Question about Xerox WorkCentre M-24 Color Copier
I replaced transfer belt cleaner and 2nd bias tranfer roller. need to reset consumable counter. how can this be done.
    Scholar:
  • 92 Answers
if both parts have been replaced then the Eng that have been onsite have to reset those values. Their are possible but required technical knowledge as their done on a Special Diagnostics menu on the device.
Posted on Oct 05, 2010
Xerox 7345 showing error order 2nd bias tranfer roller. Now i require the exact nvm value to reset the problem
If memory serves me correctly. Order a new 2nd BTR and you'll get the information within the packaging. If it's on contract it won't be a problem. Good luck!
Jan 29, 2015 | Xerox Office Equipment & Supplies
Bizhub 210
How about the transfer roller? Replace that yet? Are you getting any error codes? How about the developer bias clip, there are alot of possible solution. I would double check things again and how many copies are on it???
May 16, 2013 | Office Equipment & Supplies
How do I reset 2nd bias transfer roll for xerox 7556
On the 7556 and most other Xerox copiers, follow these steps to reset the counter. You do NOT need to call out a tech.
The supply life counters must be reset when some supplies are replaced.
  1. Log in as the System Administrator or Key Operator.
  2. Press the [Machine Status] button on the Control Panel. The Machine Status screen will be displayed.
  3. Select the [Tools] tab on the Touch Screen.
  4. Select the [Device Settings] button.
  5. Select [Supplies], and then under Features select [Supply Counter Reset].
  6. Select the required supply item, and then select [Reset Counter].
  7. Select [Reset] when the confirmation screen is displayed.
  8. Select [Close].
  9. Press the [Log In / Out] button on the Control Panel. The Logout screen will be displayed.
  10. Select the [Logout] button on the Touch Screen to exit.
Feb 11, 2013 | Xerox DocuColor 3535 Copier
Need to replace transfer belt cleaner and 2nd bias transfer roll
Both are probably still good but the HFSI (High Frequency Service Item) counter needs to be reset. Unless something has changed with them that has to be done with the service laptop hooked to machine with a serial cable and using M24 diagnostics.
Jun 20, 2012 | Xerox WorkCentre M-24 Color Copier
All three lights blink rapidly. The computer says it cannot communicate with the printer. When I plug the USB into the computer the computer doesn't acknowledge that anything was plugged in. If I...
It sounds like your main board (the brains) in the printer is fried (I got the same problem with mine). That part (when purchased new) costs so much, your better off just getting a new printer, and it's not your typical user serviceable part (hard to remove, many wire/plugs going to/from it).
The problem with replacing it with a used part, is that the used circuit board will still have the consumable counters in it set to old values from the printer is was pulled from, and NEW or RE-Chipped consumables will be needed to reset those back to zero again (not just the toners, but also the photo drums, fuser, and transfer belt). So, if the used board was connected to "old" consumables (nearly depleted), you won't be getting too many prints before it's asking for either new toners, photo drums, fuser, or transfer belt. The fuser and transfer belt cost upwards of $175 or more each....
How it works is like this, according to Okidata's Tech support guys. When you put a new "consumable" (toner, photo drum, fuser, transfer belt) into the printer, that main board resets the counters AND THEN it immediately blows a fuse (not a regular fuse, but a microchip fuse) in that comsumable so it can never reset the counter for that consumable again. When that consumable's counter reaches it's predetermined number of prints, the printer refuses to print until it is replaced (or it is "re-chipped" with a new fuse).
They make toner refill cartridge chips, and I think even a photo drum kit (seen it on Ebay). But I haven't found anything that would rest the fuser or tranfer belt. Let me know if you find something to reset the fuser or transfer belt.
Jun 10, 2011 | OKI C3400n Laser Printer
My window is showing "replace transfer belt soon" what is that and where is it and where do you find a transfer belt?
When transfer belt count 60.000 image need to reset.
Transfer belt (and other consumables) reset follow this procedure:
1. go in tech mode:
Press consistently menu -> # -> 1934 -> menu
2. in tech mode find ->consumables counter -> transfer belt ->reset
3. after 20 sec. power off and power on
If this not help try this:
1.MENU # 1934 MENU
2.Tech Mode (not User Mode)
3.DataSetup
4.Clear All Memory
Oct 27, 2009 | Samsung CLX 3160fn All-In-One Printer
I need to know how to replace...
The transfer belt cleanning blade is under the transfer belt.Remove 2 screw and change it.The bias transfer roller is mounted in two bushings,remove the bushings and 2 springs.The fuser unit : upper fuser roller,lower fuser roller and the cleaning rollers.
Aug 25, 2009 | Office Equipment & Supplies
How do i reset the second bias transfer roller on a Xerox 3535
I am afraid you will have to call in a qulified xerox technitian to reset the second bais transfer roll. It need to be done via a laptop connected to the m/c. The laptop needs to have a special program which only xerox techs. have in there possetion.
George
Jun 02, 2009 | Xerox DocuColor 3535 Copier
Not sure which part that may need to be replace
tranfer belt is a large mylar black belt.
transfer roller is a skinny gray foam roller
Mar 13, 2009 | HP Color LaserJet 4550n Printer
Xerox DC3535 Color Copier
No unfortunatly. That is done in the diagnostic mode on the 3535, and that is propritary sofware where the diagnostics has to be accessed with a laptop that has that software loaded onto it.
There are some resets you can do, but they wipe out all the NVM inforamtion. Once those numbers reach a certain level, they have to be reset via a laptop.
Now that being said, once it is accessed, the service rep CAN change that threshold to a much much higher number so you can run the parts to failure, which is more realistic.
Those parts are very easy to replace. And can be purchased from a business called The Parts Drop, Google that business and talk to Britt. No I do not work there, but have dealt with them for years and they are very professional and exceptionally honest.
Jul 08, 2008 | Xerox DocuColor 12 Color Copier
Xerox WorkCentre M-24 Color Copier Logo
557 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
