Question about Husqvarna Forest & Garden #952802239 235E 16" Gas Chain Saw
I have a Husqvarna 41 model chainsaw. It starts fine and runs, however as soon as I let go of the gas it dies. It seems like it is not getting enough gas. Any suggestions?
  • 784 Answers
Check crankshaft sealings. if between cilinder and carburator isnt air leak than is that so how you had described it.
Posted on Mar 18, 2011
Starts but stalls when hot. Chain is not too tight
Larry,Carburetor may be dirty, remove and clean or rebuild. Check the attached links,videos,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Husqvarna Chainsaw 235Troubleshooting Repair Help
How to Troubleshoot Husqvarna Chainsaw Problems eHow
Husqvarna 136 Chainsaw Carburetor Rebuild Fuel Line Repair
http://www.mymowerparts.com/pdf/Husqvarna-Service-Repair-Manuals/W9200002.pdf
Apr 19, 2016 | Husqvarna Chain Saw Models 51, 55
455 rancher runs with chock out 15 second and dies
Try opening the choke half way as soon as it starts then all the way open in a few seconds... It only needs the choke to start and should run fine in less than a minute after idleing with the choke not engaged...
Jun 15, 2014 | Husqvarna , No.455 Rancher, 20" Gas -...
My Husqvarna 41 will run fine for a while (up to 3 tank fulls of gas) then other times it will start and run but then bog down like under a load (but I just holding it and not cutting anything. Other...
Does this describe your problem.? 'Engine does not deliver full power or runs erratically'
Possible faults - Muffler carbonized, Piston rings leaking or broken, Secondary air seepage through leaking gaskets on carburetor spacer flange / poorly mounted or faulty manifold.
Aug 04, 2013 | Husqvarna Garden
Husqvarna model 41
Try changing the spark plug. Maybe it is bad and does not have enough spark . You may also want to check if the carburetor is getting gas . It seems that it probably is not . By the fact that you have to spray stating fluid. Check the hoses, filters, and the choke. Remove and clean the fuel filter and air filter . And by all means , check the ignition switch. That it is on and working .
Dec 19, 2011 | Husqvarna Garden
Husqvarna 51 idle seems to struggle, runs OK when I throttle then chokes and dies out as soon as the throttle is released. What can I do?
will it start right back up after it dies? you could use a small screwdriver and turn the idle screw in a little to raise the idle speed that should fix it.
Oct 09, 2010 | Husqvarna , No.455 Rancher, 20" Gas -...
I have a husky 455 rancher.never had a problem till today, worked fine this morning, now it iwll start but as soon as i put it under load it dies, cannot even rev the engine, it idles ok, but once i open...
When this has happened to me, it turned out to be a hole or crack in the fuel line. At the higher revs, more fuel is needed. The added "suction" for the higher demand pulls air into the line and the unit does not have enough fuel to run. Check for that first and also the fuel filter inside the tank. The filter might be clogged as well.
Keep us posted,
Dan
May 11, 2010 | Husqvarna , No.455 Rancher, 20" Gas -...
Chainsaw runs but when I start cutting it dies
you might just neet to clean the air filter and/or the carb.
Oct 06, 2009 | Husqvarna Craftsman 36cc, 16 In. Gas Chain...
Husky 455 dies out at full throttle or under load
Your carb may be the issue but your ignition coil could be the culprit. Once they start going bad, they can act up intermittently or give various symptoms from day to day. The fact that your saw dies at full load or under load, probably means that when your saw gets hot or requires more spark, your coil is not able to provide it. Your carb is easy enough to clean out, you can take it all apart and clean all screens, etc....
I just replaced my coil due to the exact same symptoms and now my saw runs great. $60 off ebay and you can put it on in 15 minutes yourself. Check your carb first though
Apr 13, 2009 | Husqvarna , No.455 Rancher, 20" Gas -...
Husqvarna Forest & Garden #952802239 235E 16" Gas Chain Saw Logo
285 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
