Question about Rheem 50 Gallon FVR NATGAS Water Heater 6YR 22V50F1
Just discovered water standing in drip pan about 1 inch deep. It's dripping from faucet-like thing on side. we have a rheem guardian system fury gas water heater manufactured 4/2004. appreciate any help you can give us. thank you.
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 22 Answers
You need to replace the garden hose valve that they have their on the side from the garden dept at your local hardware store. You need to shut your water off and the gas to replace this. If you do not shut the water off it will be coming out at high pressure when you finally get that valve off and dont forget to drain as much out as possiable with a hose to your desired location. If you do not let the water cool down inside the water heater before you change the valve and you could get a little wet doing this you might want to make sure it is no longer scolding hot water. If you do not know how to re light your water heater then dont!!!!! This is pressurized gas highly explosive and highley dangerous to breath in. So remember about the gas, hot water, presurized water line, were to drain, how much to drain, and how to get your water heater back on your side. thanks
Posted on Oct 05, 2010
The faucet is to connect a hose to to drain the sediment out of the tank at least once a year. More often with harder water. This will add life to your tank. A quick fix is to purchase a garden hose thread cap from the landscape area supply at your local hardware store and place on the valve. This is if you cannot stop the drip by just tightening the valve handle. When you drain the tank, you could replace the faucet although with the age you stand a chance of having additional leakage issues if you replace the valve.
My water heater is sweating so much it is puddling in the drip pan. How do you stop this and what do you recommend for a drip pan. Mine is a tin cap used for a furnace.
This particular model of water heater is intended for under-counter use. That should not place it in an environment that is conducive to condensation. Water heaters are usually well insulated to prevent heat loss and as a side effect, condensation. If you have not had this problem before now, I would suspect a tiny leak somewhere rather than sweating. If you have always had this issue, then you may not be using the right product for the installation or may not have it in the proper temperature environment.
Mar 19, 2015 | Rheem 2.5 Gal 6 Year Electric Heater
Problem keeping my Rheem hot water heater light
What brand, model, and approximately how old is water heater?
This is important because water heater designs are changing quickly.
Did you remove door over combustion chamber to access thermocouple?
Newer Rheem water heaters have air intake under combustion chamber that has to be blown out using compressed air.
If this is different brand, then use mirror under water heater to see air intake.
Set water heater on bricks to avoid high water. Make sure drain line out of drip pan is 3/4" and terminates in good drainage location.
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html
Put brass garden hose cap over drain valve.
http://waterheatertimer.org/How-to-replace-water-heater-drain-valve.html
Aug 29, 2012 | Rheem RHG Pro40-40F Pro Series Natural Gas...
New Rheem Fury Guardian System 50 gal water heater model 42V50-40F. Loud low humming or drone sound when in operation. What can this be?
Is the noise when the water is running or when the burner is running???
If it is just the water then the noise often is the flow checks inside the tubes going to and from the heater...
If it is the burner, then the noise could be the gas going through the gas valve...a bit of moisture or dirt can sometimes cause noises...usulally will correct its self after a bit of time...no worry...
poping crackling sounds and such are common with mineral builsup in the bottom of the heater....
Flush the heater and get the dirt out....
sizzling noises sometimes happen from condensation dripping onto the burner....gain not a problem...
sometimes the gas properties will cause the gas to make noises when going through the gas orifice into the burner... usually this is air or a LP air mixture known as "citigas" that will burn like natural gas but really isn't and it will make noises such as your are describing...again no problem...
Ultimately the noise you hear is not a problem but can be irritaing if the heater is where you can hear it easily...
Feel free to comment back if you have any more questions...
heatman101
Feb 25, 2011 | Rheem 50 Gallon FVR NATGAS Water Heater...
I just bought a house, and the water heater instructions posted on the water heater is all covered up by the earthquake straps! The earthquake straps are a requirement in California, I can't remove them....
1) Model 41VR50N is Rheem fury gas water heater.
Look on tank label, the second 2 digits of serial number are year of manufacture.
2) Rheem does not show that specific model number, but has generic manuals for Fury series:
Open link to read about Fury series, and access brochures and manuals.
http://www.rheem.com/product.aspx?id=CC643E03-4C15-4775-B139-E504A95651F7
3) Sample manual for Fury appears on following link:
http://globalimageserver.com/fetchDocument.aspx?id=01091171-3bac-4cb9-a0a8-a11aac3bd668
4) Rheem phone number: 1-800-432-8373
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Jan 30, 2011 | Rheem Water Heaters
We have a brand new rheem 40 gal elec water heater, after installation we have water leaking from the base of the relief valve, pooling up in the plastic fitting and making it way over the side all over...
Water heater should be set in a drip pan.
Otherwise, put 1 gallon bucket under TP release pipe to catch water.
http://waterheatertimer.org/Water-at-bottom-of-water-heater.html#drip-pan
When you say relief valve, I assum you are talking about brass valve located on top of tank or near top of tank. This is TP valve and a pipe connects to this valve and runs down to within 6" of bottom of tank. TP valve has a small lever on it.
If you are talking about tank drain valve located at bottom of tank, then add a comment.
Following information is for TP valve.
Dripping TP valve can be caused by 3 different thing:
1) Obstruction inside TP valve. Open TP valve for a moment to flush away particles and slowly lower lever back down. See if water stops dripping, if not, then replace TP valve
2) Defective TP valve: replace TP valve. Turn off electricity to water heater. Let heater cool for several hours so you do not get scalded. Close shut off valve located above tank on cold side. Open tub spout to relieve pressure, open tank drain or open TP valve and empty water below TP valve level. If TP is located on top of tank, not much water has to be drained. Tank is under press when hot, so be careful. Put teflon tape on new valve and install with big pipe wrench by turning clockwise until TP valve is very tight.
3) Overheating tank. TP valve is temperature-pressure valve. If tank water is over 150 degrees, the TP valve starts drizzling hot water to relieve tank pressure.
Lower tank pressure two different ways:
a) turn down thermostat
http://waterheatertimer.org/How-to-adjust-water-heater-temperature.html
b) install expansion tank on incoming cold water line
http://waterheatertimer.org/Water-at-bottom-of-water-heater.html#expansion-tank
Dec 19, 2010 | Rheem Water Heater Pressure Relief Valve
HAVE A RHEEM (GUARDIAN SYSTEM) FURY, IT IS FOUR YEARS OLD. FOR THE PAST TWO YEARS THE PILOT HAS BEEN GOING OFF EVERY SO OFTEN. WHAT CAN BE THE PROBLEM?
Probably the thermocouple, this is a very cheap and inexpensive part to replace. You can pick one up at home depot for about $20. For in depth instructions on how to remove and replace, please reply.
Dec 02, 2010 | Rheem 50 Gallon FVR NATGAS Water Heater...
Dripping Drain valve on rheem water heater
If your water heater is 10 years old or more, it's much better to replace the entire thing before you start having additional problems with it. You MAY be able to drain your water heater and replace the valve with something more reliable, but, as I've said... if your water heater is old, this is just the 1st thing to go wrong. More will follow.
Aug 16, 2009 | Rheem 40 Gallon FVR NATGAS Low WATER...
My faucet is dripping--is there an easy fix, or
you could aoways go to there web site alot of these type of faucet have real good warrantys you might just be able to get a replacement for free,,, depending on the age of the unit
Jun 27, 2009 | General Electric GE SmartWater Household...
Rheem 50 Gallon FVR NATGAS Water Heater 6YR 22V50F1 Logo
612 people viewed this question
Top Rheem Water Heaters Experts
Lickzee
Jim Goldsmith
Jim Goldsmith
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
