Question about Admiral 26 cu. ft. Side-By-Side Refrigerator
Admiral Refrigerator/Side by Side
I have a 26 cubic inch refrig/freezer that is just under 3 years old. The problem is that it starts to make a loud humming sound, will not shut off, and then begins to thaw out. If I unplug it for 4 to 6 hours and plug it back in it works fine for 2 to 3 days and then repeats the same process. Can anyone help?
  • twtx Jun 28, 2008
    i have the same problem it keeps defrosting then works fine after being switched off and on,then it makes a humming sound and then a clicking sound and goes quiet.i have had an engineer round witch cost me £150 and replaced the defrost element and now it is still not working! he now thinks its the compressor and it will cost around £500! help please
    Genius:
  • 1,073 Answers
Compressor or sealed system issue compressor is failing or a problem in the sealed syetem is putting a back pressure onto the comperssor causing the compressor to eventualy kick of on the internal overload in the compressor, cools down as you unplug the unit allowing the compressor to cool down resets the internal overload runs and repeats the process
have the unit checed by a quilified tech in ref sealed system repair
Posted on May 28, 2008
Refrigerator does not cool below 50. Freezer side is ok
all cooling comes from thefreezer, lower down air flow to freezer and increase air flow to refrigerator, this should help.
Apr 08, 2011 | Admiral 26 cu. ft. Side-By-Side...
Side by side Admiral freezer freezes but fridge
check the damper vent door between the refrige and freezer and make sure its opening up to let cold air from freezer into the refrige,sometimes they freeze up and cant open and close when called upon to do so,if so deice it with a hair dryer,the side being hot is good telling you the compressor is operating correctly
Jul 28, 2010 | Admiral 26 cu. ft. Side-By-Side...
Cold but not frozen
23 years old ? That thing was costing you more than a new unit would cost for the past 5 years!
Assuming your airflows are good, Its time for a new refrigerator.
Aug 29, 2009 | Refrigerators
Fridge not cooling on either side of side by side. Approximately 10 years old, its an Admiral.
is there frost in the back of the freezer? fans running? tell me anything you can tell me about the ref.... model number would help
Jun 23, 2009 | Admiral 26 cu. ft. Side-By-Side...
Moved refrig this morning and now it is not cooling... freezer works great
Hih, Check and see if something has stopped the condenser fan motor down by the compressor from turning. Sometimes this happens in a move.
Also make sure the controls didn't get turned to wrong settings. Make sure evaporator fan motor is working in freezer and that there is no frost building up on the rear panel.
Just some ideas to help you.
lease let me know if I can assist you further.
Thanks
Vic
May 30, 2009 | Admiral 26 cu. ft. Side-By-Side...
Admiral side by side refrigerator won't stay cold.
change the defrost thermostart or check door(ajar) or damper control
Mar 26, 2009 | Admiral 26 cu. ft. Side-By-Side...
Admiral side by side fridge defrosted and no longer cooling
Replace the compressor start relay.
If this does not solve the problem you most likely have a bad compressor.
Your fridge may be under a 5 year compressor warranty.
Feb 21, 2009 | Admiral 26 cu. ft. Side-By-Side...
Admiral refrig
thats the fan hitting ice. sounds like a defrost problem. does the back of the freezer panel have any frosty ice build up?
Aug 18, 2008 | Maytag MZD2766GES Side by Side...
Wards/Admiral refrig/freezer
I put the fridge in manual defrost by advancing the timer. The defrost heater worked so the problem was with the timer not advancing to defrost every 6 hours. The plastic gears wear out over time.
Apr 18, 2008 | Admiral 26 cu. ft. Side-By-Side...
Admiral 26 cu. ft. Side-By-Side Refrigerator Logo
235 people viewed this question
Top Admiral Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you an Admiral Refrigerator Expert? Answer questions, earn points and help others
