Question about Ecoquest Breeze AT Living Air Purifier
Will not turn on - Ecoquest Breeze AT Living Air Purifier
    President:
  • 670 Answers
Typical things to check are the plug, make sure it is seated into the socket and outlet. Check the fuse, it is located inside the power cord socket. Check that the safety switch clip on the lint screen makes contact with the switch.
Posted on Oct 04, 2010
Eco Quest Fresh Air
Have you unplugged it? Or is there a hard reset for it other than the reset button? Can you try to hold the power button down and see if that does anything? But try to pull the filter and stuff out again, after you have unplugged it, see if that works.
Mar 15, 2014 | Ecoquest Air Purifiers
Reset engine indicator light
1. With the Car Off, Press and hold down the Odometer Trip Reset Button. 2. While still pressing the Trip Reset Button, Turn the Ignition Key half way on where all your oil, check engine lights etc.. turn on. Don't turn it as far as you would to normally start the car. Wait a few seconds and the Check engine light will turn off. 3. Turn the key back to the Off position and you're done.
(source: Yahoo Answers)
Feb 08, 2014 | aFe 2004 Honda Accord - 3.0L V6 - Air...
Fan wont turn
I have taken one apart. reassembled and the fan would not turn, although there was power to the motor and it wanted to turn.
Sorry this is long...only this is about taking the motor itself apart..and I have yet to find a replacement motor.
1. Tried a little WD 40...(only on iron motor Housing!) nothing.
2. Took apart inside of motor. some rust inside..
3. carefully rubbed clean with WD 40..
4. leaned off WD 40 with contact cleaner...
5. Then worked little bearing loose on back side.
-Kind of turned upon reassembly..
6. Found some silicone High temp lubricant and took motor inside part again.
7. a very thin coat of lubricant inside rotor.
-Re assembled yet again..began to turn at high speed, kept running..24 hrs..
- It .finally turned at silent mode. and continues to work
This may be ar beyond what you want to do, however if all else fails...what else can you do? buy another one?
Tips:
1. mark rotor holders with housing. (do not reverse.)
2. make sure you remove all lint, dust, etc inside.
3. the rotor bearing I had to work by hand again and again repeatedly syringing a little WD 40 at a time to until it turned easily.
Jun 04, 2012 | Oreck XL Professional Air Purifier
I have an Aprilaire 700. Whenever the unit has been turned on, the water flow to the unit will not stop running. What part(s) do I need to replace so that the unit will properly turn the flow on and...
Hello, in order for the humidifier to turn on and off with the furnace you need either a sail switch or current sensing relay. A sail switch mounts in the return air duct and senses the return air when the furnace turns on thus turning on the humidifier and turning it off when the airflow stops. A current sensing relay works the same way but instaed of sensing airflow in senses current on the blower motors common lead and is easier to install than a sail switch. I will post a pic of both
robhvac47_24.jpgSail switch
robhvac47_25.jpg Current sensing relay
Feb 27, 2011 | Aprilaire Air Purifiers
My ecoquest fresh air turned off suddenly... when i turn it on again there is no power it keeps flashing in the front screen .. is it an easy fix or hard fix ? please advice ... thank you
Oct 11, 2010 | Ecoquest Fresh Air Air Purifier
The fan on my living air purifier doesnt turn anymore. Occasionally when I first turn the fan on, it will "try" to turn but stops almost immediately. do i need to replace the fan motor? Is it something I...
I just bought a used one of these at a sale. Horribly dirty, grimy, rusty, etc. Anyway, similar problem with fan. Clean it off and WD-40 or silicon it. You should be able to see an almost immediate response unless it's another problem. My fan went from a low speed when turned on "High" and from a complete stop on "low" to actually turning on low. Anyway, I laid it on it's front, sprayed some 40 on the back fan bolt (pin, screw, whatever), then used a pen to click the safety so it would turn on with the back off and in less than a minute it was at full speed. Good luck!
Sep 22, 2010 | Ecoquest Living Air Classic Air Purifier
Cleaned the plates and the back filter and went to turn it on and it will not turn back on
Be sure the tab on the filter is making the safety switch click in and stay in. Sometimes, all you need to do is push in on the lower right corner a little and it will start.
Mar 25, 2009 | Alpine Air XL-15 Air Purifier
Fan trouble with Flair
remove the retaining screw from the bottom of the unit and slide the insides out the back. use WD40 with the plastic extension tube, spray into the motor armature/stator and turn with your hand until it is free spinning then reassemble and turn on.
this is an ongoing problem with my unit because the air and all contaminents are pulled directly to the fan.
Apr 04, 2008 | Ecoquest Flair Air Purifier
Ecoquest Breeze AT Living Air Purifier Logo
107 people viewed this question
Top Ecoquest Air Purifiers Experts
fordexpert
Are you an Ecoquest Air Purifier Expert? Answer questions, earn points and help others
