Question about Honeywell Heating & Cooling
My Honeywell thermostat T874R is showing the EM heat indicator light when I turned the AC on for the first time this season--Why? House is warm but not humid.
  • Anonymous Mar 20, 2014
    Thermostat display showing-ac and furnace will not turn on
The above was posted by fixr1st
Posted on May 29, 2008
The T874R thermostat should be a heat pump thermostat. EM means emergency heat which you obviously are not using. That means that you just need to determine if your heat strip is on while you air conditioner is working. If so you may need to replace your thermostat or you heating relay or sequencer.
Intertherm p5rd036k
Sounds like your tstat could use some attention. The broken bar sounds like a low battery indicator. To verify wether the tstat is working correctly you can try bridging the R and W wires (after the thermostat) to set a call for heat. Be careful when you do this as you could short or blow your circuit board and other sensitive electrical parts. The R terminal is 24v power and when you bridge R and W you send 24v to the circuit board which indicates a call for heat. W is heat Y is cooling. If nothing happens still then you should call a technician as you may have broken parts and will require replacing.
Dec 09, 2013 | Heating & Cooling
Honeywell emm-3 goes to high heat when thermostat does not call for heat
Replace it (thermostat), but first make sure its in a good location to read the space temperature.
Nov 29, 2013 | Heating & Cooling
Honeywell troubleshooting
Emergency heat is the setting that shows that your heat strips are activated. Sometimes people do not wire up the heat strips at all as the use a great deal more power than the normal heat pump uses. The problem is that a heat pump comes to a point where it is not efficient at about 28 degrees and this is where you need the heat strips or if you want to heat the house quickly which a heat pump will not do. Heat strips are located in the ductwork and act like a space heater. A H/A tech is probably needed to check this stuff out for you.
Nov 15, 2013 | Cars & Trucks
New thermostat..have heat but not A/C help....
What are you setting the thermostat to when you turn on the AC , if you turn on the AC and the house is warm you will need to turn the AC down to a lower setting before the the AC will start up.
Mar 14, 2010 | Honeywell Electronic Programmable...
The transformer on my central AC/heater (luxaire model # A236A344T LH) keeps going out. There are 4 settings on the wall. Cool, off, heat and EM. Heat. The setting switches to EM. Heat each time the...
You might have some thermostat wires that are touching meaning the insulation has been broke off and getting a direct short. Check the wiring going to the outside unit and replace any wire that is in bad shape. let me know okay. Ken
Dec 11, 2009 | Honeywell Programmable Thermostat Heater
My AC quit blowing cold air all of a sudden while I was out of town - my wife turned off the compressor and turned the fan to on, thinking it may be froze up - 2 hours later still no cold air - service...
Depending on how it's wired, she might have turned it off and on again and popped a breaker. It could be wired with a breaker for the fan motor and a breaker for the compressor.
Oct 07, 2009 | Honeywell Heating & Cooling
Cool air not working with honeywell Model # RTH230B
Do you have a heat pump? If so, not compatible. What i did was move the jumper on the thermostat (RH RE). This is on the inside of the thermostat - NOT the red jumper!!! and got the AC working (the heat had already worked during the winter, problem only became apparent when I needed to use AC). I may have to change the jumper again when the season changes...not sure yet.
Apr 26, 2009 | Honeywell Programmable Thermostat Heater
Honeywell rth230b won't shut off heat
Sounds like a relay sticking. Possibly in the thermostat or possibly the furnace relay at the furnace. The next time it happens, unplug the thermostat from the wall. If the furnace still runs then it's the furnace relay.
Hope that helps...
Geno
Mar 07, 2008 | Honeywell Programmable Thermostat Heater
Honeywell ST6400C programmer doesn't switch off
Since you have three on/off timing modes could there be an overlap in the times?
The wires in the unit might be crossed. (don't always assume the contractor who wired maintained the correct colors , I have a friend who blew out a heating pipe because when a replacement motor valve was installed it was never wired right and the plumber assumed the colors were correct so no overtemp shutoff created steam in PVC pipes, OPPS)
There fore maybe one is still coming on. Do you have more than one heating zone? IF so see below
I guess the main question is why manually turn it off? why not use the program.
I will assume your heat is know as forced hot water heating. My house is multizoned however when the zone calling for heat turns off (zone valve closes) I installed a bypass valve in the lowest zone in the house, and reduced the circulator low shut off temp to 130 F which means even though the heat isn't on my circulator will continue to run dumping this excess heat in the lowest part of house to rise through house. (the spring loaded water valve allows the heated water to flow into this zone )We do have two thermistats. And even though the lowest one is not calling for heat the radiators are hot when the excess is dumped into this zone. So investigate and see if your system might be similar. (multizone).
Investigate your wiring, reprogram, replace any battery backup.
Dec 18, 2007 | Honeywell Programmable Thermostat Heater
Heat will not turn off
Call 1-800-341-0110, Honeywell Residential tech service.
Nov 11, 2007 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
265 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
