Question about Vacuums
I have a Hoover Windtunnel Dual V. The vacuum and I did a tumble down stairs and the handle release pedal was broken. Is that something I can order a part for and have my husband put on? If so, where would I obtain the part? Thanks. Roxanna Kindler
    An expert who has written 200 answers of more than 400 characters.
  • 310 Answers
Generic problem for all Vacuums
Posted by ekindler on May 27, 2008
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
Yes, you can purchase the part @ any Hoover factory authorized store or your local vacuum dealer in your area and I also will give you some suggestions listed below. If you check your owner’s manual the part can be replaced by your husband if he is handy or otherwise refer to a vac dealer. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions. Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST 1-800-657-1874 Customer Service
Thanks, Don the Vac Man
Go Ahead. Use Us.
Posted on May 28, 2008
How to remove the hoover windtunnel handle release lever
Tilt the handle back and pry it out with a flat blade screwdriver.
Jan 23, 2013 | Hoover U6630-900 WindTunnel Bagless...
Need to preplace handle release pedal
To remove the old pedal, simply insert a screwdriver along it's outside edge, and pry upward to pop it out. The new pedal, (#38434026) can be pushed into place with your fingers. Install it with the handle in the upright position.
Feb 18, 2011 | Hoover U8147-900 WindTunnel V2 Bagless...
Foot controlled handle release lever is broken. Where to get parts?
I had same problem - the foot release pedal would not spring into place when unit was upright (but would work if you nudged in place with your foot). I installed a replacement part, and it didn't fix the problem. I cut out a small sqare of sponge and jammed it behind the flat end of the bent plastic spring on the release pedal, and it now springs back as it shoud. Hope this helps.
Jan 11, 2010 | Hoover U6630-900 WindTunnel Bagless...
Stand up lever is plastic, broke when stepped on to release handle, can it be repaired, replaced with a better one, plastic breaks too easily?
The pedal release can be replaced but the base will need to be checked for cracks as well. if the base is broken most common is the socket the pedal release snaps into. some of the plastic parts have been made with better materials
Oct 20, 2009 | Hoover Ultra U6430-900 WindTunnel Bagged...
Foot latch is broken. need to replace with new one. how does one access to remove the foot pedal latch. By foot latch, I mean the foot lever that releases the upright to lower the handle and begin...
it is accessed from the bottom underneath by the rear wheel. However, If there are and cracks on the pedal release socket area then the base will need replacement. parts are little cost but the unit needs to be completely disassembled.
Oct 17, 2009 | Hoover U6446-900 WindTunnel Bagged Upright...
Hoover savvy handle release pedal does not retract. There does not seem to be any mechanism to force it back, is something broken or missing, like a spring?
yes the handle release pedal is broken. i have the same problem and ordering the spare as i'm writing this email
Jul 07, 2009 | Vacuums
Broken vac
The pedal release lever should be available through a Hoover dealer at a minimal cost.
Feb 25, 2009 | Hoover V2 U8130-900 WindTunnel Bagless...
Front drops down when lifted
MaryEllen, This vac is only $250 to replace. By your description, the part you may have broken is called a pedal release lever. Very inexpensive to replace, under $7.00; Yes, you can replace it yourself, it does not go in too easy or the old one may not come out too easy. I would suggest that someone you trust that is handy look at it. I would also make sure the socket in which the pedal snaps into has not been damaged or cracked. You can inspect it with a light by turning it over. if there are cracks or damage to the base unit, the cost is higher but can be cost effective for repair
Feb 24, 2009 | Hoover U6616-900 WindTunnel Bagless...
Vacuums Logo
203 people viewed this question
Top Vacuums Experts
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
