Question about Toshiba Satellite P15-S420 Notebook
Power port When I plug the power supply plug into the rear of my notebook, it does not charge. I close the lid and it does charge. That worked for me a good while, but now that doesn't work. I took it to an authorized Toshiba repair facility and they charged me $100.00 for a temporary fix. They soddered something at the power connector. I need to know how to get to the power connector so I can sodder the problem myself or learn what the permanent fix is. Thank you.
  • PRElite Jun 01, 2008
    Thankyou for your response. I know the issue is on the motherboard, but I'm a novice working on computers. I need to know how to disassemble the Toshiba Satellite P-15 S420 Laptop Computer so I can get to the problem. If this is beyond your scope, I'd like to know if there is a disassebly manual for my computer and where I can get one. Thanks.
    Sergeant:
  • 458 Answers
It is on your motherboard. Take it a part and you will see it.
Posted on May 29, 2008
  • T&N Family Electronics Dean and Sherrie Terrell
    You should be able to find a manual on the Toshiba site. Most of them have a break down on how to take it apart. The best thing that I can tell you is below. The only thing to do if you do not have the manual is to find a screw and take them out one by one. There should be a way to pop off the top part above the motherboard. You pry on both sides and it should pop up to get under it. The keyboard should pop up from the bottom. All laptops are not the same. Just be very careful, but if you are not sure that you can do it leave it alone. I could do it because I have done it before. Step by step directions without being there is very hard to do. You rated me as thinks for trying. I can't do the job for you. I did all that I could do from here.
    If you are comfortable with taking it apart you can repair
    it yourself. If you have not ever soldered anything before or taken a
    laptop apart before you need to have someone else do it.
    If you decide to do it yourself you will need the instruction manual to locate
    all of the screws. You will need a soldering iron and a camera along with
    a pencil and paper to draw a diagram and take notes. Laptops have a
    lot of fragile parts in them that will break. Do not do this if you do
    not know how. This is something that a qualified tech should
    do. You will see the plug and you will need to re-solder it
    back onto the board. One wrong move and you could damage the entire
    computer. If you try to do this yourself you are on your own and I am not
    responsible nor is anyone else.
    I helped you the best that I could. Did you check the Toshiba site for the manual. You said that you were a novice. The manual might not give you every detail as to what to take apart. Most companies do not want anyone to have this kind of information.
Acer 2480 2247 won't power up -no lights no nothing, pwr supply is not the problem,lid close switch isn't stuck ,pwr. on switch seems fine and power supply jack on motherboard is not broken
Remove the main battery and the power supply, allow several minutes to get rid of any residual charge, now plug the power supply adapter back in and press power "leave battery out" is there any change? if not! remove power supply, now! press and hold power for 60 seconds to reset the laptop. Next install main battery back in and the power supply adapter, power up! if no change, the motherboard is the problem.
Mar 07, 2011 | Acer TravelMate 2480-2779 Notebook
Batteries are charged, I have checked wire plugs and all are fine, but I have no power at the on-off control. Is there a fuse block, a circuit breaker, or a reset button unseen under the rear lid?
Jerry to make sure you don't have power to the joystick get a digital voltmeter set it to 200 volts dc and plug the leads into the two outter holes of the charger port under the front of the joystick. Fully charged you should read 25-27 volts If you are getting a good voltage then the problem could be in the on/off switch on the joystick. There is a fuse located under the rear shroud somewhere near the power module in line with the cable coming from the on-board charger. If your voltage is real low then you have battery or charger problem. If you plug the charger in and keeping the meter plugged into the charger port you should read 27-34 volts indicating the charger is working and the problem could be the batteries. Try turning the on/off switch on with the charger plugged in the power should come on and flash indicating charge inhibit is working. If you still get nothing check your cable coming from the rear of the chair make sure its fully seated in the plug. Thats all I've got Hope this helps
Nov 15, 2010 | Pride Jazzy 1103 Ultra Standard Power...
Have compac persario m2000. The power supply will
the issue might be with the power jack . i mean the port where you insert the charger.. to fix this issue your laptop needs to be repaired.
Jun 14, 2010 | Compaq Presario M2000 Notebook
Laptop went into sleep mode and will not turn back on
Try a Hard Reset, follow the steps below:
1) Unplug the AC Adapter from the notebook PC and remove from any port replicator or docking station.
2) Remove the battery from the notebook battery compartment
3) Press and hold the power button for about 20 seconds
NOTE: Holding down the power button while the computer is turned off drains any residual charge in the capacitors
4) Insert battery and plug the AC Adapter back into the notebook PC.
5) Press the power button to turn the notebook PC back on.
Dec 28, 2009 | HP G60-120US Laptop
Ok i have a HP Compaq Presario CQ60 Notebook PC AMD Athlon Dual-Core QL-62 2.00GHz 64 bit. So yesterday 9/23/09 i plugged my laptop into charge shortly later my screen went black. I closed the lid opened...
this might be some problem with ur power settings for ur laptop...
Better change it to default in order to reset every power settings..
Go to control Panel,
Go to Power Options,
Now Select the power scheme as ALWAYS ON
Then apply it & click ok..
Its done..
This wud be simple power scheme problem that generally comes...
Hope this works u out...
Sep 24, 2009 | HP Computers & Internet
Easynote r1004 wont power on
The battery is too low and the power supply can't charge the battery and also power the laptop at the same time.
Try this:
1. Remove the battery from the laptop
2. Plug in the power cord and turn ON the laptop.
3. It should work ok.
4. After the laptop is "stable" (what 5 minutes?), you can put the battery back into the laptop while it is ON.
5. Leave the laptop ON so the battery can get charged.
6. Lower / close the lid so that the screen will turn OFFand not take up power from recharging the battery.
If this doesn't work for you, try these steps again, maybe wait a few minutes between steps.
This WILL work!
Hope this helps!
Sep 03, 2009 | Toshiba A15-S1292 Notebook
My power cord not charging battery
you may have damaged the power input port.
broken solder joint. or your power supply took a dive. if you have a DMM 'meter' check the power supply to see if you are getting power from it.
if it is the power input port, you will have to either open up the laptop and see if it is a fixable soldering job or take it to a pro.
Happy Fixing =)
Jul 11, 2009 | Dell Inspiron 6000 Notebook
Crash when re-connected to power supply
Go into msconfig and disable all your programs then let the notebook reboot. After it reboots and goes back into windows. Try to unplug it and plug it back in and see if it does the same thing, if so then you might need to wipe out the drive and start over fresh. If it doesn't crash on you after disable the programs and unplug and replug then you have some software that isn't interfering with the power options that controls windows.
Aug 13, 2008 | Acer Aspire 5002WLMi Notebook
Toshiba Satellite P15-S420 Notebook Logo
65 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
