Question about JVC XL-MV303 CD Player
I hv an MX-D402T that stopped working after an electrical storm last week. The 3 fuses are all good. Unplugging it from AC and restoring it does no good. No sign of electrical damage. Any idas other than "trash it"?.
    Brigadier General:
  • 3,513 Answers
Please check the links bellow to have a detailed idea to diagnose your problem:
http://inquirer.philly.com/newsroom/faq/pages/fdb7df9-30.html
http://www.kuro5hin.org/story/2004/3/24/45212/6874
Please accept the solution if it's helpful. Do get back to us for any further query.
Thanks for contacting fixya.com
Posted on Oct 04, 2010
What could cause intermittent power loss to radio, ac and crusis control in 2012 Chrysler 200?
The good news: since it's intermittent it's probably a simple loose or dirty electrical connection. In other words, nothing major. The bad news: intermittent problems are very difficult to find, because by Murphy's Law they won't show up when a mechanic's looking for them. Try unplugging and replugging every electrical plug you see under the hood. Sometimes that's enough to restore the connection. Also check your fuse box for a loose fuse, and (though this is unlikely) your battery cables. Good luck.
Aug 12, 2014 | Cars & Trucks
Electrical storm last night. Microwave (Panasonic NN-S669WA) has lost functions: quick minute, time-cook, stop/reset.
Is it dead now or just won't respond to the key pad? Try unplugging it from the wall for at least an hour. Plug it back in back in and see it it will reset...
Sep 17, 2013 | Microwave Ovens
My Sharp Aquos LC-26D44E-GY in the spare room has stopped working. It worked ok about 2 weeks ago, went to switch it on last night & its dead. We had a thunder/lightening storm last week? Ive changed...
First check your power outlet, try connecting the TV to a different power outlet. Then see whether the LED light on the TV is on or blinking. Anyhow, this might need attention by a qualified service technician.
Jul 15, 2012 | Televison & Video
My one year old microwave just stopped working. The light is on, but nothing else.
Sorry to read about your problem, I hope this helps you out.
here are some issues, but you still maybe under warranty.
  1. Blown fuse in HV transformer primary circuit or HV fuse (if used).
  2. Bad connections (particularly to magnetron filament).
  3. Open thermal protector or thermal fuse.
  4. Open HV capacitor, HV diode, HV transformer, or magnetron filament.
  5. Shorted HV diode, HV capacitor (will blow a fuse), or magnetron.
  6. Damaged protective VDR from filament to chassis (not commonly used).
  7. Defective HV relay (not commonly used).
Microwaves must be serviced by technicians due to the inherent dangers involved in repairing these appliances. Internal capacitors can retain a lethal electrical charge even though the unit is completely unplugged. A microwave radiation leakage test must be performed on the unit following any internal component repair.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question's. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Jan 05, 2011 | Goldstar MV-1501 Microwave Oven
It's not heating food, sounds louder than normal and smells like something possibly electrical is burning (or just getting too hot), but it looks as if it's working (lights up, tray moves inside, timer...
Here are some issues you can have
3 Thumbs - Helpful
Jan 04, 2011 | Maytag MMV5207BAW Microwave Oven
No Power to my TV after power outage
A lot of times its simply a fuse that goes out. Either way someone is going to have to open it up and inspect the fuses first. It 's a fairly inexpensive service call.
Hopefully the fuse took the hit from the storm.
Jun 04, 2008 | Televison & Video
Power failure.
Try to check first your power cord,
Probably theres a cut on wire that give the flows of electricity
Nov 26, 2007 | JVC MX-D402T Shelf System
32v434t dead
please go according to procedure 1 isolate h/output section supply. 2 check power supply output is ok if not repaire it. 3 after power supply is ok 4 check hor osc, driver &output if problem repair it. 5 check for loose contact or print break. 6 connect supply to hor section. set will work fine. good luck.
Sep 21, 2007 | RCA 32V550T 32" TV
Tv Shut off
check the regulator or the str,the horizontal transistor,or fuse
Nov 30, 2006 | JVC AV-27530 27" TV
JVC XL-MV303 CD Player Logo
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
