Question about Frigidaire 22.6 Cu. Ft. Counter Depth Side-by-Side Refrigerator - Stainless-Steel
The fridge side is not cooling now at 60 degrees. The freezer side works and the fan is on. I cant feel any cool air coming from vent on fridge side. Are there two fans?
  • 121 Answers
Check to see if your evaporator fan is running on fridge side
Posted on Nov 01, 2010
GE Profile Refridgerator side warm, freezer ok?
Fridge gets cold air from freezer to cool it. Your freezer is fine but not enough cold air is getting into fridge compartment. U have some dampers or louvers that direct air flow to fridge and if they are not set properly cooling will not be adequate. Check those out.
Sep 19, 2017 | GE Profile CustomStyle PCF23NGT Side by...
Fridge won't cool below 60, freezer won't go above 20
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Aug 08, 2011 | Refrigerators
MY JENN-AIR REFRIGERATOR #JCD2389GES IS NOT COOLING ON THE REFRIGERATOR SIDE. THE FREEZER IS OKAY. THE REFRIGERATOR TEMPERTURE IS 60 DEGREES F.
Possible that the vent is getting blocked to prevent the cool air to be blown into the fridge section. So make sure that the auto defrost is working, if not check the auto defrost timer section, the fan, the heaters.
make sure that the thermostat is set to normal.
Finally shut off the fridge for 6-8 hours and see if the cooling resumes. If so the defrost section must be revisited
Oct 30, 2010 | Jenn-Air JCD2389G Side by Side...
My GE Bottom Freezer Refrigerator Model:PFS22SBSSS The Refrigerator is not cooling, however the Freezer is mantianing proper temprature at 0 degrees. The temp on the fridge is reading 60 degrees on the...
Your problem is almost surely caused by the failure of the fan that should circulate cooled air from the freezer section to the refrigerator. If you check for vents, normally in the rear of the fridge, and hold your fingers in front of them while you hear the compressor running, you should easily feel cold air coming from them if the fan is running.
To determine whether you want to have it serviced or replace the fan yourself, try entering your model number on the Sears PartsDirect website to see if your unit is one of thousands of non-Sears appliances in their library. If they do, then you will find an illustrated parts drawing with part numbers.
Sears PartsDirect
Sep 06, 2010 | GE PFS22SBSSS Stainless Steel French Door...
My freezer is working fine but by refrigerator is not working. how can that be with a maytag side by side?
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Sep 21, 2009 | Refrigerators
Maytag RSW24EO refrigerator not cooling
Sep 14, 2009 | Refrigerators
Amana 'side by side not freezing slightly cool
sounds like you have a restriction in your filter drier. or you could be low on freon. both sealed system issues. you need an appliance tech to check your cooling system
Apr 12, 2009 | Amana ARS2464B Side by Side Refrigerator
Refrigerator part not cooling, freezer is fine Amana TXI18JW (top freezer model) I noticed in the last week or so that my refrigerator was slowly starting to warm up, so I started to turn the dial up on...
There is a vent that is connected from the freezer down to the fridge right where the fan is,make sure nothing is blocking it.
Hope this helped.Let me know by rating me or
for more help go to live chat.Thanks
Len West
Feb 27, 2009 | Amana ARSE66MB Side by Side Refrigerator
Frigidaire 22.6 Cu. Ft. Counter Depth Side-by-Side Refrigerator - Stainless-Steel Logo
145 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
