Question about Hilti Drills
I need a new chuck as mine has lost bearings and wont hold a drill bit
  • thinglenn40 Oct 04, 2010
    Which model is it? Do you live in the US?
  • 2,176 Answers
I would suggest going to Hilti.com or calling them direct at 1-800-879-8000 for the replacement part and nearest center.
Posted on Oct 05, 2010
How to change a drill bit?
Put drill in reverse grab ahold of the drill Chuck our use a key. A cordless drill you grab the Chuck order the speed button slowly and it will loosen.
Oct 10, 2015 | Drills
I can't release the bit from the chuck.
If it is jammed then hold the bit in a vice and try to knock the chuck off with a cold chisel or suitable piece of brass. then you can remove the chuck screw and replace the chuck. You should not be able to see the bearings underneath.
Jan 27, 2013 | Black & Decker 18 Volt Cordless Drill...
How do you get a drill bit or screw driver bit out of a Cordless Drill? It has been left to me. VPX 1222. I dont know how to use a drill, never had one before.
If it has a key-less chuck, hold the skirt behind the chuck proper and turn the chuck clockwise with the drill point facing away from you. If it has a chick that has a ring of teeth macnined into the outer band, you need a key to release the bit in the chuck. Keys vary greatly and if you do not have one, you will need to take the drill to a hardware shop for them to supply you with the correct size and configuration key. If you do have a key. place it in one of the three holes in the front part of the chuck, engage the gear teeth and turn the key anti-clockwise to loosen off the chuck jaws and remove the bit. If you require any more information, feel free to approach me at any time. Please rate this answer to your question.
Jun 05, 2011 | Drills
Broke bit inside chuck and piece is lodged in there now. Pulling out on chuck release does not allow broken part of bit to come out. Do I need to take drill apart or remove chuck to get broken bit out of...
TAKE THE OUTER CHUCK PEICES OFF THE IMPACT!! THERE WILL BE A C-CLIP, WASHER, SPRING AND ONE OR TWO BALL BEARINGS AND THE OUTER HOUSING, IN THAT ORDER! WITH ALL OF THAT OFF, MOUNT THE ANVIL IN A BENCH VISE WITH BRASS JAWS OR BETWEEN TWO PEICES OF WOOD, UPSIDE DOWN!!!!!!!!!!!!!!! THE TRICK IS TO HAVE THE BIT FALL OUT OF THE CHUCK ONCE IT IS LOOSE!!!! NOW WITH IT MOUNTED IN THE VICE AND PRETTY TIGHT, TURN THE TOOL ON UNTILL IT FALLS OUT, IT WORKS GREAT IF HAVE DONE IT ABOUT 75 TIMES!! MOST PEOPLE THINK I'M A WIZARD!! BUT IT'S REALLY EASY. WITH IT MOUNTED SOLID IN THE VISE THE ANVIL HITS SO FAST AND HARD IT VIBRATES THE ANVIL, IF YOU DO NOT REMOVE THE BALL BEARINGS HOLDING THE BIT, YOU WILL BE DOING THIS ALL DAY. SOMETIMES, IN THE CHEAPER BITS IT WILL ROTATE AND GALL UP SO BAD THAT IT WILL NEVER COME OUT, IN THAT CASE YOUR BUYING A NEW ANVIL ASSY. JIMS TOOL SERVICE
Jan 11, 2011 | Makita LXT202 BHP451 18 Volt Hammer Drill...
How do I change the drill bits and then tighten so the bits stay in the drill?
The chuck will not turn. So to loosen just turn the black plastic counter clockwise. The chuck will loosen. Or you can hold the black part on the chuck tight and put the drill in reverse and slowly squeeze the trigger and the chuck will loosen also. Do the opposite to put a new bit in. Put the drill in forward and hold the black part of the chuck and squeeze the trigger with the bit in place and it will tighten down on the bit.
Dec 16, 2010 | Dewalt 18 Volt Compact Drill Kit
Have a skil 597 T8 thats lost its grip - is it neccy to change the chuck - and if so can I replace the chuck with one that can open far enough to accept some larger bits?
I couldn't find your particular drill model drill. If this is a corded drill with a 1/4 inch chuck, you would do better to just buy a corded 3/8 drill. But otherwise, yes, change the chuck if you can find one to fit at a reasonable price. Drill chucks are sized to hold a straight bit of the maximum hole diameter that the drill has enough torque to drill into mild steel. If you find a larger one that will fit on your drill, it will work fine, but if you overload it you will burn it out. If you don't drill into steel with any larger bit than the original chuck, then this won't be a problem.
Jun 29, 2010 | Skil 3/8IN DRILL CHUCK/KEY
Keyless drill has locked in a closed position with the drill bit
I just put mine in reverse and grasp the chuck with a pair of channel locks. Pull the trigger and hold the channel locks tightly. The chuck will release the bit.
Jun 04, 2010 | Craftsman 3/8" Corded Drill
Drill bit is stuck inside my makita drill chuck
Try using the low torque setting on the drill when reversing and something to assist you getting a better grip to hold the chuck from spinning when reversing. This may help.
Good Luck
Dec 02, 2008 | Drills
Never have used a keyless chuck b4- need to change bit, how do I do this? thanks
hi this should be reletively easy hold the end black bit with the sivler bit holde coming out not the black bit next to the yellow case on drill you hold the black part thats at end of drill by where the bit goes into not the black bit near the trigger hope i explain this ok.
Hold this bit tight then put drill in reverse then press trigger a couple of times it might be tight but shouldnt be that tight it wont undo.
1 put in reverse
2 hold black plastic piece near where drill bit goes into
3 press trigger few times
4 this should undo it allowing you to put a bit in
make sure its in reverse else you will just tighten it up more let me know if you need further assistance ok
Mar 05, 2008 | Dewalt 18 Volt Compact Drill Kit
Drills Logo
51 people viewed this question
Top Hilti Drills Experts
woodzowl307
John Trevino
Are you a Hilti Drill Expert? Answer questions, earn points and help others
