Question about Refrigerators
HOw do I replace an ice/water "aquaSense" filter on kitchenaid Superba model KSRB25FHSS01? Thank you, Ms. Forbes
aasc
  • 1606 Answers
SOURCE: how do you take out and change the water filter on
At the bottom of refrig , on the toe plate , press the button on the left kinda hard , and the filter should pop out .
Posted on Sep 24, 2009
Testimonial: "thanks for the help. "
  • 23 Answers
SOURCE: Kitchenaid Superba Ice Maker quit
Make sure your manual doesn't say something about inline filters, or a float that might be sticking in off position. Depending on how ice is made sometimes they have a float to where water rises so hight then gets shut off to freeze and form the ice.
Posted on Dec 08, 2007
  • 1314 Answers
SOURCE: Water Filter Kitchenaid Superba...Where is it??
look for a round peice on the kickpanel at the bottom of the unit it twists and slides out
Posted on May 13, 2008
  • 12 Answers
SOURCE: How do you replace the water filter on a
under the freezer door there is a nob like thing. turn it and pull on it. instead of replacing it, rinse it out under runing tap water and put it back were you removed it from and push the fridge light botton 5X in a row
Posted on Oct 19, 2009
SOURCE: Kitchenaid Icemaker with Aqua Sense is not working.
I had turned the water feed off on our Kitchen Aide Frig for several days while repairing another appliance in the kitchen and then discovered the aqua sense ice maker stopped working because it wasn't getting any water fed in, even after pressure was restored to the water line...appreciate your heads up as to the possibility of a frozen water feed...you helped me identify the problem
Nothing in the manual on this possibility, but without disconnecting power to the frig, I cleared off the top shelf in the freezer and warmed the area with a hair dryer..on our large side by side, it appears that the water is fed to our ice maker from the top of the frig on the right side...I warmed the area for three 5 minute periods...about 10 - 15 minutes apart...I noticed water starting to leak into the tray (I assume from the melting) and carefully sponged it out so I could gauge the success of the melting...
I am not sure if it made a difference, but half way thru the process I also powered the machine off (from the controls on the refrig side) as I wasn't sure if a reset cycle was necessary....about an hour later, the machine self feeder filled up the tray and it is once again making ice...
I would caution going slowly with the heat and concentrated hair dryer so as not to damage any of the plastic...other than that, this was pretty easy..
Posted on Jan 04, 2010
What type if filter do I for kitchenaid superba ksrb25fhss01?
The refrigerator water filter for the kitchenaid superba ksrb25fhss01 is part number 4396508. If you order it from Sears Parts Direct, it's $45. See: http://www.searspartsdirect.com/partsdirect/part-model/Kitchenaid-Parts/Refrigerator-Parts/Model-KSRB25FHSS01/0593/0165000/O2029608/00002 . It's available from other sources for less (including Amazon: http://www.amazon.com/Whirlpool-4396508-KitchenAid-Maytag-Refrigerator/dp/B0009793KC .)
I hope this helps.
Jun 24, 2012 | KitchenAid Refrigerators
Ice maker mal-formed ice
no "slug" is available however you could just use a reverse osmosis diaphram pressure tank to boost the water pressure. you can also use a water supply tube to bypass the in-refrigerator completely.
Jul 22, 2010 | KitchenAid Superba Architect KSCS25IN Side...
The water dispenser stopped working but the ice dispenser still works just fine on my KitchenAid Superba KSRG25QFB side by side
First Question, Have you changed the water filter???needs to be done every 6months. dirty water filter can keep water from flowing through system......also nasty to drink.........
Jan 09, 2010 | KitchenAid Superba KSRG25FK Side by Side...
Icemaker is not making ice.
check water valve /filter it maybe the ice maker
Apr 02, 2009 | KitchenAid Superba KSRS27CN Side by Side...
Ice maker not working/ water leaking from bottom
turned out the filter had a leak. So first shut of the water valve that made the connection to the fridge then twisted the filter counter clockwise and replaced it with a new filter.
Jan 05, 2009 | KitchenAid Superba Architect KSCS25INSS...
Kitchenaid superba icemaker leaking/freezing in freezer section
Your water hose that connects to the back of the freezer may be loose. Move the fridge out away and in the back make sure it is tightend.
Let me know if it helped :)
Oct 20, 2008 | KitchenAid Superba Architect KSCS25INSS...
Kitchenaid Refrigerator Superba
heres a part number for the valve, somple enougth to install just turn off the water supply and installe ne wvalve, exact replacement. soundsas if its not closingt correctly allowing water to tricklel in part number 4389177
Apr 07, 2008 | Refrigerators
Refrigerators Logo
959 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
