Question about Kitchen Appliances - Others
Setting the oven on beko scc 2632 - Kitchen Appliances - Others
2 Suggested Answers
  • 715 Answers
SOURCE: How to get access to change oven thermostat on scc
kill breaker pull stove out and take top back panel off you may want to take a picture of it to insure you get all wires back on right
Posted on Jan 13, 2010
I have power but not switching on at Knob no grill or oven no fan
Beko OIF21300B Electric Single Oven not heating - Repair
www.how-to-repair.com/.../beko-oif21300b-electric-single-oven-not-hea...
Jun 11, 2015 - If your Beko OIF21300B Electric Single Oven is not heating or tripping the ... Now the cooker turns on and the display lights come on but the cooker does not seem to work and start heating up. ... The grill element doesn't work
[PDF]Download Manual - Beko
downloads.beko.co.uk/bekoupload/manuals/DVG592.pdf
Congratulations on your choice of a Beko quality cooker which ..... Before you startusing your cooker, clean ... if an appliance burner doesn't light, press again.
Dec 13, 2015 | Beko D533AW Single Fan Oven Electric...
HI I have a Beko Electric oven (model SCC 2632). It has a combined oven and grill element which i redently had to replace. Fitted it no probelm, but when it came to attaching the coloured wiring spades...
Have a beko scc 2632 cooker. Need to know the colours of wires fom left to right of grill/oven element as it is different than the old element?
Jan 29, 2011 | Ovens
I ve got beko electric cooker model DC543 and the oven doesn't work
This tutorial will show you how to check your Beko element and how to replace your Beko cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
    1.Your Beko oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Beko manual.
    2.If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
    3.When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing. For all you Beko elements
    If this helped you why not get me a beer?
Paul is from the Naturally he would appreciate beer How to Repair Home...
Jan 15, 2011 | Ovens
Have beko D533W electric cooker oven not heating up fan still working
Generally speaking, if the fan is working o/k, then it is usually the fan oven element that has failed.
This is usually located at the rear of the oven compartment behind a removeable cover.
Nov 14, 2010 | Ovens
Beko dvc 62 ,all electrics tripped out ,put cooker
The element has blown. It will cost you around
May 16, 2010 | Ovens
How to get access to change oven thermostat on scc 2632
Jan 13, 2010 | Ovens
Touch pad will not unlock after running self clean cycle,
ran the SCC and the oven door unlocked when completed but the touchpad did not. Can;t use over at all, top of stove works fine. None of the bottons for the oven works. still says self clean completed, will not go away, can't use oven at all.
Dec 14, 2009 | KitchenAid KESC307 Electric Kitchen Range
No fan or heat
Hello..... have you (a) checked that you have power going to the oven...(b)...With the power to the oven switched off open the terminal block (where the cable from your socket enters the oven) check that all connections are secure....(c) remove the rear panel of the oven and check that the safety stat is ok.......(usually small square white or gray unit wit two wires running to it found on rear of main oven...it is usually fixed to a bracket or directly fixed to the cabinet...test for continuity with a multimeter if open circuit ..that is no meter reading relpace it
regards Sir Galahad
Jun 28, 2009 | Belling XOU492 Electric Double Oven
Beko s512 oven wont heat up light not on hob works ok ,,electric oven
you probabbly have some burnt out elements or switches gone bad use a meter and check for current coming to your element when you have it on if no current its a switch if there is current then its an element problem
Mar 15, 2009 | Ovens
Beko double oven electric cooker - bottom oven (fan assisted) doesnt come on, rest of cooker works fine
Oct 03, 2008 | Kitchen Ranges
Kitchen Appliances - Others Logo
96 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
