Question about Nokia N70 Cellular Phone
Autoamatically loading loudspeaker option and multimedia utility.
Hi
i hav N70 ,wenever i make a call ,loud speaker automatically loading up and call is being interupted after that could be seen "4444" on my diaplay.....
and watever utility assaigned for multimedia key is also loading up. has anyone heared about it ,if so plz get me a solution..
  • lalettan May 30, 2008
    Thanx..raysagem..but i update firmware thrice from nokia service centre,no use !!! well.my cell now restarting without any external cause and i tried my cell without memory card also.
    could u tell any other way..
  • Anonymous Nov 28, 2008
    my n70 makes same problem.when calling loud speaker,radio option,gallery,etc open automatically
    President:
  • 1,017 Answers
I think your phone may need a Software/Firmware update. Before doing that, try resetting the phone:
Take your SIM card out.
Make sure your phone battery is fully charged.
Press * 3 send at the same time and turn the phone on. Keep them pressed until the reset screen appears.
Give it time to reset.
Yes! I know. You need someone to press the ON button.
Then update the Software (sometimes called Firmware) thus:
You need to download the latest Nokia PC Suite to do an update on your phone.
Before updating software you should check that there’s a newer version of software available.
WARNING
When updating software on Mobs, be sure to:
HAVE A FULLY CHARGED BATTERY INSERTED;
PUT IT ON GENERAL PROFILE;
TURN OFF YOUR PIN NUMBER;
CONNECT YOUR CHARGER TO YOUR MOB AND SWITCH IT ON;
DO NOT ----- DO NOT ---- TOUCH YOUR PHONE WHILE THE UPDATE IS GOING ON;
THIS CAN TAKE 30 MINUTES OR MORE.
And obviously don’t unplug the phone from the PC.
Be patient, you may have to do a restart or two on your mob afterwards. Even remove the battery to get it going again (not recommended). But give it plenty of time.
It is also wise not to use your PC while updating software, just in case the PC freezes.
If the PC freezes during an update, you’re up the creek without a paddle...
I did an update on a Sony Eric 810i it took nearly two hours.
More... Your phone turns itself on and off, sometimes more than once while updating software, you should leave it well alone during the update.
Posted on May 28, 2008
  • Raysagem
    Raysagem May 28, 2008
    If the Nokia website shows that you already have the latest Software, do an update anyway.
When I make/receive a call, the phone is automatically on (loud) speaker.
http://www.applevis.com/forum/ios-ios-app-discussion/every-time-i-make-or-receive-phone-call-automatically-goes-loudspeaker
Mar 10, 2014 | Samsung Galaxy Pocket
In my nokia N70, call is getting disconnected and loud speaker activated, music player opens and 4 numbers displayed on the screen every time.
Hi! nothing to worry! here are the simple steps to solve ur problems!
first of all move to settings on ur phone menu! then click phone and call option then hit call option here change option for loudspeaker, volume, call disconnecting, etc after these ur first problem solved! based on ur question i suggest u to set default settings to ur phone !these are simple it appears on phone menu->settings->phone->phone original settings->it asks password if u already assign or else simply try to enter 12345 thats it . it ask u to restart phone! don't worry ur data wont loss! it will be safe! still u facing problem means ! try to format ur phone! its simple u wont waste money! simply follow these: remove ur mamory card, try to backup messages, contacts and media, etc! then turn off phone, renove sim card! then press with ur hand with the following buttons *,3, dial for five to 10 seconds then press power button ! phone ask u to format or not press format! then thats it ur phone formated to original state at the time of purchase! try to use antivirus to protect ur phone, avoid bluetooth to reduce such type of risks..! thats it! hope so u understand! plz rate if u like! Thank U!
Jun 08, 2011 | Nokia N70 Cellular Phone
Music player opens automatically, o, 4's numbers dial automatically, loudspeaker activates while call and call ends, cannot make video more than 1 minute
take a look at the settings of music player, fixed dial number, loudspeaker, and call limit and video limit of your phone...
Sep 06, 2010 | Nokia N70 Cellular Phone
How do i turn it on to load speaker? thanks
when you are calling or receiving any call you will get a option of loudspeaker on main screen or select options and select loudspeaker on.
May 17, 2010 | LG Shine (CU720) Cell Phone
Hoe to turn on loudspeaker in nokia 2760
During a phonecall, you will just have to press the button, usually the right option button where the "Loudsp." is aligned to it.
Also, when you want to listed to an audio message, select Options and select Loudspeaker.
Hope this helps.
Nov 06, 2009 | Nokia 2760 Cellular Phone
Auto turn off and turn to loud speaker
Please use another good fully charge battery to test it, if it gives the same problem get the phone to a Nokia care center or get a trustworthy phone technician to check it for you
Jul 29, 2008 | Nokia N70 Cellular Phone
Call dropped down...
Try to restart and clean inside maybe numbers stuck or just needs to restore on factory settings again if you need to have a pin **** its 12345
Jun 01, 2008 | Nokia N70 Cellular Phone
Loud speaker during call
When the call will be in progress u have to see on the right handside corner of the screen of ur handset, option of "loudspeaker" will be there OR u go to "options" on the left handside of corner of screen.Press it and loudspeaker will get activated.
Oct 20, 2007 | LG KG800 Cellular Phone
Nokia N70 Cellular Phone Logo
185 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
