Question about Ryobi Thickness Planer Blades
How can I set the blades on my Ryobi AH-115 thickness planer? I'm told there is supposed to be a set gauge that comes with the machine that I do not have. Are they available?
I made a very simple yet effective jig for setting blades on an old ryobi ah 115 planer. Do you still need help with this?
Posted on Jan 15, 2011
  • _TMH_ Aug 01, 2011
    Hello, marchese969. Would you be so kind as to explain you blade-setting jig for me? I just sent the planer knives on my AH-115 out to be sharpened.
    The rollers weren't feeding the workpiece through the planer, so I thought that sharpening the blades would fix this. They needed to be sharpened anyway.
    Thanks, Tim
  • marchese969 Aug 02, 2011
    Email me at marchese969 at gmail and I will send you a photo of the block I made and a short description of how to use it.
I am replacing one damaged roller on my AP13AK planer. I have an exploded view of the whole machine which shows numbers of all parts. A list and description of parts would be helpful. Where can this be...
HI I HAVE THE SAME MACHINE AND MY FEED ROLLERS HAVE JAMMED SO AN EXPLODED DIAGRAM MIGHT BE HANDY AS I PULL IT APART
COULD YOU PLEASE EMAIL ME A COPY OF IT TO
PETER BULLARD AT aj4bullard@bigpond.com
THANKS PETER
Mar 08, 2011 | Ryobi Thickness Planer Blades
Ryobi AP1301 planer. Suddenly started getting ripples in wood.parallel to blades. Tried reversing blades to unused side, made no difference.Only trying to take of about 1/16". Stock is...
CHECK THE ROLLERS THAT PULL THE WOOD THRU, I HAD TO REPLACE MINE FOR THE SAME REASON.
IF THEY HAVE A LOT OF USE YOU WILL SEE WORN FLAT SPOTS ON THE ROLLERS CAUSING THIS PROBLEM
Jan 16, 2011 | Ryobi Thickness Planer Blades
How to replace drive belt on ryobi thicknessor
How to change belt on a ap10 thickness planer
May 09, 2010 | Ryobi Thickness Planer Blades
I have a 12 5/16'' ryobi planer and need a place to get a set of knives and books.
go to home depot and purchase DELTA 12 1/2 inch blades. make sure they are centered so they don't rub the sides of the housing or grind off a little bit off each end.
Oct 18, 2009 | Ryobi Thickness Planer Blades
Ryobi AP12 Thickness Planer---rubber feed rollers do not rotate
It is fixable if you are technically competent. All parts are still available online. It could be one of two problems:
1 - The rollers are driven by two gear & chain mechanisms on the height adjuster side of the unit. I did have a drive chain break once.
2 - If it isn't that than the gearbox has cracked / gear stripped under the torque load. This is also fixable, each individual gear and the gearbox housing are still available (10-09), but it requires substaintial teardown.
As you disassemble the unit just be careful once you remove the crossover height adjuster shaft - you don't want to turn one lifter by itself and have the planer higher on one side. It really is a simple teardown, just lots of parts. If you like the planer it is worth it; parts are cheap. If you are like me, you enjoy tearing stuff down to see how it's made and you hate throwing out $200 tools because only one little part broke!
Aug 06, 2009 | Tools & Hardware - Others
Uneven thickness when planning
Surely you have some mounting screws for the Knives, don't you? You may have to loosen those and Re-set your Cutter Depth & Level. I use a "Step-Gauge" to do that with. In some Rare Cases you may have to shim to attain the desired results.
Jan 10, 2009 | Ryobi Thickness Planer Blades
Ryobie ap 1301 surface planer
Here is the Ryobie support web site . You may still be able to get the manual for your service planer.
https://register.ryobitools.com/customer_session/new
Dec 22, 2008 | Ryobi Thickness Planer Blades
Ryobi Thickness Planer Blades Logo
583 people viewed this question
Top Ryobi Masonry Tools Experts
Tom Chichester
Are you a Ryobi Masonry Tool Expert? Answer questions, earn points and help others
