I have a charmglow propane heater ventless w/logs. I've blew it out and cleaned it but it still won't light. cgo5o11893
  • Patrick Warren
    Patrick Warren Oct 04, 2010
    the igniter is sparking it doesn't seam to be getting all though my other heater is working.Can't smell any gas
    President:
  • 2,777 Answers
You are certain the gas is flowing properly, and the igniter is sparking? Can you light it manually, or have you tried?
Thanks
Tim
Posted on Oct 04, 2010
  • Tim Grayson
    Tim Grayson Oct 04, 2010
    It sounds like something is blocking the flow of gas in this case... That could be very hard to determine, and somewhat dangerous to fix. You may want to call in an expert at this point locally... If you can't smell the gas going that is a bad sign for sure.
    Tim
Emberglow ventless gas logs (set to burn on porpane gas). Pilot lights, but not logs.
It needs 14'' wc to work , hose could be too small for load .
Dec 06, 2012 | Heating & Cooling
I am needing a new blower for Charmglow propane ventless fireplace #cgn300tq
I can't find an owner's manual anywhere for this fireplace, but you are welcome to see if any of these universal fan kits look similar: Universal Fireplace Fan Kits.
Nov 30, 2012 | Heating & Cooling
I have a Charmglow ventless gas heater after it reaches temp, the pilot light goes out.
I have had a Charmglow for about five years and was doing the same thing. I called a plumber that worked with gas fireplaces and he came out, clean the pilot light and now it works great. Cost was $99.00
Jan 09, 2011 | Heating & Cooling
Charmglow ventless gas fireplace burners won't ignite
is pilot flame on the thermopile good, pilot flame should cover the thermocouple and thermopile if unit has both
Jan 07, 2010 | Blue Flame Charmglow 30K BTU Propane Vent...
Pilot light won't light on ventless fireplace
Ventless Gas logs, Vanguard, VS30PR. Propane gas
Pilot light stays lit various times, sometimes for several days then other times for a few minutes. Lights best when temp outside is below freezing. Pilot flame appears to receive too much air. How do you adjust the pilot flame? Is this done using two screws marked A & E? Do you have suggestions?
Thanks,
Ed
Jan 07, 2010 | Desa International Unvented Gas Space...
I have Legacy ventless propane heater 15,000btu.
Try to take pilot assembly apart and clean real good. This will work most of the time. If it does not work for you, you will need to replace the gas valve. It's expensive but I'm about positive that cleaning it will fix it. Gas burns dirty and after a couple seasons a scale builds up that causes this problem. It's pretty common and nothing to worry about after it's cleaned. Good luck.
Oct 17, 2009 | Dyna-Glo Heating & Cooling
My ventless propane heating stove shuts off by itself
I have a Rinnai Ventless heater hooked up to a 20 lb propane cly with a Moble home type regulator in line, and when I light it the pilot light lights and stays on. When I turn it to the heat position the pilot light go's out and that it!
Jan 28, 2009 | Rinnai Desa Vent-Free Infrared Gas Heater:...
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
