Question about Nautica A16550 Watch for Men
My A16550 Nautica watch has a little fourth hand, the normal hands are SECOND, HOUR, and minute hand, but i dont really know what that fourth hand is for. please give the information
jerryg50
  • 1667 Answers
SOURCE: nautica watch
The waterproof seal is not woking, or one of the controls was used while the watch was wet, and water came in to the watch. If this is not serviced soon, there will be eventual damage to the movement of the watch.
Jerry G.
Posted on Sep 15, 2008
escapement
  • 2334 Answers
SOURCE: The second hand of my Tissot watch T870/970 starts and stops.
Yes, pulling out crown prolongs battery life, but this is only for allmost unnoticeable period of time.
With the seconds hand there are only one solution- you have to take your watch to the nearest watchmaker as you will not be able to deal with it without appropriate knowledge and skills.
There can be two reasons why the seconds hand is jumping:
1) Fault within integrated circuit ( watch 'brain' is not giving an impulse in a specific period of time),
2) Few teeth may be damaged on second wheel as well as there can be tiny dirt particles sticking onto it.
Both need attention of professional.
If that seconds hand do not annoy you too much, wait till the watch needs battery replacement and then replace battery and check the watch at once. It will be cheaper then to do both jobs separately.
Posted on Dec 20, 2008
SOURCE: second hand on my watch now goes in 5 second intervals
Check the instruction manual if you have one. Tag-Heuer watches move in 5 second intervals to let you know the battery needs replacing. A neat feature. Now you know that you have a real Tag!
Posted on Jan 17, 2009
escapement
  • 2334 Answers
SOURCE: discolored white nautica watch band
If your watch band have UV sensitive pigmentation in it, there is nothing you can do, but buy the new band.
Find your nearest jeweller and ask to clean watch band in ultrasonic cleaner for 1 hour. If this kind of cleaning doesn't help, that means your watch band is UV sensitive and is and will be discolouring more and more by the time.
Alternatively you can try to clean it with the lighter fluid (ZIPPO). Soak a soft cloth in to lighter fluid and clean the band. Start with a small area inside band to make sure the fluid is not reacting as dissolver, as some resins react quite vigorously and tend to transform into chewing gum sort of state.
And again- if this cleaning doesn't help, the band is UV sensitive and discolouring is taking place.
That discolouring is happening becouse some of the colour pigments used in resin manufacture are sensitive to ultraviolet light and when exposed to sunlight or daylight, they react in a chemical
way, changing molecular structure, wich we see as the colour change.This process can not be reversed and this is why the band can not be cleaned.
Do not forget to rate please.
Posted on Jan 25, 2009
escapement
  • 2334 Answers
SOURCE: Resetting stopwatch dials - Armani AR5331
When you reset the big seconds hand to zero, the hour and the minute hand are not engaged in this function, so, there is no fault with the watch movement.
Do as follows:
1) pull out crown and set the hour and minute hands at 6 o'clock (they must be lined perfectly in opposite directions)
2) push the crown in half way back (not completely)
3) push and hold the button at 2 o'clock (set the big seconds hand to zero) and release it when done
4) when big seconds hand is zeroed push the crown back in
5) pull the crown out again and set desired time
6) push the crown back in.
If all actions described do not work, you will have to visit your nearest watch repair shop and ask to refit chronograph hand as in this case it is out of balance (not pointed at exact mark).
Rate me, please.
Posted on Apr 03, 2009
The hour hand is off. How do I set the hour hand?
If you have a normal three hands + calendar watch - you should pull out the crown two notches out and turn it. Both hands should turn. Now, if your hour hand is off from a marker when your minute hand is on 12 (or 0 minutes) than you would normally need a watch maker. The hands assembly on your watch was done sloppily.
Jun 23, 2016 | Watches
Why is my second hand not moving
THE watch is in stop watch mode (pause) , reset your side mounted post buttons to go to normal time
Sep 16, 2015 | Festina F16190/1 Chronograph Watch for Men
How do I zero the stopwatch hands on my Nautica A 29504 chronograph watch
try www.watchshop.com/mens-nautica-bfc-chronograph-watch-a29504g-p9...
Dec 10, 2014 | Nautica Watches
Citizen AT03060-50E,i bobught online kind cheap than showroom so still am confused that it is original or not.. my chronograph second and minute hand stops after 1 hour,the small chronograph second hand...
The chronograph will only run for 59 minutes 59.95 seconds.
If you do not have a set on instructions for your watch, you can find one on their web site (citizen.com)
When there, click on "technical support" and the on "setting instructions" and fill in the number off the back of your watch.
Feb 01, 2010 | Citizen Eco-Drive BL5184-56L Wrist Watch
Hour and minute hands dont move, second hand does
You better go to a watch service center to replace depected parts ,the problem of your watch is a broken center wheel,need to replace with a new one with identical size and caliber,so its works normal again.
Hope it may help you;
Regards;
VOTIT
Apr 23, 2009 | Watches
Do as follows:
Rate me, please.
Apr 03, 2009 | Watches
HI, i have a gucci watch YA077310 and i dont know how to set it. also the second hand does not work.
To set the time, you normally pull out the crown and rotate it. The main (large) second hand is associated with the chronograph function so is stopped at 12 when no using chronograph. There should be a little second hand in a little round area on dial that is moving.
Jan 26, 2009 | Gucci 7705 Chronograph YA077310 (17736)
Seiko chronograph alarm
Solution #3 (Posted by Guest on 5 Mar 08) is spot on. Quick and easy method to reset the chrono hands (it was not in my Seiko manual).
Interestingly, this can also be used to set the chrono ahead (or behind--with a little math) for offset timing measurements.
Jan 13, 2008 | Seiko SNA553 Alarm Chronograph
Pull the crown to first position (where you set the date) then adjust the dials with buttons.
uhrmacher
Jan 10, 2008 | Giorgio Armani Classic AR5326 Wrist Watch
Analog clock not in sync with digital clock
This problem may be due to your analog hands being improperly zeroed. To find out, try this: 1. Put the watch in chronograph mode by rotating the crowon in its normal position to "chr" 2. Pull out the crown two clicks. This should cause all of the hands to point to zero. If you do this and your minute hand points to 1 o'clock, or five minutes, you will know that this is the problem. If this is the problem, you can can correct it by zeroing the hands as follows: 1. Put the watch in chronograph mode by rotating the crowon in its normal position to "chr" 2. Pull out the crown two clicks. This should cause all of the hands to point to zero, or close to it. You should also notice the letters "HR" in the lefthand digital display. This allows you to move the hour hand by rotating the crown. If the hour hand is not pointing at 12 o'clock, rotate it so that it does. 3. Push the top button once. The letters "MIN" should appear in the lefthand digital display. This allows you to move the minute hand on the large dial, and the minute and hour hands on the small UTC dial. Rotate the crown so that the minute hand points directly to 12 o'clock. 4. Push the top button again. The letters "SEC" should appear in the lefthand digital display. Rotate the crown to point the second hand directly at 12 o'clock. 5. Push the crown back into its normal position. Set the digiatl time and date in your tie zone, and your analog hands should match the digital read-out. If the zeroing of the hands is not the problem, I don't know what is wrong with the watch.
Jan 22, 2007 | Citizen Skyhawk Eco-Drive JR306059F Wrist...
Nautica A16550 Watch for Men Logo
Top Nautica Watches Experts
Jerry Greenberg
Jerry Greenberg
Are you a Nautica Watch Expert? Answer questions, earn points and help others
