Question about OQO 02 (1050203US) PC Notebook
My OQO 02 was freezing during work. Now it will not start again. Blue power light comes up, I hear start the HD, but no system start. No BIOS info. OP-System is VISTA Business.
I have done the step to remove the bios password by taking out the battery for 24 hours and it went good. I could come in the bios and I have installed Windows XP with all his updates. To me surprise the...
That doesn't work, you must completely format the system and then reinstall the operating system. Taking the CMOS battery out doesn't erase the system password, that is a old wives take.
Jun 27, 2017 | Compaq d530 CMT PC Desktop
Need to reformat an oqo model 2 disk - windows wont boot - can i fix by booting from a usb?
If your USB stick has a bootable system on it, (format the USB with system files before adding your system) and if you set the BIOS to use USB as boot device.
Mar 07, 2011 | OQO model 2 PC Notebook
Windows Vista freezes while loading up& Blue Vertical Bars appear
Hi
Reflashing the bios doesn't make any difference.
Check in the BIOS Screen whether notebook scree has the same issue if it is the same then it is a hardware issue if it is fine in the bios screen then need to run the hdd and memory test
After the test result we can decide next steps
> If hdd and memory test passes - then reload the os.
To login to bios - Reboot the system and keep tap on f10
Apr 28, 2009 | HP Pavilion dv9000z Notebook
My PC auto matically restart when turning it on
The beep you hear is your BIOS trying to alert you to an error in the POST (power on self test) routine. Without knowing the manufacturer of your motherboard one can't be certain what the beeps indicate...see this link for more info: http://www.5starsupport.com/info/beep_codes.htm
It's possible you have some kind of infestation, and it's possible there's something more systemic, but without knowing the make and model of your system I couldn't say.
Sometimes three beeps indicates a keyboard error...you could try another keyboard or unplug yours and see if it will boot up "normally" without it.
Otherwise, report back with some more info and we'll take it from there.
Mar 28, 2009 | Microsoft Windows XP Home Edition
The bios update failed on my 4g asus eeepc
What you need to do is to get the manual for the motherboard os you can reset the BIOS. On the other hand, you may not be able to preform that. This model is like a netbook and try this, remove the battery and the power cord. give it 15min. put the battery back in and reboot the system and than the power cord. that should help. if not, than a tech person is your next step.
Mar 27, 2009 | ASUS Eee 4G Notebook
Toshiba Laptop doesnt fully boot up!
Question, does it freeze while BIOS boot or operating system boot? try reinstalling operating system and or repairing (overwriting) the MBR.
Sep 11, 2008 | Toshiba Equium 100 PC Desktop
New asus m3n72-d motherboard bios will not post
If you don't already have a case speaker hooked up to the board, you might want to connect one since there isn't an on board speaker and you will not hear error beeps otherwise.
Also, if you have another non-phenom AM2 processor handy you should really update the BIOS to latest release. Many late model Phenoms will not work on motherboards that have earlier BIOS releases and you will not be able to post. You should then choose "Set Optimized Defaults" and save the bios without any changes then shut down (not reset). When you power on again it should post and you should be able to get into the BIOS.
A third thing you can try (after you get a case speaker hooked up) is using a cheap pair of ddr2-6400 RAM to get the board to post so you can get into BIOS and change the voltage to the correct settings for your RAM if it requires a higher voltage than the bios expects.
Aug 23, 2008 | Intel Motherboard
T6420 E-Machine won't/Reboot W/O F8 Key
No sync means no video signal to the monitor. The rest sounds like a corrupted OS. This could be from a number of reasons, including a virus. If you have NORTON or MacAfee, Your open to a lot of attacks. Get AVG free, and use Mozilla instead of IE.
The reason the fans come on full speed is the MB senses a high temp on the CPU, until the bios fan control takes over after POST. This is normal on most systems.
Aug 22, 2008 | E-Machines eMachines Desktop PC
Computer Freezes During Startup (Urgent!)
Try firstly, on start up keep pressing F8 until a menu comes up. Look for the line that reads 'Start windows with last known good configuration', move cursor to it with the up or down keys as your mouse won't work; and press enter. Hopefully your pwill restart and run as normal. If not you may need your Windows cd.
Jan 03, 2007 | Toshiba Satellite A105 Notebook
OQO 02 (1050203US) PC Notebook Logo
23 people viewed this question
Top OQO Computers & Internet Experts
David Payne
David Payne
Are you an OQO Computer and Internet Expert? Answer questions, earn points and help others
