Question about Canon PowerShot A710 IS Digital Camera
Can not use use arrows to connect to menu or any thing ? /?
    Novelist:
  • 178 Answers
An internal sensor might be having a problem causing the LCD screen not to respond correctly. or the menu button has been forced and is stuck causing internal conflict not allowing you to switch between functions.
Check out immediate online quote at Teleplan Camera Repair. They are very good and will hone in on the problem very quickly!
Posted on Oct 04, 2010
Print command appears to being received, but printing is not occurring
Perform Tap 41 PRINTHEAD Health Diagnostics Test, along with supporting service level/diagnostic tests (service menu access procedures do vary by HP printer model, refer to HP printer diagnostics document, pages 45-47, to view normal display messages, http://inkjet411.com/?page_id=1813 )
Tap 41 PRINTHEAD Health Diagnostics (NOTE: applies to touchscreen printer models only):
1.Press 'Return' button (lower left side) four (4) times until 'Support' menu is displayed.
2.At 'Support' Menu, using the arrow key, navigate to the 'Service Menu', press Ok.
3.Use arrow keys to advance to the 'Special Reports' Menu. Select OK.
4.Use arrow keys to advance to the 'print mech button tap' menu. Select Ok.
5.'code = 0' will be displayed. Use arrows keys to change value to '41' (i.e. press and hold right arrow key).
6.When 'Code = 41', select 'OK'. The diagnostic test pattern will print.
7.Check the 4th line at the top of the printed report; an electrically good/stable PRINTHEAD will state "Pen Status: Pen OK".........if any other message is displayed then the PRINTHEAD may have failed and may need to be replaced. Re-seat PRINTHEAD and/or clean rear electrical contacts and repeat 'Tap 41' test to verify connectivity is not the issue.
Nozzle test (use to determine if all ink cartridge nozzles/printhead is firing all colors properly)
Press return arrow 4 times
2.Press support menu
3.Press right arrow 5 times to print diagnostic menu and press ok
4.At nozzle test press ok
Self test/printer status (use to print internal printer settings)
3.Press right hand arrow 7 times to reports menu and press ok
4.At self test report press ok
Extended self test (use to evaluate color performance and obtain total page count)
4.Press right hand arrow 1 time to extended self-test and press ok
Print Quality Diagnostic Page (use to determine if printing alignment is correct)
4.Press right hand arrow 2 times to Print Quality diagnostic report and press ok
Print head recovery (runs 'intensive' printhead service cleaning routines, i.e. for a clogged printhead)
1.Press home key twice
2.Then return key
3.Then home key twice
4.Then return key
5.Then home key twice...............this will gain access to the Engineering Menu
6.Press the 'service menu'
7.Press right arrow 4 times to 'service test' and press ok
8.Press right arrow:
a.16 times to 'print head rec level 1' (basic recovery)
b.17 times to 'print head rec level 2' (medium recovery)
c.18 times to 'print head rec level 3' (thorough recovery)....suggested for severe streaking
9.Press 'ok' to activate either of the 3 selections above.
Semi full reset (can be used to help address intermittent or incorrect printer behavior issues)
1.Press return arrow 4 times
3.Press right hand arrow 2 times to Resets menu and press ok
4.Press right hand arrow 2 times to semi full reset and press ok (Note: this will return printer to factory default condition; regional setup will be required following this action)
* Failure of the PRINTHEAD has nothing to do with refilled ink cartridges; the PRINTHEAD assembly is a separate electronic unit in which the cartridges plug into and feed ink into. Refer to NOTE below.
4) To rule out printer/cartridge connectivity (assembly interface/connection) issues please ensure you have followed all steps on HP's support page - this includes PRINTHEAD removal and thorough cleaning of the electrical surfaces on the PRINTHEAD and on the CARRIAGE ASSEMBLY:
http://www8.hp.com/h22157/video-gallery/us/en/customer-care/printers-and-all-in-ones/replace-ink-and-toner/2286857593001/replacing-the-printhead---hp-officejet-pro-8600-e-all-in-one-printer/video/
Apr 07, 2015 | HP LaserJet Office Equipment & Supplies
HP Calibration Error
    For HP Officejet 6600 / 6700 printer models which suffer a calibration error, more than likely either the PRINTHEAD has connectivity issues (i.e. remove, clean all contact points, and reinstall), compatible/clone ink cartridge chips are causing the issue, the PRINTHEAD is approaching end of life, or not all ink nozzles are firing and therefore the printer is unable to calibration. Perform the following diagnostic checks to help make a determination:
    Tap 41 PRINTHEAD Health Diagnostics (NOTE: applies to touchscreen 6600/6700/8600/8700 printer models only):
        2.Then return key
        4.Then return key
          For more information on inkjet printer recovery tips, or solutions for a different printer model, please visit http://www.inkjet411.com
          -Thank you
Nov 22, 2013 | HP OfficeJet Office Equipment & Supplies
Hi... I have a Kogan Agora Smart TV,... the date and year are wrong and I do not know how to change it. Thanks if you can help.
What is the model number on the back of your TV? It should look something like this KALED42SMTWA or KALED423DSMTZA. However, try the following instructions first, if they don't work I will need the exact model to give more specifics.
  1. On the remote with the TV turned on and connected to the internet then Press MENU button to display the OSD menu.
  2. Use left/right arrow buttons to select the main menu(I think the time should be 4th right from the top so that's 4 right arrows), and press down arrow button to enter the submenu.
  3. Check the time zone option first, make sure this is correct. You should be able to change the time in this mode, if you can't then it gets the time from the internet and the only thing you can change is the time zone and this should fix it as it will auto update the time from the net on its own.
  4. Press MENU button again to return to the main menu then press EXIT button.
I hope this helps..
Sep 07, 2013 | Televison & Video
Got rid of cable, how do I change from set channel 3 to open channel choices.
To perform Auto Program again
1 Press menu
2 Press right arrow to highlight Channel Setup Menu.
3 Press down arrow to highlight Cable. Press + to select.
4 Press up arrow or down arrow to select On or Off according to how you connected your TV. Press .
5 Press down arrow to highlight Auto Program. Press + to search for channels.
6 After performing Auto Program, press menu to exit.
This should pull in all of your over the air channels
Dec 02, 2010 | Sony FD Trinitron WEGA KV-27FS100 27" TV
I bought me camera off ebay and the software didn't come with it
Easy, just change the camera's USB connection to the DSC mode. You don't need any software when the camera is in DSC mode, it looks like a memory stick or card reader to your computer.
Enter the picture viewing mode, press the "menu /OK" button, arrow down to menu "2",
arrow down to "Set",
right arrow to the sub menu,
Arrow down to menu "3",
arrow down to "USB",
right arrow and arrow up to change from "Pict Bridge" to "DSC", left arrow out and press "menu/OK" button.
Nov 06, 2010 | Fuji FinePix S5200 / S5600 Digital Camera
Montior goes black i turn off the monitor and turn it back on i can do about 2 things and screen goes black again repeat this as many times as i want. Gateway FHX2300 monitor
My monitor has been switching connections on me randomly. Hit the menu button. The one to the left of the power butter when facing the screen. Hit the left arrow twice then hit the menu button again. This will open up the screen where you can choose one of three inputs. I'm going to assume that it is on the incorrect input so use the arrow keys highlight what input you are using and the hit menu button again and your screen should return to normal. Mine only does this randomly when it goes into screen saver, hibernate or sleep. I don't know how to permanently get it to stop doing it though.
Aug 23, 2010 | Gateway FHX2300 LCD TV
SAME PROBLEM THE ADVICE DIDN"T WORK
Manual say to -
1. Press the “Menu” key on the panel, “Menu” will appear on the screen.
2. Press [arrow left] or [arrow right] key, move the cursor to “image function”.
3. Press [↑↓] key; enter “Display model” function choice.
4. Press [↑] or [↓] key, move the cursor to “Image Revolve”.
5. Press [arrow left] or [arrow right] key to adjust “Image Revolve”.
6. Press [↑] to go back to the Menu.
7. Press “menu” key to exit the “menu” window
If your projector will not do this, the functionality may not be there.
Dec 18, 2009 | Televison & Video
I HAVE A WIRELESS ROUTER HOW DO I HOOK UP THE INTERNET T0 MY PS3
in the main menu go to the left side of it and choose settings ok then go down to network setting now inside the network settings go to the internet connection setting ok till now, it will ask to continue YES or NO, u chose YES now u will be signed out of network and 2 choices will appear askin u whats the type of inter connection ur using u Wired or Wireless u go with wireless okkk when u chose wireless it will be BOLD wireless NOW use the Arrow and press on the Right Arrow > another menu will appear choose Scan also press the Right Arrow > u will see ur Wireless name there maybe u will see other Wireless Internet connections but u have to choose ur OWN connection ok. now after choosing ur Wireless connection press X then Right Arrow now if u have a security key then u have to already know what type it is { WEB, WPA-PSK(TKIP), WPA-PSK(AES) or if u dont have a security key at all the choose none} okk try to use WEB while setting ur Wireless settings up its much easy to deal with and try to use an easy key like 12345678 or something like that any way after choosing it click Right Arrow u will see an Empty text area press X and u will see the PS3 keyboard right down ur wireless key then press start also press the Right Arrow keep pressing Right Arrow till u finally in a menu telling u to test ur internet connection press X and u will have ur PS3 connected through Wireless, ** maybe this seems to be a very hard thing to do but i swear its so EASY dot wury u will managed to make it work** have FUN man
Dec 10, 2009 | Sony Playstation 3 (PS3) Console
No Sound on a Philips 42PFL5332D
First thing to try is reset everything to default.
Menu arrow to installation press ok.
arrow to reset av settings press right then press ok.
If still no sound after this the tv likely needs service..even if the settings assistant
has sound.
Sep 15, 2008 | Televison & Video
Ink cartrige wont work
press menu then start mono then arrow up button 4 times.
machine will be in mainténance mode. press the arrow up button until 7 is displayed. press menu. press arrow up til 6 then press menu. press arrow up til 3 Dispaly shows powerp_all press start mono. machine runs a power purge. after that press arrorw up til 0 press menu press arrow up til 9 machine will print test sheet. In case you dont have a good result do the power purge again. If you dont get a good result after 3 times purging, the printhead is clogged and cant be fixed anymore!
to leave the maintenance mode press arrow up til 9 then menu then arrow up til 9.
Nov 05, 2007 | Brother DCP-110C All-In-One InkJet Printer
Canon PowerShot A710 IS Digital Camera Logo
24 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
