Question about Motorola Mobility PEBL U6 Cellular Phone
Powering off Every third or fourth time I close the phone after using it to talk or text it powers itself off. The battery saver is not on. Also it delays on the outside screen. Usually when I close it the time appears, this is whats delaying. It will just stay lit with no words. Sometimes it stay lit until you restart the phone. Also, if it does not power off the inside screen delays when you open it. Bought it online and its past theyre return policy so I'm screwed.
  • ronald toppenberg May 31, 2008
    mine beeps very loud and it says battery low,and cannot hear operator speaking.
I finally returned the phone and they sent me another one. after a while the camera stopped working. i'm not buying anymore unlocked phones offline.
Posted on Oct 01, 2008
    Brigadier General:
  • 7,752 Answers
You curcuit board needs replacing it sounds like it has loads of errors , try a reflash of the firmware or take it to a mobile service center and have them diagnose the board and reflash it for you.
HEST - replace the ear piece on the phone
Generac 15000 watt generator blows 15 amp fuse when it try to exercise
a weak battery will cause the 15 amp system fuse to blow, even though the battery can still actually start the generator.
Nov 29, 2013 | Generac Electrical Supplies
My phone just out of the blue just frooze now it just powers up and wont turn on
keep the battery out for 30 minutes, keep the charger UNPLUGGED from the phone. Then put the battery into the phone and charge it, (with the phone off), for the determined time in your cell phone's user manual. (Recommended 3-5 hours)
Apr 04, 2012 | Samsung UpStage SPH-m620 Cellular Phone
Will not read disks. Cycled power usally worked not this time.
First Turn your X-box on
Second Take out your game or CD
Third Open tray
Fourth Close tray
Fifth Repeat Third and Fourth a couple times and let it load then open
Sixth Stop when you hear the xbox make a spinning noise like when it is reading a game
Seventh Open tray
Eighth Pit a game in
Ninth Close tray
Tenth Play you game!
Dec 30, 2010 | Microsoft Xbox 360 Console
My battery life is great as long as i dont text or call anyone. My phone can retain power if it is not in use. Everytime i attempt to make a three minute call my phone shuts down after a certain amount of...
Hello,why the phone is still shutting down is because the cell of the battery is weak and can power on the phone for to long, that's why it shots down so quick,
You will need to replace battery with a new one for longer talk hours.
Make sure you charge battery for 6hours before use.
Take care.
Jul 02, 2010 | LG Vu CU920 Cellular Phone
Samsung propell problems
Hi, May i help ? Friend the power switch of your phone is short circuited thats why it turns off when press a key. you should clean the power switch surroundings.or resolder the power switch if necessary.
Feb 01, 2010 | Samsung Propel A767 Cell Phone
Can i get cricket service on blackberry pearl?
Sure, a couple of things:
First- you can use BlackBerrys on Cricket in SOME markets. You will NOT be able to use a BlackBerry in an AWS market where Cricket uses the 1900mhz spectrum- simply because the BlackBerry doesn't have that band.
Here is a partial list of AWS markets.
Chicago, IL
Beaumont, TX
Brownsville, TX
Corpus Christi, TX
Laredo, TX
Las Vegas, NV
McAllen, TX
Oklahoma City, OK
St. Louis, MO.
Philadelphia, PA
Milwaukee, WI
Second- the phone doesn't have to be "Unlocked". It needs to be "Flashed".
Third- talk, text, MMS, and internet ARE possible.
Fourth- BlackBerry Internet Services such as BBM and PIN messaging will NOT work. Reason is, you need a BIS account- which Cricket does not provide.
Go to www.bbmedic.com They flash phones.
Dec 13, 2009 | RIM BlackBerry Pearl 8130 Cellular Phone
Putting off power saver on nokia 5000
Hi Friend,
Kindly follow the below mentioned steps,
1.Press the main menu
2.Enter into the settings,
3.Enter into the display
4.enter into the power saver and provide the on/off
If its ON--to save some battery power. A digital clock is displayed when no function of the phone is
used for a certain time.
Check and revert
Kindly rate this solution
Thanks for using Fixya
Regards,
Ayyasam
Jul 07, 2009 | Nokia 5000 Cellular Phone
I can see just a logo on ma moto v3i's external screen
Remove the battery, wait ten minutes and put it back.
Try also removing the sim, try a different one if you have it.
If you have a memory card start it without the card inside.
Try also the following procedure:
"press and hold the * # andpower button all at the same time until you see text come up on thescreen. If you get the text on the screen, pull the battery out, pressthe power button three or four times to discharge the phone completelyand then try the battery again and hold the power button for 8 secondsor until the blue in the kaypad gives a slight flash dim"
from HowardForums
Check also here
Motorola v3m razr has frozen up - FixYa
If it still does not start it is faulty, take it to a repair shop.
Sep 19, 2008 | Motorola Mobility RAZR V3i Cellular Phone
Texting issue
I do not know if you can fix it on your own. But before taking your phone in, try a few things first. First, try removing your battery and putting it back in to your phone. Second, replace the battery. Third, read the owners manual for proper battery maintenance. Fourth, remove any programs that you have added and the replace them one at a time. Good luck.
Apr 05, 2008 | Motorola Mobility Moto Q
Motorola Mobility PEBL U6 Cellular Phone Logo
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
