Question about Braun Cruzer 3 Electric Shaver
How to disassemble trimmer Braun Cruzer 3 - Braun Cruzer 3 Electric Shaver
3 Suggested Answers
  • 3 Answers
SOURCE: Braun Cruzer 3: Trimmer blades
Hi guys!
I managed to fix the trimmer, here a short video how.
Hope it helps
http://www.youtube.com/watch?v=ZH1NRbDidRM
Posted on Jul 30, 2012
  • 76 Answers
I assume you already tried this, but in case you didn't, clean out all the hair with a small brush (eg. a toothbrush) and then apply liberal amounts of lubricating oil such as "Kool Lube" which is available at beauty supply stores.
Posted on Aug 05, 2010
How to fix braun series 5 trimmer
Search Results
    Repair your Braun Cruzer 3 Trimmer MacGyver style in 6 ...
    ? 6:36
    https://www.youtube.com/watch?v=ZH1NRbDidRM
    Jul 30, 2012 - Uploaded by Ed el Vise
    My Braun Cruzer 3 Trimmer suddenly stopped working. ... I have replaced screens now on 5 different cell ...
    Braun series 3 razor fix - YouTube
    ? 3:00
    https://www.youtube.com/watch?v=mSdJu_iaEjs
    Oct 16, 2014 - Uploaded by mruberg1
    How to fix the Braun series 3 razor, after the trimmerattachment, falls off, due to sonic weld failures ...
    Braun Series 3 disassembling trymer rozbieranie - YouTube
Jan 18, 2016 | Braun Health & Beauty
Why won't my Braun Cruzer trimmer not charge?
did u check fuse in plug? just change it no need to check it, if still no good open it up and see if there's a wire off battery, if still no joy search for one on flea-bay, i can't see it so i hope u know wot to look 4 loool
Aug 17, 2014 | Braun Cruzer 5 Beard and Head Cruzer, 5...
The trimming blades of my Shaver do not work. my hair got stuck in it. It seem the blades do not move across each other.
Assuming you have cleaned and lubed the blades, then you need to dismantle requiring a torx screwdriver.
Firstly, take off the top cover and remove the foil itself. There are two torx screws there, and another one where the power charger goes in at the bottom.
Once those 3 are removed, pull apart the main black/grey sections. There are 2 more screws holding the battery in place, remove them and the battery. Next bit is tricky - where the 2 grey 'dimples' are, gently loosen the two sections which should leave the black slider holding the trimmer and just one side of the grey outer shell. It felt to me it was going to break, but came apart without issue.
I couldn't work out how to seperate the black trimmer section here, but you can buy replacement trimmer sections so assuming it's possible somehow. From here, I cleaned, and soaked the blades with lube overnight. Then put back together again.
Feb 03, 2011 | Braun Cruzer 3 Electric Shaver
Braun Pulsonic model 9595. Trimmer will not close properly. Can I repair this myself?
The trimmer is replaceable and can be purchased as an assembly http://buyitnow64.stores.yahoo.net/brshrese7pul.html You will T-6 and T-8 torx drivers to take apart the head end of the shaver. Using these tools, remove the swiveling head, the hold down cover over the motor assembly, and then pop off the drive arm for the trimmer. Now the broken trimmer assembly can be slid out of the end of the shaver by carefully prying between the case where the on/off button is located and the black trimmer assembly base with a small flat blade jeweler's screwdriver. The new trimmer assembly can then be slid into the case and the shaver reassembled. Just be sure the ends of the retraction spring on the new trimmer assembly are installed over the little chrome retaining lugs for them or your trimmer will not fully retract (my trimmer assembly arrived with the spring ends loose and not retained by the lugs).
Mar 29, 2010 | Braun Health & Beauty
Trimmer malfunction
I had same problem, at first I could not find out how to seperate the small silver cover with the on/off switch from the rest. After removing the 3 torx screws, 1 at the power entrance, and 2 under the shaver blade. You can remove the black cover. I also removed 2 more torx screws to separate the battery, from the rest, (don't know if thats really necessary). The silver covers are 'clicked' into eachother. When lifted the part where the battery part was screwed into, the silver parts became partly seperated, then you can pull the part apart.
I cleaned/washed the trimmer part with wd40 contact spray.
Assembled the parts, and made sure that the little plastic nodge was came into the trimmer.
Cleaned it all (removed leaking wd 40) and works fine again.
Hopefully this is helpfull to anyone.
Goodluck,
Adrian
Dec 25, 2006 | Braun Cruzer 3 Electric Shaver
Problem shaving
People, never ever buy the Braun body cruzer!!!! It does not mather which version/type you buy, with 'all' versions the big trimmer fails to work after aprox, 18-24 months.
I have bought three version of them, the first one stopped working totally after about a year. With the second one the large trimmer blade did not work anymore, so I bought the newest cruzer version (shaver #3 by then) in the hope Braun would have solved this problem. But NO, the same thing happend. After 18 months the trimmer is broke and I can throw my shaver in the bin because you buy this thing for the trimmer.
Now about 3 years later I have in total bought 3 cruzer shavers from Braun and all are broke (i am also almost broke, those things are pretty expensive here). And of course Braun does not help, they just say you are beyond warranty or did not take good care of the product. But I did, I keeped it clean with the little brushes, I put oil on blades/parts, and when I had shaved in the shower I made dry.... so I wonder what Braun means with "taking good care for your product" but i think they mean something like: buy a new one and give us some more of your money.
I will NEVER buy a Braun product again! And be warned people, don't say you where not warned for this product when you buy one and is goes broke within a year.
Sep 16, 2006 | Braun Cruzer 3 Electric Shaver
Braun Cruzer 3 Electric Shaver Logo
1,174 people viewed this question
Top Braun Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Kazim ERGUNEY
Kazim ERGUNEY
Joseph Hoffmann
Are you a Braun Health and Beauty Expert? Answer questions, earn points and help others
