Question about Xerox DocuColor 12 Printer
Xerox docucolor 12 i have a problem with my cyan color, i print the cyan color it comes out green
    Champion:
  • 241 Answers
Check your toner is it mixed with yellow
otherwise
do the calibration
Posted on Oct 05, 2010
Docucolor 12
check scanner unit which hit the opc drum, may be hide by something
Dec 27, 2013 | Xerox DocuColor 12 Color Copier
Instead of Bule print DC12 prints Violet
Hi there! The blue color is becoming violet because the Cyan and the Magenta toners are not getting mixed in the proper 100:100 ratio (100% Magenta and 100% Cyan make CMYK Blue). Since the print is violet, the culprit is the Cyan toner. Now, first, get the Cyan Developer Assy checked if there is enough developer in it. If no, get it refilled by a proper tech and manually mix about 50 grams of the Cyan Toner with the developer. Also get the tech to check the trimmer gap on the Developer Assy with a metering gauge. If yes, next check the Cyan dispenser motor located on the backside of the Toner Housing Assy. It is probably broken and not dispensing any toner to the Cyan Developer Assy . Additionally, check for the Cyan Dispenser Auger blockage or jam. It is located under the Cyan Toner Cartridge in the Toner Housing Assy and also check the auger under the Cyan Developer Assy. After sorting these out, you should get proper CMYK blue from the 10th or 12th page once you resume printing.Let me know. Regards
May 26, 2011 | Xerox DocuColor 12 Color Copier
Docucolor 12 low density
cambia reveladores y reza un padrenuestro
Oct 31, 2009 | Xerox DocuColor 12 Color Copier
XEROX Docucolor 12 Color Developer PN needed HELP
DEVELOPERS:black 5R616 ; yellow 5R 619 ;magenta 5R 618;cyan 5R617
TONER : magenta 6R1051 ; cyan 6R1050 ;yellow 6R1052
Sep 14, 2009 | Xerox DocuColor 12 Color Copier
Prints aren't plain, it have some texture like crayon
its problem of toner
its of good quality
and also check proper supply of toner into develper assembly
trying to add some extra ink directly in developer assembly
if problem solve
check
cartridge motor running
and supplying toner proeprly
May 24, 2009 | Xerox DocuColor 12 Color Copier
Docucolor 12 no print
if its a print from system to machine do the following
1: check the cables from fiery to machine
2: press clear server in the fiery menu
its not ok
next time mention fiery model
Jan 16, 2009 | Xerox DocuColor 12 Color Copier
Shades on Prints
run the alignment program
Nov 18, 2008 | Xerox DocuColor 12 Printer
Xerox Docucolor 12 : Four colors ( CMYK) dots printed each time on paper on 3 separate area
Your Problem is the cartridge printer Mx, In spanish algun balero de las developers units esta dañado pudiera estar golpeando el cilindro de imagen
Nov 03, 2008 | Xerox DocuColor 12 Printer
Cyan Toner always prints faded.
It is the developer. All colours should be changed at the same time. This can be accessed via the right hand side of the machine, when you remove the cover. (where the output tray is)
Feb 06, 2008 | Xerox DocuColor 12 Color Copier
DC12 prints with no yellow toner
Sounds to me like the yellow developer housing has failed.
Either replace the housing or call for service for them to do that.
Dec 14, 2007 | Xerox DocuColor 12 Color Copier
Xerox DocuColor 12 Printer Logo
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
