the air flow from the freezer into the refrigerator. However, assuming you dont have any cooling problems, you didnt mention if you do, it may simply be a normal occurance, as some makes and models open and close this damper door automatically, and when it is closed, can sometimes cause a low whistling noise
Feb 13, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Our Amanda refrigerator/freezer has been making noises on and off (buzzing) over the past two months, in particular the bottom freezer. Today everything started to melt and the buzzing is frequent every...
It sounds like your evaporator fan motor, they last about 4-5 years. Try to see if the buzzing noise comes from the motor, usually in the freezer compartment behind a vented cover plate
The freezer is usually cooled by the compressor, the fridge is then cooled by an evaporator fan motor ($30). If this fan seizes or slows down then the fridge warms up (it sometimes starts squealing before this happens). It could be that your drain hose is clogged or frozen. Maybe the temperature adjuster go bumped.
If you think it is the evaporator fan motor:
Check to be sure you can get a replacement fan first, they last about 4 - 5 years. Can get from a parts supplier or electric motor company.
UNPLUG fridge. Located usually in top of freezer behind a vented cover plate. Remove cover, remove screws holding fan in, may have to cut wires. Replace with new motor, make sure the fan pushes air into the freezer area and doesn't spin backward drawing air from the freezer area.
Oct 31, 2009 | Amana ABB1927DE Bottom Freezer...
Whisling noise coming out of inside the refrigerator. Louder when freezer door is open. maybe ice maker area?
The whistling is caused by the air circulating fan located just behind the light. It is easily accessed by removing the light cover and the two small hex screws above the light. To stop the whistling I simply turned the freezer off and pulled the fan cover out slightly to reveal the fan blades. I then pushed the blades down, toward the bottom of the until the blades stopped and i could feel the shaft slightly protruding from the top of the blades. Repositioning the blade has stopped the incessant whistling. Hope this helps!
Apr 19, 2009 | GE GSL25JFPBS Side by Side Refrigerator
Maytag refmodel number mff2557hew
sounds as if perhaps the fan in the freezer is not circulating air up to refrig sect. pretty common issue, if you pull out freezer door youll be able to hear the fan on the back wall, behind the vent on top sect of freezer. that cover pops right off with a pry of the screw driver.. heres the part number if indded that is the issue 12002744 comes with instuctions on how to install
Nov 09, 2008 | Maytag Refrigerators
We have a Maytag Fridge model: MTB1956GE and the top freezer is not keeping food frozen, however the bottom fridge is working fine. In addition small pools of water have been cleaned up from under the...
Your defrost system consists of the timer, heater and thermostat. Your problem could be any of these. But because your fan doesn't turn off it is more than likely the timer. https://www.searspartsdirect.com/model-number/MTB1956GEW/3048/0166000.html
Oct 31, 2017 | Maytag Refrigerators
Maytag MTB2156GES Top Freezer Refrigerator Logo
148 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
