Question about Campbell Hausfeld 2000 Psi Gas Pressure Washer PW2002
Pressure washer starts then stops immediately
How to adjust the unloader valve.
With a pressure gauge. If it's a home duty model it can usually be turned all the way in without damaging anything. Try turning it all the way in and fire it up. If the engine/motor doesn't groan or stop, you're probably okay. If the unit stops or slows down when gun is closed, immediately open gun, then shut down. With unit off, back off on unloader setting and set with pressure gauge, or have it done by a professional.
Aug 23, 2014 | Craftsman 3000 PSI 27 GPM Briggs ...
My 580.752000 pressure washer now starts and immediately shuts down. It is as if it is full choked and stops due to over rich. Sooty spark plug and muffler replaced. Also new carb installed. Still problem...
This seems to be an electrical problem, replace your spark plug, & lead. make sure your electricals are all OK.
Check your "Points" also check, your magneto too... Ensure you have a good healthy spark.
many problems are caused by bad electrics,and mistaken for all sorts of problems, this all needs to be checked thoroughly.
Also check your air filter too.
troubleshooting link below to assist you.
http://pressurewashers.lifetips.com/cat/61621/troubleshooting-your-pressure-washer/index.html
below is a great site to show you what to do.
http://www.repairfaq.org/samnew/lmfaq.htm
Aug 16, 2010 | Craftsman Garden
No power
The most common problem is the unloader valve.The valve that you use to adjust the pressure need to come out and then free up the unloader valve with some penatrating oil and maybe even some emery cloth.If you cant free it up then it will have to be replaced.
May 09, 2010 | Karcher K2.26 Electric Power Washer
Engine keeps shutting down
Most Honda engines have an oil pressure switch that prevents engine damage due to low/no oil pressure. Make sure there is sufficient oil in the engine and that the wire is connected to the pressure switch.
May 28, 2009 | Karcher 2500 PSI Pressure Washer
Kenmore he2 wont fill with water
first off check your incoming water supply.. also make sure your not using stainless steel hoses manufactured withthe name "flood safe"" big issue with these hoses shutting off premature(they have a built in shut off check valvewithin the hose itself, .. replacethehoses if you have these. if not and you have good incoming water supply, soundslike yo may have a faulty inlet water valve.although usually onyl no hot or no cald the fact you haveno either water temp, thats odd
Mar 04, 2009 | Kenmore HE2 Plus Front Load Washer
Campbell Hausfeld 2000 Psi Gas Pressure Washer PW2002 Logo
350 people viewed this question
Top Campbell Hausfeld Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you a Campbell Hausfeld Air Tool and Compressor Expert? Answer questions, earn points and help others
