.After spraying my dog with
    Problem Solver:
  • 9 Answers
Yes the sensor got wet & your pilot lite is probably out from the water
Posted on Oct 04, 2010
Is the Richmond 6g40-34pf hot water heater a model with or without powervent
According to photos listed for that specific model... it is NOT power vent.
It is ordinary atmospheric gas water heater with 3" vent pipe
http://waterheatertimer.org/How-to-install-gas-water-heater.html
Gene
Water Heater Timers Save Money
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Mar 04, 2015 | Water Water Heaters
Does the vent motor come on when you turn on a powervent hot water heater
`1) Copy following link to troubleshoot by type of gas control valve, blower motor links, pressure switch testing, and other professional resources:
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
http://www.thetankatwaterheaterrescue.com/forums/forum3/
2) Power-vent blower motor can go bad.
Plug motor directly into outlet, or turn on-off switch on, and see if motor works.
Check outlet for correct polarity, and for at least 80% of rated voltage.
Check vacuum switch. Blower creates vacuum, and the vacuum switch detect vacuum, and signals gas control valve that burner sequence can continue.
Gas control valve can also go bad. Wiring etc can go bad.
Feb 04, 2013 | Rheem 50 Gallon FVR NATGAS Water Heater...
I have a PowerVent residential Gas Water Heater the blower runs continuously and the water is not hot enough
Copy following link for troubleshoot resources, including troubleshoot by type of gas control valve.
Brand and model number of unit is located on label side of tank.
Aug 05, 2012 | Water Heaters
I have a richmond 40 gallon powervent water heater. It seems to light, but shuts itself off after about 5 seconds. I am leaning toward the vapor sensor. I know there are reset codes, but have not been...
1) Could be the vapor sensor. That's a suspect.
2) General troubleshoot: clean burner and combustion parts, clean air intake, bleed air from gas line, check gas pressure. Color of gas flame should be clear blue, and flame should be strong, and no combustion by-product dripping back into combustion chamber. No chemicals of any kind stored in air supply. Plenty of fresh air. Water heater in hot attic needs more air. If water heater has igniter, then igniter has to be checked. Flame sensor must be positioned correctly and operational at time of combustion, or sensor will signal gas control to turn off gas. Gas control valve can be bad.
Open following link for possible illustrations and reading.
http://waterheatertimer.org/How-to-install-gas-water-heater.html#troubleshoot
3) Specific troubleshoot begins with identifying gas control valve and reading the service manual.
I think the Rheem/Richmond power vent has intellivent gas control
Open following link to identify gas valve and download possible service manual:
http://waterheatertimer.org/How-to-adjust-water-heater-temperature.html#intelli
4) Take a moment and rate answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Sep 04, 2011 | Audiovox Richmond 6G40-36F 6-Year Tall Gas...
Ok. a plbg client just called. in 2004 he installed a Rheem 22v30 (30 gal) gas water heater in one of his units. he just called. the pilot stays lit, but when he turns on the gas, the burner...
Certain water gas water heater models feature electronic controls with a flammable vapor sensor installed on the bottom portion of the water heater unit. This sensor is designed to shut off your water heater system to prevent fires in case flammable vapors are present within the area. If your flammable vapor sensor caused your water heater to shut down, check the area immediately for leaking gas or other flammable products. Common household chemicals such as bleach can also trip the safety system as well as unsuccessful burner ignition attempts. I'm not sure what control your unit has, but on a White Rodgers here's how it goes.
White Rodgers Intelli-Vent PowerVent Control Equipped Models
  1. Step 1 Turn the water heater's blower switch off and disconnect the power cord for the water heater (refer to your particular model's operation guide for the exact location of the blower switch). Disconnect the Molex connector attached to the bottom of the control pad (the left most connector with five pins).
  2. Step 2 Turn on your multi-meter and set it to read resistance or "ohms". Connect one of the multi-meter's probes to the number two pin and the other probe to the number three pin of the Molex connector (middle black wires). If the reading on your multi-meter reads below 9k or above 45k ohms, the flammable vapor sensor is faulty and in need of replacement; you cannot reset the system until this issue is resolved.
  3. Step 3 Reconnect the Molex connector to the bottom of the control pad, reconnect the water heater's power if and turn the blower switch to the "ON" position. Press both the left and right buttons on the control pad at the same time. Wait for the green light on the control pad to blink and press the following buttons in sequence: Left, Right, Left, Left, Right, Left, Right, Right (you will need to perform these actions within 30 seconds of reconnecting the power cord to the water heater in order to be successful
Oct 28, 2010 | Rheem 30 Gallon FVR Propane Water Heater...
Flammable sensor is lit and won't go off. I replaced the sensor how do i reset the controller?
Oct 15, 2010 | Audiovox Richmond 6G40-36F 6-Year Tall Gas...
Basement was flooded when washer inlet hose burst. Approx 6 in of water in the area where the water heater stands. Complaint of no hot water, no pilot flame. Attempt to light pilot successful but pilot...
Certain Rheem water gas water heater models feature electronic controls with a flammable vapor sensor installed on the bottom portion of the water heater unit. This sensor is designed to shut off your water heater system to prevent fires in case flammable vapors are present within the area. If your flammable vapor sensor caused your water heater to shut down, check the area immediately for leaking gas or other flammable products. Common household chemicals such as bleach can also trip the safety system as well as unsuccessful burner ignition attempts.
Oct 01, 2010 | Rheem Water Heaters
Hosed basement floor. soaked flamable vapor sensor. Removed and dried sensor. control now in lockout. How do you get control out of lockout???
  3. Step 3 Reconnect the Molex connector to the bottom of the control pad, reconnect the water heater's power if and turn the blower switch to the "ON" position. Press both the left and right buttons on the control pad at the same time. Wait for the green light on the control pad to blink and press the following buttons in sequence: Left, Right, Left, Left, Right, Left, Right, Right (you will need to perform these actions within 30 seconds of reconnecting the power cord to the water heater in order to be successful).
Jul 23, 2010 | Rheem Water Heaters
We have a Rheem powervent gas water heater (50 gallon). We can't seem to get the pilot light lit, it won't light at all. The Flammable vapor sensor code flashed. We had a fire in the basement but the tank...
yep, for certain it is the vapour sensor tripped by the paint fumes. I work in the hvac field, on service and at least half a dozen times a year, i go to no hot water calls, due to the sensor being tripped off by kitty litter. the sensor is designed to be as failsafe as possible. Any slight detection of vapor, that could potentially be combustible and the ignition sequence is locked.
Mar 14, 2010 | Rheem 50 Gallon FVR NATGAS Water Heater...
ECO failure. Replaced the gas control thermostat & vapor sensor
It sounds like your gas/air mixture needs to be adjusted. The flame should have just the slightest amount of white, at the very tip. The rest should be evenly blue. There is an air vent adjustment in the line to the burner, right after the gas input.
Sep 03, 2009 | Rheem 40 Gallon FVR NATGAS Low WATER...
Heating & Cooling Logo
41 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Mack Baxter
