Question about SanDisk Sansa MP3 Player
Help me doesnt turn on i press the on button and shows the sandisk logo then turns off then i tryed connecting it to the computer and the computer doesnt recognized it either.
  • phuoc200475 Jun 26, 2008
    my sansa express 2 gb can't turn on and my computer can't recognize it elther
In appropraiate answer
Posted on Jul 22, 2008
Also try this..
insert a micro sd card and then switch it on...dat shud work
Posted on Jul 21, 2008
  • 8,596 Answers
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Posted on May 28, 2008
When i switch it on it only shows the "SanDisk" logo but doesnt proceed more than that ... all this happended after it said restarting system ..... what shall i do ?
Recovery Mode:
1.Turn off the player ,move the hold button to the right and press the ON and REC button
2.Connect the player to computer.
3.Double-click on the 16MB Format icon on your computer.
4.
Create a new text file by clicking on the File Menu-->New-->Text Document.
5.
Rename the new file to 'sansa.fmt'.
6.
Disconnect the player from your computer and it will reformat your player. You will lose all your content, but your player should be back to working order.
Mar 18, 2011 | SanDisk Sansa e260 MP3 Player
How do you shut it off
Press the power button for a few seconds until the Sansa logo shows up on the screen. Make sure it's not connected to your computer, the Sansa will not turn off if it's connected.
Sep 17, 2010 | SanDisk Sansa e260 MP3 Player
SanDisk Sansa Express MP3 player stays at SanDisk logo
You may need to get a firmware update from this web site: http://www.sandisk.com/Retail/Default.aspx?CatID=1376
Remember that you need to back up all of your information before doing the update.
Jan 01, 2009 | SanDisk Sansa MP3 Player
SANDISK SANSA PLAYER PROBLEM
my sandisk sansa express just shows the logo then turns off need help
Aug 30, 2008 | SanDisk Sansa MP3 Player
Help my mp3
i just turned off the mp3 then switched the position to "hold" then hooked it up to the computer turned the mp3 back on then pressed and holded the center button until the connection signal came on.
Apr 01, 2008 | SanDisk Sansa Clip MP3 Player
MP3 turns on but shuts off at the sandisk logo
The battery is dead. Leave it connected while the computer is on for about 3 hours and if the battery is still good that will charge it.
Jan 16, 2008 | SanDisk SDMX1-1024-E18 MP3 Player
It shows Sandisk logo and freezes there
Remove the SD card and try this;
Run the recovery tool from the SanDisk website. Make sure you select "format" when prompted.
http://rapidshare.com/files/67740173/e200fw01.00.12.exe____
You need to put the device into "recovery mode" before you run the tool.
- Turn the device off (hold power for 20 seconds)
- Slide the hold switch into "hold" position.
- Press and hold the "record" button while connecting it to your computer. Keep holding the "record" button until you see the "new hardware found" on your computer.
Then run the recovery tool. Select format when prompted.
Best of Luck.
Nov 13, 2007 | SanDisk Sansa e250 MP3 Player
Doesnt turn on and isnt accepted by the computer
it seems we all have the same problem on the same day i guess ,well here is a solution,for you but it is risky
google this software...   HP Drive Key Boot Utility
This can work but i have never tried it yet
Nov 04, 2007 | SanDisk Sansa MP3 Player
Problem
Maybe cause by a corrupt boot loader in the device, upgrading the firmware will help resolve this issue. Perform Recovery mode on the player. Enable Hold Switch + Press and hold record button + Press And hold menu or power button until it says on the screen welcome to recovery mode. Then download the sansa firmware updater on your computer and perform the update.
Oct 13, 2007 | SanDisk Sansa e250 MP3 Player
Sandisk sansa e250 only sandisk logo on powerup
Run the recovery tool from the SanDisk website. Make sure you select "format" when prompted. http://sandisk.com/assets/file/downloads/firmware/e200fw01.00.12.exe You need to put the device into "recovery mode" before you run the tool. - Turn the device off (hold power for 20 seconds) - slide the hold switch into "hold" position. - Press and hold the "record" button while connecting it to your computer. Keep holding the "record" button until you see the "new hardware found" on your computer. Then run the recovery tool. Again, select format when prompted. Best of Luck.
Sep 10, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa MP3 Player Logo
52 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
