Question about Intermatic Inc. ML121RT Malibu Low Voltage 121-Watt Power Pack with Timer
The timer will not turn on its a malibu - Intermatic Inc. ML121RT Malibu Low Voltage 121-Watt Power Pack with Timer
  • Anonymous Oct 04, 2010
    all lights will not turn on
I have a Malibu 300 watt ML300rtw, timer goes until it reaches "on" pin then stops. if i manually turn timer, i hear click and lights go on - they turn off no problem. pins are not broken. what next?
Sounds like the mechanical timer assembly likely has never been lubricated, You may use a lightweight oil, such as WD-40, to lubricate the timer mechanism.
May 09, 2015 | Malibu ML300RTW - Low Voltage Power Pack...
Part of a malibu light timer runs but the timer dial does not turn to turn lights on/off
Clock motor has stopped working... there is not replacement module.
Plug power pack into wall timer.
Following link has troubleshoot, warranty, and installation tips to avoid problems:
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html#troubleshoot
Gene
Water Heater Timers Save Money
Mar 22, 2015 | Malibu Hardware & Accessories
My malibu timer seems to get stuck before turning itself on. It take 1 hour to trip the timer to come on?
1) Clock motor is worn out, or gears are dirty:
2) Take apart clock motor and add white grease to gears
Set override to ON, and plug timer into cheap wall timer.
Take advantage of 5-year warranty.
Mar 10, 2013 | Malibu ML300RTW - Low Voltage Power Pack...
Malibu timer motor won't turn on, but it turns off ok. I want to replace the timer unit, where can i get one
The timer module is not sold separately.
Malibu has 5-year limited warranty against defects in workmanship.
If the transformer still works, then plug unit into cheap wall timer.
If the timer dial still keeps good timer, then order trippers.
Copy following link for manuals, tips, replacement tripper numbers and general troubleshoot:
Aug 15, 2012 | Malibu ML300RTW - Low Voltage Power Pack...
Timer on my 200W transformer is working but lights will not turn on manually or by timer. when i turn on with manual switch they flash on for a second then turn off. i am just under 200W for total...
You posted under Intermatic-malibu power packs.
Wattage of bulbs must match wattage of power pack or bulbs and power pack will burn out.
Your power pack might be damaged beyond repair.
For information on Intermatic/Malibu power packs showing troubleshoot steps, replacement trippers, useful links, warranties and tips:
Aug 23, 2010 | Malibu ML200RT - Low Voltage Power Pack...
The timer wheel turns counter clockwise how can I fix
There are no replacement clock motors.
Improvise by setting timer to override and plug power into cheap plug-in timer.
Jun 24, 2010 | Malibu ML200RT - Low Voltage Power Pack...
Clock does not work,manual operation turns light on
Improvise by setting timer to override and plug power pack into cheap plug-in timer.
Jul 11, 2010 | Malibu ML200RT - Low Voltage Power Pack...
Malibu 600 watt transformer timer not working. Can turn on and off w/ the switch but the timer isn't functioning.
The timer motor is probably bad. Unfortunately, Malibu transformers have very few user servicable parts :-( , and the timer motor isn't one of them. One cannot even access the internal connections. If you recently purchased the transformer, return it to the store. If the transformer is less than 5 years old, it's still under warranty. In that case visit the Malibu website for instuctions.
Oct 31, 2009 | Malibu Intermatic Inc. ML121RT Low...
My Malibu ML600TW power pack is stuck in the ''on'' position
There are no repair parts for intermatic/malibu power packs.
You can buy cheap plug-in timer, and plug power pack into cheap timer.
For more information on Intermatic/Malibu power packs showing troubleshoot steps, replacement trippers, useful links, warranties and tips:
Oct 20, 2009 | Intermatic Malibu 300W Power Pack...
I have a Malibu 600 watts low voltage transformer that works only for 30 minutes and then, will turn on again for another 1 hr. I only want to turn on one time but for 4hrs. I already removed one red and...
If problem timer malfunction, then set power pack to override, buy cheap plug-in timer, and plug power pack into cheap timer.
If problem is internal wiring, then replacement is option.
Sep 01, 2009 | Intermatic Malibu 300W Power Pack...
Intermatic Inc. ML121RT Malibu Low Voltage 121-Watt Power Pack with Timer Logo
Top Intermatic Hardware & Accessories Experts
Gene Haynes
Jay Finke
Jay Finke
Hippy_dd
Are you an Intermatic Hardware and Accessory Expert? Answer questions, earn points and help others
