Question about HP LaserJet 1600 Printer
HP 1600 laser jet printer, says that there is a paper jam, however it was cleared and still says there is a paper jam. Help!
  • 4 more comments
  • bob8667 Oct 04, 2010
    how do you unplug from power source, then turn on while unplugged? how does it turn on?
    Have a paper jam on an HP1600 laserjet printer, but have already removed the paper. The system claims the jam still exists.
    Have unplugged to hopefully reset, but that didn't work.
    thanks,
    Didn't work!
    Any other ideas?
    Thanks,
    that was the second thing I did will all the cartridges, have not gotten a msg. that ink was low, cartridges are not that old.
    I suppose all my hot air won't suffice, but I don't have any canned air. There doesn't appear to any be debris and got all of the paper out that caused this situation. Would a hair dryer work?
    thanks anyway, but no cigar
  • HP Master
  • 4,737 Answers
This is another very common issue. Sometimes this can happen even if there's no actual paper jam, in that case, you need to reset the printer. It could be because the sensor/s is/are stuck or it could be some mechanical problem or it could be electrostatic issue.
First try to understand the flow and path of the paper, First remove all the cartridges, fuser unit, unplug the usb cable and the drum (make sure that the power cord is unplugged), also, pull out the paper tray. Now reseat all the chips on the cartridges and on the drum. Check the fuser very carefully and make sure nothing is obstructing inside. Look inside the paper passage and the inner compartment, if possible use a blower or an air can to blow through the passage so that nothing is actually blocking the path.
Tap the power button several times while it's still Off..
You can refer the path of the paper and jamming areas here (click here)
Clean all the components and supplies.
After you are done with the cleaning and the chips, power on the machine without all the components installed. Leave it ON for few minutes. Tap the cancel button several times while it's still On.
Now turn it Off and again turn back On and press down the Cancel button while it boots up. You'll see all the leds blinking, ignore them this time.
Again, take a thicker (photo paper or chart paper) or a bunch of regular paper and push inside the passage from the front, do this a few times.
Again turn Off, install the fuser unit and turn back On. Now install the drum and the cartridges, press the Cancel button everytime you install the components. Do all these slowly as far as possible. This will help you fix your issue if there's no internal-mechanical problem.
This might take sometime, but this is the best troubleshooting measure with the Paper Jam persistent error.
If all of the above doesn't fix, call hp or a local tech and get their help. The machine will need to be disassembled and check all the sensors and passages.
I wish you good luck.
Thanks for using FixYa.
Posted on Oct 05, 2010
    President:
  • 1,768 Answers
1. Turn printer off for 30 seconds. Then power on again.
Clear all documents in the print queue.
2. power cycle the PC >> That is power down the wait then power on again.
3. check the printer set up page in the hardware/ printer section of Windows and see if you have it set to your printer.
4. If so, then try a test print with a word processor and or the the test print feature for your model printer.
Posted on Oct 04, 2010
  • 2 more comments
  • Harleen Nash Oct 04, 2010
    answer is above / Please inform if you have tried the steps.
    try removing the ink cartridge and replacing them back into their slots.
    check for ink depletion.
    check for debris in the paper path. if you can use canned air to blow out any debris in the paper path
    try the vacuum cleaner blower but be careful of too much force it may blow springs or other part out their place. If this doesn't work then I believe calling/ contacting tech support for your printer . There may be a faulty micro switch/ sensor that is damaged.
    President:
  • 4,070 Answers
Hi! Alright please try this. Unplug the unit from power source and turn on the printer for 10secs. while unplugged. This should reset the system and will get your unit back to its normal working condition. Plug the unit to power source, turn it on and see how it goes. Hope this helps and thank you for using FixYa!
Printer show paper jamed without paper in it
There's a small piece of paper on the sensor. 4 in 1 Cleaning Paper for Laser Ink Jet Printers 12 Pack Perfect Data PD... You need paper path cleaning sheets like tho ones here. That should clear the jammed condition.
Aug 12, 2016 | hp deskjet 3600 series
My HP color Laser Jet 2600 printer has a paper jam
Jul 21, 2014 | HP Office Equipment & Supplies
Printer won't print after clearing a paper jam
I use to have an HP All-In-One Laser Jet printer that, for reasons unknown to me, wouldn't print after clearing a paper jam until I replaced the ink cartridge.
Jan 13, 2013 | Canon IMAGECLASS MF-6530 Multifunction...
Hp laser jet 5025 paper jam
Clear the paper jam...
Also make sure all the pick up rollers are not smooth, if they are replace them. Also make sure the tray is set to the right paper and not offset. A lot of times people slam the tray and it moves the setting bar.
Jul 09, 2012 | HP LaserJet M5025 Printer
Paper is jammed in my printer - HP Laser jet 3055 --- cannot seem to clear -- don't know how to get at the jam.....can you tell me how to lift the area where the jam is?????
The panel on the back of the printer should pop out and you can get to the paper jam throught there. Make sure you get all the peices out cuz sometimes all it takes it one very small piece of paper to make it not work.
Aug 26, 2011 | HP LaserJet 3055 All-In-One Printer
Laser jet 1600 printer high pitched squeal
It proberly has dust in the printer near the spool (the picture below)
Sep 11, 2009 | HP Hewlett Packard LaserJet 1600 Printer
I'm getting paper jams on the duplex whats the
chek inside printer for pieces of paper or something...try to clear paper feeders...Good luck
Aug 14, 2009 | HP LaserJet 1320 Printer
Paper out jam in hp laserjet 1020
Please visit this below mentioned link to troubleshoot your printer problem.
HP LaserJet 1020 Series Printers - Clearing Paper Jams
Thank You
Oct 20, 2008 | HP LaserJet 1020 Printer
HP LaserJet 1600 Printer Logo
154 people viewed this question
Seeker5211
Seeker5211
