Question about Ovens
BAKE ELEMENT HOW DO I CHANGE THE HIDDEN BAKE ELEMENT. WHERE DO I GET ACCESS FROM?
  • Anonymous Mar 24, 2014
    TRYING TO CHANGE THE ELEMENT NOT LUCK
  • Anonymous Mar 26, 2014
    How do you get to hidden bake element
    Scholar:
  • 41 Answers
not sure I can help but will try. If your oven is fan forced you will probably find a cover that removes inside the oven to reveal the fan and also the element. Some elements are screwed in. Sometimes you have to take the back panel off also to get to the wires to remove them without breaking the lugs off. Hope this helps.
Regards
Bryan
Posted on May 28, 2008
My Electrolux double oven goes from "bake" to "warm oven " after about 1 hour. I try to use the other oven and it will go start to "warm oven"
is the bake element getting hot?when you put the oven on bake both the broil and bake elements come on,if just the broil element is getting hot it might take it an hour to heat up.you might just have a bad bake element,if the bake element isn't hidden does is turn red? if not it's not getting hot.
Nov 14, 2017 | Electrolux Ovens
How do you remove the moulded Hidden Bake Element from the inside whirlpool ceramic range accubake system
first, remove power from the unit before doing ANYTHING! second, remove the back cover of the machine, this will expose another smaller panel with 4-6 screws in it running along the bottom edge across the back. after removing the screws you will have to gently BEND the panel down until you can see the wiring leading to the hidden bake element. cut the insulation covering the back of the element... be sure new element is placed in the exact location of the old one to avoid shorting the bake terminals to the metal cover, then reverse the removal process...
Apr 26, 2016 | Whirlpool 30" Self-Cleaning Freestanding...
All the lights and buttons work/sound on control panel. Broiler oven works but baking element not working. Replaced baking element with new, but still doesn't work. Convection fan works, light works,...
Manufacture and model would be nice ohm out the bake element might be open some are in the oven cavity others are hidden below the lower oven plate and have to check from the rear by removing back cover in the bake mode the broil element element cycles on/off thats why you have some heat.
Feb 10, 2014 | Ovens
How to replace the lower, hidden bake element in the lower oven of an Electrolux Icon oven
You need a 1/4 or 1/16 mm. to take it out, they always have a simgle plug.
Nov 13, 2013 | Electrolux Ovens
How to get access to bottom element (not visible modle) to replace ir?
That model is not shown as hidden bake but the bottom would have have to lift up to uncover the element .
Nov 19, 2010 | Whirlpool RBS245PDS Electric Single Oven
Whirlpool Range GR563LXSSo Oven doesn't come up to temperature. How do you get access to the hidden bake element to check connection and voltage?
Hello- Access is thru left side panel (from front).  Unplug oven and move out for easier access. Remove panel and find cover for element under insulation. Be careful- fiberglass dust and sharp edges!  Insulation needs to be carefully pulled back enough to remove cover and element.  This is where most techs get sloppy-  Insulation should look just as good after you finish so take some time to do it right. Please acknowledge this posted solution if helpful. I have more info if needed.- Thanks- Ed
Mar 24, 2010 | Whirlpool Ovens
Preheat takes too long
does the oven bake properly when it does reach temps?
if this is a newer oven, with a hidden bake element, they do take longer to preheat so may not have any problems, just give it about 15 minutes to preheat.
if it is older and doesnt bake right, then you may have a bad bake element.
the unit will heat but wont bake right.
unplug the oven and take the bake element to your local parts house, they can check it and sell you a new one if needed.
Jan 10, 2010 | Frigidaire Ovens
Ovens Logo
164 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
