Question about Garmin eTrex Summit GPS Receiver
My Garmin Etrex Summit records tracklogs and shows them on the screen but when I upload them to my PC all tracks show as 0 miles, 0 altitude etc
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 81 Answers
2 possible reasons.
Either memory is full.
Try remove all data from history, and have a small run.
It should be OK then on PC upload.
If not OK, only hard reset can cleanup device, and return to factory settings.
Consult your manual for hard reset instructions.
Posted on Oct 04, 2010
  • tony_pagett Oct 04, 2010
    Thank you for your reply.
    I have already done a hard reset but still no joy
Can the garmin etrex summit download topo gps maps
The Garmin Etrex Summit does not have the ability to add maps to it.
Sep 13, 2011 | Garmin eTrex Summit GPS Receiver
Garmin etrex ledgend c: When track log is turned on, "breadcrumbs" mark the path I've traveled. I don't save the track but the breadcrumbs remain on the unit's map....forever.
Hello
Check both your track and map settings. Make sure that "show track on map" is not selected in your map settings, and in your track settings try erasing all previous tracks.
Hope this helps!
Dec 09, 2010 | Garmin eTrex Vista Cx GPS Receiver
How to get a replacement lcd cover/glass for a Garmin Etrex Summit. Mine is cracked.
I have a Etrex Legend (same size as yours) that no longer works - It has a good lcd cover.
email me at rsrogers at screaming dot net for full details
Rog
Oct 15, 2009 | Garmin eTrex Legend GPS Receiver
My Garmin eTrex Summit HC will not turn on. I
absolutely! Hve yoiu checked that this model does not have a switch on the rear as well as on the front? the one of the front is standby. The other one is main power. Not 100% sure about your model so just check first. Other than that take it back to seller for replacement or instructions
Jun 28, 2009 | Garmin eTrex Summit HC GPS Receiver
Garmin eTrex Vista Cx won't turn on
Call Garmin customer service, they are wonderful. My rubber thing around the outside became loose,and they sent me a new unit, even though it was almost 2 years old.
Apr 11, 2009 | Garmin eTrex Vista Cx GPS Receiver
Fragmented track logs
Part 1 of answer:
If you record a track log from A to B, then turn it off and back on to record a track log from C to D, it is obvious your track logs will be fragmented, even though they may not be recorded separately. They may appear as a single, interrupted, trip.
Maybe you've got this one, or this was not your question, so there is a:
Part 2:
Even if your unit can record track logs of up to 10,000 points, it cannot receive track logs back from your PC bigger than 250 points.
So, track logs get fragmented when uploaded back. To have them again in the GPS you must edit them to 250-point separate packages.
It can be done, for most track points are usually superfluous, especially when you record straight trajects; if your track log has many curves, it gets harder to simplify them.
Some software packages have a "Simplify track" tool, which solves this automatically in seconds, but it is the software who decides what to keep and what to remove, so edited track logs can be pretty unaccurate.
The only other option is to edit them one by one, so it's you who decides which track points are necessary or not. It can be painstakingly slow, but it pays if the tracks are important for you to use again and again.
Maybe I have not answered exactly what you needed to know, but anyway the solution is, or at least can be, editing your track logs in your PC. For instance, GPS Expert is a fine software to do that: you can split track logs, eliminate track points, join them back, simplify them or add new track points.
Nothing replaces a good editing software, but to get a useful collection of tracks and routes to use and share frequently, you must work on them for some time.
Best regards!
G. F. Kloss
May 27, 2008 | Garmin eTrex Vista GPS Receiver
ETrex Vista shows incorrect date
Thanks for the great advice. My problem is fixed!! Yay!
Nov 18, 2007 | Garmin ETREXVISTA GPS Receiver
Garmin eTrex Summit Screen
see discussion at http://californication.mtbguru.com/2005/11/20/deconstructing-the-garmin-etrex-vista/ Its possible that there's a bad connection at the ribbon cable, but most likely its a bad connection at the edge of the LCD glass panel. I've had two eTrex fail because of this problem. Don't pay the riduculous price Garmin asks for repair - just buy a new Magellan unit. If you must get a Garmin, go with the high-sensitivity receiver.
Sep 25, 2007 | Garmin eTrex Summit GPS Receiver
Garmin eTrex Summit GPS Receiver Logo
328 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
