See if camera electronics can be reset. Contact the manufacturer for this procedure. If nothing can be done to restore camera to factory defaults then the electronics are fubar. May not be cost effective to repair.
The A410 works with SD cards. Your 8GB card is an SDHC card and won't work in devices not designed to use them. You need to use SD cards, 2GB and smaller.
You can use any MMC or SD card. Be careful not to get SDHC or SDXC cards, they won't work in the A410. The brand doesn't matter, though I'd stick with the major brands, like Lexar, PNY, and SanDisk. The speed doesn't matter much either, so I wouldn't waste money on fast cards.
There are several possible causes for "memory card locked", "memory card error", or "no memory card". Troubleshooting steps for this problem are listed here. If this doesn't help, consider trying Canon at 1-800-OK-CANON.
Make sure that the card is 2GB or smaller, the camera only supports SD not SDHC so it won't recognize a card larger then 2GB. If it's 2GB or smaller format it within the camera and then you should be good to go.
No, it doesn't support SDHC, the following card types are supported by Canon MP500 :
CompactFlashĀ®, Micro DriveĀ®, SmartMediaĀ®, Memory StickĀ®, Memory Stick Pro ā¢, SD Cardā¢ and MultiMediaCardā¢
And these are the cards which can be used with respective adapters:
xD-Picture Cardā¢, Memory Stick Duoā¢ Memory Stick Duo Proā¢, miniSDā¢ card
Hope this helps.
Let me know if you need further help.
Good Luck.
Thanks for using FixYa.
If your camera is indeed an SD200, am sorry to say an 8GB SDHC will not work in this camera. The camera will fail to recognize it, and will do this by giving various problems as you've run into. The overall problem is that the camera was designed before the SDHC format came out (SDHC cards although the exact same in appearance are different in format than standard SD cards). The largest size card that the SD200 will recognize is a 2GB standard SD card.
