Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Please help I have replace motor coupling and clutch. Washer is still not spinning and sounds like a belt is slipping but it is a direct drive motor. Please help.
    Genius:
  • 1,073 Answers
Check for an object between the tub and the basket
at the direct drive coupling connection to the transmission you should with a wrench or vise grips be able to turn the transmission shaft in both directions by doing so you can manually make the trany spin and agaitate by hand if it does check drive coupling for damage if it does not find the obstruction
Posted on May 27, 2008
I have an LG Inverter direct drive 10kg washing machine WD14060D6. It will not spin on any washing cycle....had the retailer out, and they said it was our wooden floor vibrations. The machine is 2 yrs...
i would check out the hall effect sensor(the motor position sensor). check videos on: appliancepartspros.com, repairclinic.com or youtube.com
Mar 27, 2015 | LG Washing Machines
Will not spin fast, when it spins you can rase lidmby pass door switch and stop itfrom spinning
  • The motor coupler may be broken. Many Whirlpool®-manufactured washers use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. You may need to replace it.
  • A belt may be broken. Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.)
  • The clutch may be worn. If your washer is a GE, it may use a clutch to come up to the proper spin speed. As the clutch wears out, it may prevent the unit from spinning well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician.
  • The drive motor may be defective. Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor.
  • The transmission may not be shifting properly. Older washers produced by Whirlpool® have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may drain the water but not spin. This is a complex system, if your washer has a shifter problem, you may want to hire a qualified appliance repair technician to repair it.
  • The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle. Call a qualified appliance repair technician.
  • Oct 22, 2008 | Roper RAS6233KQ Top Load Washer
    Water loads up but does not wash nor spin but does drain
    No agitation or spin? try these:
    Motor Coupling If the washer won't spin or agitate the motor coupling might have failed. The motor coupling connects the motor to the washer transmission. It is designed to fail if the washer is overloaded in order to protect both the motor and
    Drive Belt If the washer won't spin or agitate, check the drive belt. If the belt is broken or if it isn't tight on the pulleys the washer won't spin or agitate properly.
    Drive Motor If the washer won't spin or agitate the drive motor might be defective. This is not common. Check all of the other related parts to this symptom before replacing the motor. If the motor is visibly burned out or physically damaged, replace it.
    Stator Assembly If the washer won't spin or agitate the stator assembly might be burned out. The stator is essentially one half of a motor, it interacts with the tub by creating a strong electro-magnet. If the stator burns out the washer won't spin or agitate. Check the stator for continuity. This part is often misdiagnosed.
    Transmission or clutch assembly not engaging due to going out or slipping.
    Door or Lid Latch Assembly If the washer won't spin or agitate the lid switch assembly might be defective.
    Door Lock Motor and Switch Assembly If the washer won't spin or agitate the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
    Motor Control Board he motor control board provides power to the motor as well as direction and force. If the motor control board is defective the washer may not work at all or function properly.
    Oct 09, 2014 | Maytag Neptune Washing Machines
    It does not want to spin
    No spin, or lite spin try these: bare in mind that many times there is no spin it can be due to a clogged water pump so check it for debris and or broken propeller.
    Other items to check Using a multi meter check for continuity the door switch, which when bad may not allow agitation or spin. Bare in mind the lid switch assembly can fail either mechanically or electrically.
    Check the clutch, brake assembly and transmission, one way to check for slipping is to get under the machine after a spin cycle ( this is if u get a lil spin but not much leaving clothes still wet) mix in a spray bottle a lil water and some dish detergent, then spray it on the clutch assembly ( the metal round pc. Connected to the tranny) if it sizzles and steams up then u know its bad and slipping. Another way to check clutch if u get no spin at all? Is to take it out and use ur hand to try and turn the inner spring assembly pushing it around the inside? If its very easy, it BAD should be hard to push by hand.
    Or try the hand test:
    If no hammering sound has ever been heard out of this machine, one of the unofficial tests we professional appliantologists will do in the field is called the Hand Test. WARNING:This test is not sanctioned by Whirlpool Corporation; it involves bypassing safety equipment and then putting your hand on and near rotating machinery which could result in injury, dismemberment, disfigurement, disembowelment, mangling, hideous screaming, and a bloody death. Proceed at your own risk! Have a nice day.
    - put the timer on a spin cycle and open the lid- grab the inner basket with maybe 30% to 40% of your hand strength with your left hand
    - turn on the machine and bypass the lid switch by depressing the lid switch with a key until the machine begins to spin
    - if the clutch is engaging properly, the basket should immediately begin to spin and slip through your hand
    - if it takes very little force to stop the tub from spinning, the clutch needs to be replaced.
    Next check the motor coupler which engages the tub and tranny to the motor. ( if its bad u usually get no wash or spin or very little of either)
    Next if belt driven check for a loose, worn or broken belt. And on some models there is no clutch but rather what is called a splutch. And a MODE shifter. These can go bad and effect the spin cycle.
    On some front load models u may need to check the STATOR assembly.
    Sometimes a no spin machine can be due to a plugged waterpump hose or obstructed water pump propeller. Check these by eye and hand. And in some models check with a meter for continuity and voltage.
    next step is toremove the cabinetand jumper the lid switch harness (tan to gray). Put the unit in spin and watch the shiny metal clutch disc that is on top of the transmission where the shaft comes out. If the machine starts and runs in spin, check to see if the disc is spinning. If it is, then the problem isnot in the gearcase- look for trouble in theclutch,basket driveor the tub drive block
    If, on the other hand, the disc is NOT spinning, check for a problem withthe motor drive coupleror one of its retainers. This washer doesn't have a belt. Instead, the motor is directly coupled to the gearcase by a drive coupler; that's why it's called a direct drive washer.
    Read more:Diagnosing and Repairing Spin and Agitate Problems in a Whirlpool / Kenmore Direct Drive Washer
    http://fixitnow.com/wp/2010/07/07/diagnosing-and-repairing-spin-and-agitate-problems-in-a-whirlpool-kenmore-direct-drive-washer/#ixzz3XW7eZwiN
    By the way my advice is free cuz God is good!
    Apr 29, 2011 | Washing Machines
    My washer will spin but very slowly. Motor and shaft spins out of washer.
    Your problem sounds like the drum/tub drive clutch is worn. Especially if the motor operates fine and attempts to spin the tub. This model is a direct drive unit, no belts, so if the motor operates during the spin and drain cycles but the tub is barely moving, only two problems can cause this, bad clutch (which is engaged only during the spin cycles) or worn drive coupling on the motor. If the coupling were a problem, though, you would also notice sluggish or erratic agitation during the wash cycle.
    Hope this helps
    kcomp1863
    Jan 04, 2011 | Roper RAS6233KQ Top Load Washer
    My washer will fill up but then wont spin just makes buzzing sound
    It doesn't agitate If your washer doesn't agitate, check these: Lid switch Motor coupler Belts Clutch Drive motor Drive pulleys Transmission Agitator Lid switch If the lid switch is defective, the washing machine may not agitate or function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it. Motor coupler Many washers produced by Whirlpool® use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. If this happens, you need to completely replace it. Belts Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.) Clutch If your washer was made by GE®, it may use a clutch for agitating the clothes. As the clutch wears out, it may prevent the washer from agitating well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician. Drive motor Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor.
    Jan 05, 2010 | Maytag HAV3460AWW Top Load Washer
    Sounds like belt is slipping on the gear.like a brrrr sound . how do I get to the belt . Do not see how back comes off????
    If this is a Whirlpool top loader (as the picture you have this posted under) it does not have a drive belt. This is a direct-drive washer that uses a motor coupling instead of a drive belt. That noise you're hearing is not a belt slipping. Also, the back of the washer is not supposed to come off, you will need to remove the exterior washer casing to access the interior.
    If the washer will fill and drain, but won't agitate or spin, you may have a broken motor coupling. The noise of the motor engaging, lack of agitation and ability to still drain are the usual symptoms. This is a common fail item with this model washer through normal wear and tear. Newer versions of the coupler are more resilient and resist breaking. The following link explains how to replace one:
    http://www.fixya.com/support/r385250-replacing_motor_coupling_kenmore_top
    The motor coupling is located between the drive motor and the transmission and takes the place of a drive belt. They do wear out and can break. The replacement part number is included in the link I provided and is an improved upgraded coupling that is more resilient. It should last longer. If you have questions, or require additional assistance, please let me know. I hope this helps you.
    A replacement coupler can be purchased on line at appliancepartspros.com for about $11. Just use the part number in the link and "Search by Part Number" for your search criteria.
    Aug 03, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
    Spinning cycle is not spinning.
    It could be belt or transmission. I would tip back the washer to check. Some times the belts are under the whole washer. depending on your model, it may be inside the housing. It's only a few screws to take off the front panel. They are pretty self explanitory. Let me know if this helps.
    May 04, 2009 | Kenmore 22422 Top Load Washer
    Washer not spinning enough to ring out cloths
    if a direct drive whirlpool, its the clutch, easy replacement, if you have the cabinet off already, remove the agitator, then pump, motor, drop tranny and replace clutch
    Jan 22, 2009 | Kenmore 22422 Top Load Washer
    Whirlpool Washing Machine Model#63849
    if it wont spin either but the motor is running then you need to replace the motor coupling. its only a 10 dollard part and easy to install.
    Oct 27, 2007 | Whirlpool LSB6200KQ Top Load Washer
    Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
    52 people viewed this question
    Dan Webster
    Dan Webster
    Mike Cairns
    Mike Cairns
    prem mathew
