Question about Haier HWR06XC5 Wall/Window Air Conditioner
After storing away for the winter, unit has no power.
I bought this unit last summer and it worked fantastic. i stored in away in the original box for the winter and when i plug it in, there is no power response. i know its not the outlet because i tested it with our products. help!
  • tmtee Jun 10, 2008
    well i have the same problem with my air conditioner too so first i have to leave it out for 8 hrs for the oil to settle then the room have to be hot before i plug it in to get power? just like the other person said i brought mine last year and i working fine then i stored it in the box and now i gets no power
  • 525 Answers
Just a wild guess but maybe it's not warm enough to activate the display?
Posted on May 27, 2008
Tip
How to store your motorcycle for winter. Storing your motorcycle.
As the summer months start to come in, we all like to get our motorcycles out and start riding them, but i hear a lot of people saying help, my bike wont start! That is because when you last parked it in the shed for the start of winter, then you made no preparations. With a few simple steps, next summer, you can get your bike out, and fire it up without any problems, ready to ride. There are things you must do when you go into storage, and a few things to do when you bring your bike out.
OK,so winter is approaching, and you want to put your bike away in the shed.
First thing you need to do is drain some fluids. Drain your engine oil. Then drain your gas tank and carburetors. It is important to drain the carbys, as the fuel left in the float bowl will go bad. You can choose to totally drain your gas tank, or fill it to the top with gas. Storing a tank full with gas, leaves no room for moisture to form, causing rust on the inside of steel tanks. Next, you need to also disconnect one lead from your battery, or even better, if you have a trickle charger hooked up to it. Thats about it really. Also,if you are confident in doing so, remove spark plug, or plugs, and spray some penetrating oil down into each cylinder, turn engine over to work it through. This will prevent any moisture or corrosion from forming on the inside of your cylinders. It is also a good idea to clean or replace your spark plugs each year anyway.
Now it's summer, and you want to ride, just roll your bike out. Put in some fresh engine oil, a fresh tank of gas, and a fully charged battery, you are ready to go!
on Jun 21, 2010 | Motorcycles
I tried to turn on my air coditioning today for the first time this year and my Totaline Themostat P474-1050 won't turn on. Worked fine during the winter and last summer.
the thermostat is powered by the unit or batteries if batteries they may be dead if the unit you need to check fuses outside at unit or reset breaker outside depending on age of installation
Jul 10, 2012 | Heating & Cooling
Bought a Troy TB110 oush mower at end of last summer. I stored it all winter without opening box. I got it out today, put together and started it. It is leaking oil and blowing white smoke- What do I...
You must have stored it with the spark plug end down. This has caused the oil to get by the rings and on top of the piston. Pull spark plug out and pull starter cord to clear excess oil , put plug back in . Check oil , start mower and let it run until the excess oil burns off and some of it may still be in the muffler. Mower is ok. Some body borrowed my mower and did this resulting in the same problem.
Apr 10, 2011 | Troy Bilt 5.5hp Self Propelled Mower
Air conditoner will not power on
This will sound really crazy, but check to make sure that a little furry critter with beady eyes called a field mouse did not get in their and make it his home or worse yet his bathroom or decide to make a meal of the wires...
To find thid out youwill need to take the unit out of the chasis and then start opening up all the little boxes with wires that you can find...
You will probably know the problem when you find it... if there is no damage like that then check the t-stat...it may have lost the bulb charge and will not bring on the unit...
heatman101
May 07, 2010 | Whirlpool ACQ128 Air Conditioner
Trimmer wont start from storing over winter
clean the leads with alcohol but remember not to try and start it straight away.
Apr 12, 2010 | Homelite Mighty Lite Lawn Trimmer
I have a Simplicity dehumidifier/humidifier model SHCC6026 by Danby, bought new, used 2 months last summer as a dehumidifier, was emptied and dryed before storing for the winter. On start up this summer,...
I contacted the Danby Co. and found out the unit was still under warranty. They gave me the name of a local repair shop who replaced the float sensor "free of charge".
Thank you for your time and interest. If I have another problem later I will be in touch with you.
mef
Jul 02, 2008 | Danby Heating & Cooling
Maintance
Check for dust buildup on both hot & cold coils, including any filters. Clean as required. Power washing can be used, provided water is kept away from the fan motor & controls. Allow to dry thoroughly before using. Vacuum cleaning is also acceptable. Note than on some units, the hot coil will have dirt buildup on the inside of the coil.
Jun 21, 2007 | DeLonghi Pinguino PACL90 Portable Air...
Air conditioner
Unit is low on Freon. Take it to a repair shop to find the leak & recharge the unit.
Jun 18, 2007 | Haier Mechanical Air Conditioner HWF05XC7
Haier HWR06XC5 Wall/Window Air Conditioner Logo
156 people viewed this question
Top Haier Heating & Cooling Experts
Tom Chichester
Matt
Matt
Level 1 Expert
Vincent Schnittert
Vincent Schnittert
Level 1 Expert
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
