Question about GE WSXH208A Front Load Washer
How do i replace the drive belt on my GE adora washer
  • 3 Answers
SOURCE: Ge Adora Front Loader
If you have not already done so, clean the filter behind the panel in the front bottom of the washer. Remove the three philips head screws to get the panel off. Unscrew the plastic filter on the right hand side (use a shallow cake pan to catch any water). Remove the filter and clean out the pens, pencils, change, lint, etc... and put back in. All should work well after this. Thanks, Greg
Posted on Jan 03, 2008
SOURCE: Front loading ge washer won't drain?
Similar problem fixed in less than 5 minutes. Here's a post that was very helpful. http://www.foobert.com/blog/2007/04/02/ge-adora-front-loading-washer-does-not-drain/
There's a trap located under the front panel (3 screws) I undid the filter and pulled out 21 coins, 2 buttons, a 'letter h', zipper parts, a broach, and a whole lot of lint.
My wife said that the unit never got the clothes so dry afterwords, she said the almost didnt need to throw the clothes in the dryer.
NOTE: Have a ton of towels ready, and if you can fit a bucket or dish under the filter, go slow and steady. I opened it up and had several gallons all over the floor!
Posted on Jun 04, 2009
  • 57 Answers
SOURCE: My Ge Adora washer fabric softner dispenser
You have low water pressure which wont reach the dispenser drawer during rinse cycle. Clean the feed pipe in case there's dirt in the feed gauze located at the back of the machine. The mould on the rubber is dirt in the machinme. A mixture of 1 cap of bleach and 1 small tub of Swarfega mixed with water and put into the drum on an empty wash will stop it geting worse but it cant be removed.
Posted on Dec 09, 2009
edgreason
  • 120 Answers
SOURCE: front load GE Adora washer isn't spinning when it
go to the web site for your manufacturer.
download the troubleshooting guide/manual.
there should be a procedure to retrieve "error codes" that will
narrow the problem(s)
door latch sensor is one possibility, others are
motor control unit deffective
front panel/switch control deffective
does it pump water out?
does it turn during wash cycles?
have you tried other cycles? ie, quick wash, rinse/spin only, etc?
Posted on Apr 06, 2010
  • 202 Answers
SOURCE: ge adora front load clothes washer washer smoke
new pump
Posted on Mar 22, 2011
Spin. Working short time do not put cloth water out
Sounds like the belt that spins the washing drum is slipping. It my need to be adjusted or replaced, or try washing a smaller load of laundry.
Mar 10, 2016 | GE Washing Machines
Why won't my washer drain
Check the belt that operates the pump. If that does not help, take out the pump und check for obstructions. Pins tend to get stuck in there and keep the impeller from turning. Does the impeller turn freely? If it does, the machine will drain.
May 17, 2014 | GE Adora Front Load Washing Machine Washer...
GE Adora GHWN5250D0WS beeps twice, wont start
Sounds like the lid switch is broken if you need more help please let me know
Mar 28, 2014 | GE Adora 3.9 cu. ft. Top Load Washer in...
How to repair drive belt on GE Profile washer
Contact the GE Washer div. and request a schematic of the machine. It will show you the detailed format for removing parts and construction teherafter.
Mar 25, 2014 | GE Profile WPRE6150KWT Colossal Capacity...
I have a GE Adora front laod washer that I need help with. I have cleaned the pump filter, shop vac'ed the hoses, checked the hoses to make sure they are not clogged or pinched and I have hit a de
On the GE Adora machines, if the unit is not getting the correct power, the unit will not go beyond the fill point to wash. You will need to replace the "power inverter" on the unit. Here is the part you need to order.
Nov 01, 2012 | Washing Machines
GE Adora front load washer turns until water is added then won't turn or spin
You should contact GE or qualified appliance repair center to be looked at professionally.
May 06, 2012 | GE Wh12x10309 Heater for Adora Front Load...
GE Adora front load wont lock the door or start at all. GE service is not existant.
the door switch has broken and needs replaced can be got online,adrian;;;;
Nov 11, 2009 | GE WSXH208A Front Load Washer
Front load ge washer does not finish cycle
This model does not have a drain filter. There are filter screens inside the inlet valve where the hoses attach onto the machine. Take hoses off and look inside where the water goes into machine to see screens. Also, take the other end off hoses to make sure there are not screened hose washers in either end of the hose which may need to be cleaned or replaced.
Oct 18, 2008 | GE WSXH208A Front Load Washer
GE WSXH208A Front Load Washer Logo
217 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
