Question about Hannspree 22" widescreen LCD Flat Panel HD Monitor
I just purchased a HF 205 Hannspree 20" monitor. I can't figure out how to use the control buttons to adjust the contrast etc. When looking up something in Google the print appears to be two colors black and purple. My downloaded photos also see to be some what distorted. I was unable to download the owners manual when I I tried usiing the cd that came with it. Please Help!!! Thanks!!!
florin_decad
  • 203 Answers
SOURCE: Monitor Drivers for Hannspree 199H
go to manufactor website and download all the driver's or use DRIVER MAX to find your driver's
Posted on Jan 17, 2009
Jay_Sav
  • 93 Answers
SOURCE: adjusting the horizontal & vertical to be proportionate
You need to set the correct resolution for your monitor,
To do this, minimize all windows, and right click on your desktop (not on an icon). Select properties, and go to Settings on the tabs on top.
Drag the slider until your resolution matches that of the monitor. I use mine on 1600 x 1050. However if your card doesn't go that high, try either the next ones down until it looks normal, or try a driver update for your graphics card.
Posted on Mar 05, 2009
SOURCE: NEW WIDESCREEN TOOOOOO WIDE
Use menu button on monitor.
select menu.
select image setting
select aspect ratio
change aspect ratio to "Fit"
Posted on Sep 12, 2009
  • 101 Answers
SOURCE: Hannspree HF 257 25
Is the power light staying on or does that go out as well?
If the power light stays on and if you darken the room, can you see a faint image still on the screen by shining a flashlight at it (close). If there is a faint image it is either the inverter or the backlight tube.
JC
Posted on Jan 31, 2010
technical114
  • 1851 Answers
SOURCE: Hannspree 20" HF207 monitor display
The drivers is not a problem for your case. If you can not select the 1600X900 resolution (this is the native resolution for your monitor) the problem is at your VGA; it does not support this resolution. What is brand / model is your VGA (or if you use the on board at the motherboard what brand / model is your motherboard)?
In case of a problem or clarification, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Posted on Aug 23, 2010
I don't understand anything about changing the display settings on my Acer p215h monitor I push the buttons but can't figure out what to do
umm...usually if it is a desk top there will be buttons either on the side, front or back or even the top, one looks like a sun and another looks like a square thats normally half white and half black. they are your brightness and contrast...push either end of the buttons to adjust more bright or less bright, more contrast or less contrast.
Sep 16, 2012 | Acer P215H LCD Monitor
My hannspree monitor model # HF259H keeps flashing
Go to devices on your control panel and check the status of the video card under "properties". murf427
Aug 29, 2012 | Hannspree Recertified - HF-259HPB Black...
Have Hannspree 205 HF running Windows XP Pro. Display has shifted to the right, and I can't get it back to center. Any suggestions?
Turn the Hannspree-brand monitor on using its remote, then press "Menu."
Press and scroll the down arrow button to highlight "Setting." Press the right arrow button to enter the "Setting" menu.
Press and scroll the down arrow button to highlight "Aspect."
Press and scroll the right arrow button to change the aspect ratio from "Auto" to "Full," "Normal," Panorama" or "Zoom," depending on the type of image that you want to see on the screen.
Press "OK" on the remote control. Press "Menu" twice to exit the menu settings.
hope it helps
Nov 29, 2011 | Hannspree Computers & Internet
I have a 22" Hannspree HF 237 monitor about a year
It is the inverter problem maybe it is loose or cold solder already. You better open the unit and look for the inverter section then re solder all leg parts there.
Regards;
votit
Feb 08, 2011 | Hannspree HF237HPB 23 inch LCD Monitor
Hannspree 20" Monitor HF205 - What is its' power
Max Resolution 1600 x 900 • 15000:1 Image Contrast Ratio • 5 ms Response Time • 34 Watt Power Consumption
techbelkin
Dec 13, 2010 | Hannspree 19" Widescreen LCD Flat Panel...
Recently purchased HF 205 monitor. Now I have a vertical yellow line running down the center of the screen and cant remove it ? any thoughts
You have failing T-CON board (part of the LCD panel assembly), it will get worst with more lines appearing.
You can try reseating the ribbon cabel on the T-CON board to see if it helps.
See pictures here:
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Jun 15, 2010 | Hannspree 22" widescreen LCD Flat Panel HD...
Can not access PC Brightness or PC Contrast - only X Contrast
From p.29 of the manual
"Brightness, Contrast, Sharpness, Color, and Tint are only available for adjustments
if you select User in Picture Mode.
Press / on the remote control or VOL+/ VOL- on the control panel to adjust these settings."
Apr 12, 2010 | Hannspree 28" Widescreen Flat-Panel LCD HD...
Dell 991 monitor
On the front of the monitor is a menu button. Press it, and using the left and right buttons on the monitor navigate through the menus until you see brightness, contrast, etc. Then adjust them as necessary.
Steven
Sep 17, 2008 | Dell M991 19" CRT Monitor
Need help with Compaq MV5500 CRT 15 inch monitor
hi there, your switch botton is failling, manual buttons on the front to adjust controls, do some switch test, replace micro botton switch. ty
Dec 26, 2007 | Gateway FPD2275W LCD Monitor
Need help with Mitsubishi 15
Try pushing the contrast button, and then some of the other buttons once the contrast menu is up. To control those menus you use the buttons on the front of the monitor, not the keyboard and mouse.
Nov 24, 2007 | Intel (RK80532PG0881M) Pentium 4, 3 GHz...
Hannspree 22" widescreen LCD Flat Panel HD Monitor Logo
588 people viewed this question
Top Hannspree Computers & Internet Experts
 Chuck N
Chuck N
Are you a Hannspree Computer and Internet Expert? Answer questions, earn points and help others
