Question about Microwave Ovens
The pot no longer heats up--could it be a fuse, or do I have to replace the entire heating element?
    Brigadier General:
  • 3,513 Answers
Please check the links bellow to have a detailed idea to diagnose your problem:
http://www.repairclinic.com/Microwave-Troubleshooting
http://www.repairfaq.org/sam/micfaq.htm#micnhono
Please accept the solution if it's helpful. Do get back to us for any further query.
Thanks for contacting fixya.com
Posted on Oct 04, 2010
Kitchen aid microwave will not heat
first check the fuse if cutoff, replace it. if ok, then check for any broken wire. if all connections are intact, then test the heating element for continuity, if no continuity, then the element is bad and needs replacement. try these steps
Jun 11, 2013 | Microwave Ovens
Hope you can help me? I have lost the user manual for my kettle (Morphy Richards model 43015). Just switched it on not realising it was empty and now it won't work. I seem to think there was a cut out...
Nearly (maybe all) small appliances with a heating element are equipped with a thermal fuse. This prevents the meltdown of heating elements, most of which are encased in aluminum. These fuses are not only unreliable (China is the biggest supplier) but generally unavailable as replacement parts since they are most often spot-welded to the ends of the heating element and would have to be replaced in the same way since solder melts at a much lower temperature.
I would suggest you replace the pot.
Sep 08, 2011 | Microwave Ovens
My coffee pot quit working. it turns on but doesnt warm up or start brewing. how do i fix it
Either the heating element is open, the thermostat is open, or the overheat fuse has popped. You can probably replace the pot for what it will cost to repair it. Good luck!
Oct 09, 2010 | DeLonghi Microwave Ovens
Dishwasher is running through cycles ok but water is not heating so only cold cycles.
Hi
The water is not heating as the heating element has gone bad or a fuse has blown which is preventing heating element to turn on. To check the heating element you'll need to turn off the dishwasher, unplug it. After unplugging it check the heating element formineral deposit on it, clean the deposits using a soft brush and a cleaning solution(Don't scrub the elemnt hard). If this doesn't resolves the issue then remove the panel and examine all the wirin connections to the heating element. Now, use a multimeter and check for the resistance reading(ohms, Rx1) for the heating element. The multimeter should display between 1200-1600 ohms or 1.2K ohms. If it is less than 1200 then you'll need to get the heating element replaced. Also, check for any blown fuse around the element. This should resolve your issue.
Thanks
Daniel
Aug 07, 2010 | Microwave Ovens
Kenmore dryer overheats its one of 3 parts
The component in the blower fan area is known as the Thermal Fuse. It is supposed to read a short (0 ohms) or something close to it. If it were blown, the dryer would not run at all.
The component on the outside of the heater box you are referring to is the Thermal Cut-Out (TCO). It is also supposed to read a short if good. If this component blows, the dryer will run, but will not heat. If you are getting an infinite reading, it must be replaced.
NOTE: If the TCO is bad, you must also replace the Hi-Limit Thermostat along with it. This is the other component on the heater box that is mounted adjacent to the heating element terminals. Failure to replace BOTH components at the same time can lead to premature failure of any parts you do replace. These parts are commonly sold as a set for this reason. The part number for the replacement kit is 279816.
Replacement parts can be purchased on line at any of the following web sites:
searspartsdirect.com
appliancepartspros.com
pcappliancerepair.com
repairclinic.com
For assistance, you can refer to the Sears website for some excellent exploded view parts illustrations. The parts I'm referring to are located under the "Bulkhead" section:
Item 1 - Thermal Cut-out/Hi-Limit Thermostat kit
Item 59 - Thermal Fuse - you should not need this part if it checked good.
Now...if the TCO has blown, it usually blows for a reason. The most common cause of dryer failures is poorly installed, kinked, or clogged dryer vent ducting. I would would strongly suggest you inspect the entire length of the ducting and ensure the vent hose is not kinked or clogged anywhere. Also, make sure you leave enough space behind the dryer to make sure the vent hose is not crushed. This will lead to poor ventilation, resulting in longer dry times, poor efficiency and eventual failure of the heating circuits. It is also recommended that you use the semi-rigid metal ducting because it resists kinking, crushing, rodent investation and heat.
CAUTION: Make sure you UNPLUG the dryer before servicing. Dangerous voltage is still present inside the dryer even when it is shut off.
If you have any questions, please let me know. I hope this helps you.
Nov 28, 2009 | Microwave Ovens
Microwave want heat any longer. Everthing else is
HI. in most cases, this will lead to a failed Heating device(magnetron tube).It would be wise to check the Magnetron cutoff fuse to be sure of its integrity. if the fuse is blown, simply replace it. if the fuse continues to show continuity, replace the magnetron.
(((The fuse is located inside the unit along side the magnetron)))
Jul 31, 2009 | Microwave Ovens
Vintage Manning-Bowman Percolator fix-it guy says thermostat bad
Greetings,
I have an "Atomic" globe type art deco Manning Bowman percolator from 1947. It does not have a thermostat, just a fuse.
If your pot is blowing the fuse, are you using one with the correct amperage for the pot? This pot pulls 350 watts which works out to 3.18 amps. watts/volts=amps. You'd need a fuse that would allow the heating element to generate a minimum of 350 watts before blowung.
May 15, 2009 | Welbilt MR95TW Microwave Oven
Microwave arced, wont heat now
I'm assuming that it doesn't microwave either. If it does...then the heater is bad. Sears parts sells them. Second guess is a blown fuse or thermosensor. Inside the pad housing, locate the internal fuse and replace it if blown. The thermosensor is a black plastic bit about the diameter of a dime and 3/8 inch thick and clamped to the side of the unit inside the control area. Test it for continuity and replace if open. If not either of these, then you have power supply issues or control panel problems. My bet: the heater blew out. Often, this is caused when you heat greasy foods.
Dec 16, 2007 | Kenmore 69642 Microwave Oven
Microwave Ovens Logo
12 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
