Question about Gestetner AO45 Copier
Blotching of ink on many parts of the plotted drawing
  • jimbdzn Oct 04, 2010
    Can you tell me how to clean out the unit? What unit are you speaking of?
    Can you tell me were the ink storage unit is?
  • 2,272 Answers
This happens when the waste toner is overflowing from wastage section. This overflow wastage toner spills on the paper and creates blotches.its a very common issue.
To solve the issue the wastage needs to be emptied and the unit should be cleaned and reinstalled safely.
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Posted on Oct 04, 2010
  • raj somaiya
    raj somaiya Oct 04, 2010
    Waste storage is just fixed below the drum assembly.
    The drum assembly and wastage are screwed together so one has to remove both together then gently unscrew the wastage part and empty it then clean and re-fix it properly.
    Also do forget to clean all metal contacts on the sides of the unit.
Streaking on photo plots on a 1050c
Streaks can come from several sources. Since you said they appear near the end of a plot, the print heads may be running out of ink before the end of the job. This would happen if you had air in the ink tube system and consequently in the heads. When the printer is idle for a while, ink will migrate to the bottom of the print head so when you print again it is ok for the first part of the plot and then gets to the air bubble.
Open the back door of the plotter and look for air bubbles in the ink supply lines. If air is present, it needs to come out. There is a purging tool at Designjet Ink Tube Priming Tool . The print heads may need to be replaced, but not before the tube system is clean.
May 25, 2012 | HP DesignJet 1050c plus InkJet Printer
Whenever i try the graph on my TI-83 Plus the ERR:INVALID DIM 1:QUIT comes up and ive checked the STAT PLOT and i have Plot 1 set as ON.
You have to turn all statistical plots OFF before you draw function graphs. Press [2nd][Y=] to open the statistical plot configuration screen. Press [4:PlotsOFF] and then [ENTER]. When calculator answers DONE you are ready to draw function plots.
Sep 09, 2010 | Texas Instruments TI-83 Plus Calculator
When i plug in an equation in my calculator, for the y = when i press graph it says there is an error and it won't graph
Before drawing Y= , polar, param ans seq graphs deactivate the statistical plots.
Press [2nd][Y=] (STAT PLOT)
Select [4:PlotsOff]
Press [ENTER]
The statistical plots will be deactived and you will be able to draw regular graphs. Then try Y1=X.
Jan 19, 2010 | Texas Instruments TI-83 Plus Calculator
HP DesignJet 1050c InkJet plotting issue
Friends,
You doesn't say what application and OS versions you have, or if the printer is shared from a server or connected locally to a workstation. This is signifcant to solve the problem. Please clarify.
To make this work properly, all machines should have the HPGL driver and all drivers should have both the "Autorotate" "Inked Area" boxes ticked - both under General > Printing Preferences > Advanced AND under Advanced > Printing Defaults > Advanced.
Then you should create a paper size that is as wide as the media is wide, and longer than the longest/widest paper size you're ever going to print (6-10 feet long is OK!) - BOTH under Printing Preferences AND under Printing Defaults. This will ensure that every "odd" paper size (within media width limits) is printed without problems.
If the printer is installed on a server and shared, these settings should be done on the server - and the driver should be reinstalled on the workstations. If not, these chanvges should be done on each workstation that has access to the printer over the network.
When using older versions of AutoCAD you might have to reinstall the printer there as well for the changes to take effect.
Note: This solution has worked successfully over several years while working at HP support. The suggestion about the looong paper size may sound strange but it works!
//Al
Feb 10, 2009 | HP DesignJet 1050c InkJet Printer
Getting a DIM:MISMATCH when i want to draw a graphic, tmmrw exam
You're probably trying to graph a function that does not involve stat plot features. You can correct this by turning off the stat plot features. Press "2ND" "STAT PLOT" and then select 4:PlotsOff.
Dec 07, 2008 | Texas Instruments TI-83 Plus Calculator
Incomplete plot from .pdf file - Hp DesignJet 1050C Plus
Was the plot originally done on a size D or E plotter.. A .pdf is generally not a good way to send a plot that has to be done to scale.. Can they re-send the plot in a hpgl format, or a format that you can use in another program, liks ACAD, and then print it through that program? This would provide you with some control, that a pdf document will not allow.
This is just a stab in the dark for me, but I am familiar with plotters in general, just not the many formats to print from..
Nov 19, 2008 | HP DesignJet 1050c plus InkJet Printer
Gestetner AO45 Copier Logo
46 people viewed this question
Top Gestetner Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
CheckitRight
CheckitRight
Are you a Gestetner Office Equipment and Supply Expert? Answer questions, earn points and help others
