Question about Saniflo & Saniplus& Macerator Pump
The unit is vibrating and too noisy only been in 7 wks
    Scholar:
  • Saniflo Expert
  • 115 Answers
Could be a bad installation or the motor might be tilted and not sitting straight inside the pump casing. Disconect the discharge pipe and vent pipe and drain the pump into a bucket, check if it makes a different, if it does then the problem might be on the drain pipe. Also you might want to open the lid and remove the motor with pressure chamber and make sure is sitting straight inside the pump casing.
Posted on Oct 11, 2010
I have a comfortaire bhd501-d that is very noisy. Any solutions? I checked the screws on compressor and they are tight.
Pull the plug on the unit and strike it moderately with your hand listening for any vibrations. Try to pinpoint the source of that vibration and correct it. You should also place the unit on solid ground to eliminate the possibility of the noise being amplified by the surface it is sitting on. "Very noisy" is very subjective. Best I can do for now. Please post your findings
Jun 06, 2014 | LG LHD45EL Dehumidifier
Kenwood KW85 is noisy
Hi, have you tried moving it to somewhere else as it can be noisy depending on what type of surface its on, as this can cause it to vibrate
May 14, 2008 | Kenwood KW85 Air Conditioner
Loud Vibration/Noise when System Starts
This happen when there is air in the gas line...if the problem is still there after a couple of days you will have to return the unit for an exchange the gas control is giving problem...contact rheem first before making a exchange decision..they will walk you some step first to ensure there is not a problem
Jul 03, 2010 | Rheem Direct Vent Natural Gas Tankless...
Noisy Blower Motor
could be trash leaves acorns ect in housing that the blower is picking up then dropping when the unit is off. try cleaning the housing the motor fits into
Aug 04, 2009 | Buick LeSabre Cars & Trucks
Very loud vibration during the spin cycle, how do you control this only 2 wks old
check the inside of the machine (have to unsrew the top of the machine)each corner should have a rod wich the drum balances on perhaps one has come loose or a spring is gone. possible lol i hope this is some help to you
Apr 26, 2009 | Frigidaire GLTF2940ES Front Load Washer
Motorola T6550 pair.
I can see where this feature can seem somewhat inconsistent. But if you think of it like a phone ringing, it is easier to understand. Once you have answered the phone, the phone stops ringing. And the person who called you never experiences a ring on their end.
VibraCall® Alert
Page 26: VibraCall is a vibrating alert that notifies you that your radio is receiving a message. This is useful in noisy environments. When the alert is on, the radio
vibrates once every 30 seconds when you receive a message on the channel and
code you set.
• To turn vibrating alerts on, press menu until the vibrating radio symbol is displayed, then press the plus (+) button to display the letter Y for Yes.
• To turn vibrating alerts off, press menu until the vibrating radio symbol is displayed, then press the minus (-) button until the minus symbol (-) is displayed.
Dec 10, 2008 | Motorola Talkabout T6550 (7 Channels)...
Rinnai model 531 2520FFU 91 N
Have the installer replace the inducer blower assembly. Rinnai will cover the repair and your technician will get paid from Rinnai.
Mar 03, 2008 | Heating & Cooling
Noisy pump
Obviously, this unit has a warranty. Are you packing the coffee too tightly? Run the unit without any coffee and see if the vibration is still there. If it is, get it fixed. If not, modify what you're doing.
Nov 02, 2007 | DeLonghi BAR 140 Espresso Machine
Too noisy while running
Sorry to hear that. Mass produced in China or Taiwan units rarely need to pass a quality control check or they get josled about in transit. Some units made by Honeywell with overseas assembly and parts also have this same problem. Cheap labor, cheap parts. It shouldn't be on the part of the user to track down faults, but if you want to try to find the squeaks and vibrations - go inside the unit and look for loose components. Duct tape in the right places does have a calming effect. A little silicone sealer does wonders too! Just be careful! I'll probably get a "thanks for trying" rating but this is just my opinion.
Sep 09, 2007 | Holmes Products PCH4199UM Ceramic Heater
Noisy humidifier
A noisy humidifier may be the result of an unlubricated fan motor or a drive mechanism clogged by debris. Periodically clean the water reservoir, fan, and nozzle to ensure that they are clean and working properly. To keep your humidifier working smoothly and efficiently, lubricate the fan motor bearings with SAE #20 oil. Be sure to consult your owner?s manual for proper care and maintenance procedures. If it seems loose, vibrating parts are causing the noise: 1) Disconnect the power. 2) Remove the cover and look for any vibrating parts. Tighten screws, if necessary. 3) Wiggle the fan to see if it is loose on its shaft. If it is, tighten the mounting fasteners. Lubricate the motor's bearings if suggested in your owner's manual. 4) If it still makes noise, call an appliance repairperson or take the unit into an appliance repair shop.
Jan 18, 2006 | Honeywell HCM530 Humidifier
Saniflo & Saniplus& Macerator Pump  Logo
179 people viewed this question
Top Saniflo Home Experts
Paul Carew
Tim Whalen
Are you a Saniflo Home Expert? Answer questions, earn points and help others
