Question about GE DWXR483EBCC Electric Dryer
Dryer Model : DDE8500RCMWH The dryer keeps drying after the clothes are dry. Sometimes it runs for 90 min.
gittos73
  • 244 Answers
SOURCE: Keeps on cutting out on Hot drying cycle
this will be a problem with your thermostats 1 of them will have a thermal cut-out switch built onto it this thermostat needs replacing it is faulty
Posted on Aug 15, 2007
SOURCE: Squeaky Dryer
Master_Tech:
I have the same model number and the same squeaky problem. I could use the same fix that you gave bebowser.
thanks
skuterbum@yahoo.com
Posted on Apr 16, 2008
docjohn174
  • 943 Answers
SOURCE: DBXR453ET3WW Electric Dryer Won't shut off unless on timed cycle.
hi thanks for the question in the ge dryer theres 2 elements so if one is not working you only get half heat i would check the heater thanks the appliance doc
Posted on Sep 27, 2008
SOURCE: Dryer takes too long to dry my clothes
My dryer has been taking longer and longer to dry my clothes. Sometimes it takes multiple cycles before the clothes become dry. They seem to be getting warm, but are not drying as quickly as they use to.
Posted on Oct 05, 2008
  • 3 Answers
SOURCE: LG DLEo332W electric dryer not drying full time
you have to change out the timer motor...
http://www.partselect.com/repair.aspx?appliance=dryer&part=dryer-wont-heat
Posted on Mar 27, 2009
Kenmore dryer 90 series
Since no model number was given, check to see if you have a setting commonly noted as "wrinkle guard", "wrinkle shield", "press care" or something to that affect. Those settings will run the dryer for as much as 90 min after a completed drying cycle to prevent wrinkles in clothing, allowing you time to remove the cloths after a dry cycle if you are busy. Pleazer Appliance...
Apr 09, 2014 | Dryers
Bosch Nexxt 500-series electric dryer problems - Dryer never finishes complete cycle of drying clothes. When attempting to restart, the display will show 20 (mins) even though I've pushed something di
did you clean the LINT filter? try vacuuming the lint trap area. wet or damp lint can get built up in the lint trap area. it is good to regularly clean the area as it is a Major fire hazard.
Mar 12, 2014 | Bosch Nexxt 500 Dryer
MY DRYER WILL NOT DRY THE CLOTHES WHEN I USE THE REGULAR CYCLES. I HAVE TO DRY THE CLOTHES ON TIMED DRY FOR 90 MINUTES AND THEN SOMETIMES THEY ARE NOT COMPLETELY DRY. THE DRYER IS DEFINATELY GETTING HOT,...
Your vent system is more than likely stopped up..You may have to pull the dryer out and clean the flexible hose that connects the vent to the outdoors
Apr 12, 2011 | Dryers
I have a GE washer/dryer Model WSM2700RAWWH stack type and the dryer is taking very long time to dry the clothes. Please advise if it can be fixed. If not what will be best alternate washer/dryer stack...
first things first. if any dryer regardless of brand takes 2-3 hours to dry cloths 90% of the time it is your exhaust duct. take the exhaust duct off the back of the dryer and dry some clothes if the clothes dry fast then you need to have your exhaust duct cleaned. either DIY or call a professional
if it still takes a long time to dry then it could be the thermostats or the thermistor.
but in my experience its normally the exhaust duct.
Feb 10, 2011 | GE Washing Machines
Model/stock #...66904/669. Having to run 3-4 cycles to completly dry clothes
Sounds like your problem could be the thermostats or the heating element, they will normally cause the dryer to take a long time to dry the clothes
Sep 26, 2009 | Kenmore Dryers
DRYER RACK DOES NOT DRY CLOTHES
try timed dry cycle instead of the auto-sensing setting. In your drum if you have auto dry such as less dry normal dry and more dry, There is a sensor sometimes in the drum and sometimes in the exhaust right after the blower. If in the drum then your clothes brush by this and if moisture is sensed then it keeps on drying. With your rack the clothes can't touch the sensor so it tells your dial to turn and that items are dry which in fact are not. Try this and see how it does.
Feb 17, 2009 | Samsung 7.3 Cu. Ft. 9-Cycle Electric Dryer...
UN-ending Auto dry cycle
This is caused by the dryer vent being blocked and not allowing the moist air to be removed from the dryer. To confirm this. Dry a load of close in a timed dry setting. Set the time on a specific time and then start the dryer. Wait for about 5 min. See if the timer has moved. If it has then the problem is not the timer. It is the exhaust vent being plugged up somewhere. Moisture how the auto dry setting works. The dryer sences moisture and runs longer to dry your clothes. With the dryer exhaust vent blocked, wet moist air is comming back into the dryer and fooling the sensor into believing the close are not dry and runs for a very long time. It is not uncommon for this problem to cause a dryer to never shut off. Your dryer exhaust vent is plugged up with lint somewhere.
Nov 10, 2008 | Dryers
Jun 18, 2008 | GE DBXR463EBWW Electric Dryer
Dryer won't dry
  1. thermostate 2 the gas valve cylanoids the 2 black things on top gas valve can be bad will heat then stop heating 4 awhile thay drop out dont open valve watch your valve listen 4 it if comes on run heat goes off dont come back on 4 awhile 3 5 min bad valve cylonoids
Dec 29, 2007 | Kenmore 64952 Electric Dryer
GE DWXR483EBCC Electric Dryer Logo
141 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
