Question about Casio Exilim EX-S600 Digital Camera
I took several pictures this morning. Then I plugged the camera into the cradle and pressed USB port and connected the line from the cradle to the computer, an operation I have completed numerous times. This time nothing happened. No "import" showed up. I looked at help in iPhoto. It said to turn on the camera. I tried, but it would not turn on. I took it off the cradle and tried many times. No luck. Have I somehow accidentally locked the camera? Does it even have a lock feature?
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Casio Master
  • 102,366 Answers
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use iPhoto or any other photo cataloging program.
Posted on Apr 25, 2011
Can I charge a Casio Exilim battery throug USB to my PC
No. The EX-Z60 does not charge the battery through the USB port. You need to use the supplied charger. Alternatively, if you have the EX-Z60DX cradle, you can plug the camera into the cradle and plug the cradle into a wall outlet. However, using the cradle will not let you charge the camera through the USB port either.
Aug 23, 2011 | Casio EXILIM ZOOM EX-Z60 Digital Camera
Last friday i took some pictures and transfered them to my pc as i have done for the last 18 months. Over the weekend i took some more pictures. I went through exactly the same routine in connecting he...
Consider NOT connecting your camera to your computer.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
Nov 25, 2010 | FUJIFILM Finepix S1500fd Digital Camera
Where is the usb port on thefinepix z can u show
You won'tfind a USB port on any camera. But you will find a tiny socketinto which a plug goes and the cable connected to it has a USB plug on the other end. So Look for a small socket and that is where you pplug the USB cable into. Try looking at the sides of the camera.
Apr 07, 2010 | Fuji FinePix Z2 Digital Camera
How do i transfer pictures to my memory card
Connecting the camera to a PC
1. Turn the PC power on.
2. Turn the camera power on.
3. In any mode other than Voice Recording mode, press
the MENU button.
4. Press the LEFT/ RIGHT button and select the [SETUP]
menu tab.
5. Select the [USB] menu by pressing the UP/ DOWN
button and press the RIGHT button.
6. Use the UP and DOWN buttons to select
[COMPUTER], and then press the OK button.
7. Press the menu button twice and the menu will disappear.
8. Connect the PC and the camera via the USB cable.
- Insert the small plug of the USB cable into the camera USB connection terminal.
- Insert the large connector of the USB cable into the USB port of the PC.
- The plugs must be firmly inserted.
note: driver for a40 must be installed in your computer.
you can get it here.
Jan 09, 2009 | Samsung Digimax A40 Digital Camera
Drivers missing
ways i am giving to you. try all one by one uptil it starts working.
1.reinstall the drivers.
2.check if the card is correct or not.
it might have came under someone's feet.
3.the port might be making some problem
4.if all these have failed,consult any hardware expert.
Aug 03, 2008 | Olympus Stylus 770 SW Digital Camera
Problems trying to connect to the computer
ya, u check ur camera USB port i think some looscontacts,
Apr 05, 2008 | Canon PowerShot SD600 Digital Camera
Camera No Longer Being Recognized
Does it connect to the PC via a USB cable? Then try connecting to a different USB port or if you have try a new USB cable. I had the same problem with my IXUS 400 and changing to a new USB port, directly to the PC - not a USB hub, it worked. However now I have several issues with my camera - no sound or image on the LCD screen, but I think these are unrelated.
Jan 27, 2008 | Canon PowerShot S400 / IXUS 400 Digital...
Where is port to connect USB cable?
I'm sorry you're having trouble with this. I have put together a picture that shows where the mini-USB plug is supposed to be attached to the camera. I hope it helps. This picture actually shows plugging the AV cable into the receptical, but right behind it is the mini-USB port. This is where you connect the USB cable. It looks like you have to lift the flap on the corner to reveal the plugs.
Nov 24, 2007 | Canon PowerShot SD1000 Digital Camera
Camera Wont turn On: Is it stuck in USB mode? How do i fix it?
I was able to get past this problem by removing and reinserting the battery. This caused, in effect, a hard reset of the camera, which let me power it up fresh and take pictures again. Of course, it's not exactly reassuring that the problem arose in the first place,
Jimmo
Nov 04, 2007 | Casio EXILIM Card EX-S770 Digital Camera
Casio Exilim EX-S600 Digital Camera Logo
Top Casio Cameras Experts
Greg Cann
Greg Cann
mohamed salim shaikh
Are you a Casio Camera Expert? Answer questions, earn points and help others
