Our Toshiba Copier has A5-R on the display and will not copy at 100%. I either get the top and bottom of the pag4 cut off or the copier prints it at 50% of its real size. Help!
  • 149 Answers
A5 R is a European paper size. Check the tray settings. Toshiba usually do not have auto size settings, and the size needs to be set in user setttings thru the utility button. look for drawer icon
Posted on Oct 05, 2010
Copystar CS-2050 cutting off edges when copying or scanning
Check your default paper size. It may have been set for A5.
Apr 07, 2014 | Copystar CS-2050 All-In-One Printer
I can't get my toshiba estudio 162 copier to print 8.5 by 14 inch copies. how can i change the length?
Drawer feeding:
A3, A4, A4-R, B4, B5, B5-R, LD, LG, LT, LT-R,
FOLIO, COMPUTER, 13"LG, 8.5" x 8.5", 8K, 16K, 16K-R
Bypass feeding:
A3 to A5-R, LD to ST-R, FOLIO, COM-PUTER, 13"LG, 8.5" x 8.5", 8K, 16K, 16K-R
Jun 25, 2012 | Toshiba e-Studio162D Copier
When I print the page is printing out chopper off on the sides..
Not completely sure what you mean here but if the images are cutting off the copier may need an alignment. Also a possibility that the paper drawer used by default is the cause, if the pages are shifted as it pulls them your images would be cutt off on the prints & copies.
Sep 01, 2011 | Toshiba E-studio 281c Copier
How do i print envelopes on this copier
Most copiers have a stack bypass or single sheet bypass with adjustable walls. hit the paper select key to choose the bypass and run a test sheet to see which side it copies on. Some copiers copy on the top while others copy on the bottom.
Good Luck
Apr 17, 2009 | Toshiba E-STUDIO 650 Copier
Toshiba 2060 Photocopier prints copies that are a bit too dark.
restart the copier while holding down the "0" and "5" keys. you will now be in service mode. enter "5" and press "start" key a number should show up in the display. this is the exposure value - how dark or light the copies will be. 5 is the automatic exposure setting. around 128 is the normal value. the larger this value the lighter the copies are - the smaller the value the darker the copies.
Enter a new number (exposure value) and press the "interupt" key to save the value. Restart the copier and check what the copies look like. Keep adjusting until it looks good/better.
Mar 26, 2009 | Toshiba 6560 Copier
Partial print
Are you sure you have the paper aligned correctly?
should be left top or center.
Do you have the correct sive paper (Letter instead of A4)?
What happens to the rest of the copy : cut off, blank, black?
Is the scanner light staying on when scanning the whole page or does it die out when it scans 3/4 of it? ( bad scan cable or board)
Jul 31, 2008 | Sharp AL 800 Copier
Toshiba 2860 Plain paper copier
It maybe the waste toner container is full try emptying it
Feb 19, 2008 | Toshiba 2860 Copier
Toshiba 3160 copier
Would you say that the bottom half is Ghosting? if so then the fuser hot roller teflon has worn and will need replacing.
If not please check the optical mirrors (Do not remove them only remove the top glass) for dust.
Sorry cannot be anymore help as you may possibly need a engineer call out.
Thanks J
Jan 16, 2008 | Toshiba 1360 Black and White Copier
k24674
jasbo
jasbo
