I have a new YDP-141 Yamaha piano with the following problem: noise if the potentiometer volume is not turn to high
Hello, I've the same problem (Spain). For me it seems to be the ripple of the power supply. I've tested to power the piano with a 12 v battery, and then there is no noise at all. Next week I will try a better power supply. Yamaha seller has not given me any solution. Did you find one ?
Posted on Jan 29, 2011
My yamaha ydp-160 sounds like my pedal is stuck down. All keys are sustaining all notes. Is there an easy fix?
On SOME Yamaha pianos, there is an electrolytic capacitor 1mfd/50v that becomes leaky and causes this. On those with the particular main board the capcitor is at location C94. On other pianos there are other caps that bypass the wire from the pedals that are ceramic. Likely one of these has shorted. There is also a possibility that the pedal contact has shorted. Test for this by unplugging the pedal cable. If it still sustains, then problem is internal. Unless you are adept at electronics this is NOT a DIY repair.
Aug 07, 2011 | Yamaha yDP S31 ARIUS Console Piano
Would like to find the site to download operating instructions for a Yamaha Digital Piano Model No. YDP-121.
You can find the manual here, just choose the Support tab, and click the YDP Owner's Manual link.
May 09, 2011 | Computers & Internet
Where can I get a power cable to a Yamaha Digital Piano Model YDP-223
The cord is the same as the standard ones used on computers and many devices. You can get one at most any computer store, but here is a HINT: You can often find them at thrift stores and computer recycling facilities.
Jan 03, 2011 | Music
My Korg c15s has a lot of grating staticky noises when played ....I'm told it cannot be repaired as Korg no longer makes parts for this model?
I have a Korg C-15s and also experiencing loud crackling sounds when I turn it on. The problems seems to be either the sliding volume control or the amplifier itself. Honestly though, I believe the issue is the volume control. I opened my piano to get a closer look and attempted to clean the contacts on the volume. Unfortunately after cleaning the contacts, the crackling sounds became somewhat worse. After I turn the piano on, the volume control is generally rendered useless......volume set to low volume and the noise is quite loud and other times the volume control is set high and get very low volume crackling noise. No real consistency. The noise does diminish after a few minutes but so does the piano sounds to an inaudible level. There were a couple of instances where I turned it on and surprising enough, no no noise and perfect sound. For these reasons I believe the issue is within the volume control and not so much the amplifier. I have an electronics background and noticed that the volume control is very unique in design and is not something that can be substituted with another volume control from other sources.
My recommendation is to check the sound quality of the audio from the RCA L/R audio outs on rear of the piano by connecting to a stereo receiver. If it sounds fine you're in luck. If the crackling sound does not diminish after a few minutes like mine does, I would suggest disconnecting the internal speakers and using the audio out only. You can connect a pair of studio monitors or high quality computer speakers, preferably with a small subwoofer to deliver the full audio range and deeper tone of a real piano. I'm currently using a basic pair of Logitech computer speakers and is quite acceptable until I can afford a high quality set of monitors or relocate my piano closer to my high quality Yamaha receiver.
I hope this info helps a bit.
Aug 18, 2010 | Yamaha Full-Size Keyboard
My Yamaha YDP-121 digital piano has a key that is slow to pop up once pressed...the key will still produce a sound but the key becomes "sticky" and stays pressed, sometimes requiring manually lifting the...
Check if it might be dragging on the edge of the case. The restoring force for some of these comes from a silicone rubber dome that is oart of the contact. SOMETIMES the dome fails.
Nov 29, 2009 | Yamaha NP 30 76 Key Lightweight Digital...
I have a Yamaha ydp-121 88-key piano. It has 3 keys that are sticking. Any ideas how to fix it?
I wrote up and photographed for my similar YDP, see solution 2 under this post:
http://www.fixya.com/support/t8881187-1_key_not_spring
Oct 20, 2009 | Yamaha NP 30 76 Key Lightweight Digital...
Sticky Keys for Yamaha Digital Piano YDP-121
have you tried using the can of air. you can get it at almost any drug store walmart or kmart. just spray the can of air between the keys and they should become unstuck.
Dec 07, 2008 | Yamaha NP 30 76 Key Lightweight Digital...
181 people viewed this question
 Grubhead
Grubhead
