Question about Canon EOS-50E 35mm SLR Camera
Canon eos 50 flash
Just want to know how to turn it off so it does keep popin up when i dont wnat it to
  • 2,039 Answers
According to the manual, if you have the selector set in any of the "creative" modes (P, Av, Tv, M) the built in flash will only work if you press the button to pop up the flash. It also references a "hot shoe cover" which, if inserted into the hot shoe for external flash, will prevent the built in flash from working.
You can download the manual here. (The EOS Elan II is the same as the EOS 50.)
Posted on May 28, 2008
External flash not firing in manual mode
In order to have your "External" flash work on your Rebel XSI, you need to go into the menu and turn on the external flash function. If you dont know how to enter into the menu mode, refer to your operating manual.
Nov 22, 2013 | Canon EOS Rebel XSi Digital Camera
The camera doenst start the ligth of empty battery is flashing the camera dont start
check for a blown fuse in the DC/DC board. Board is on top after you remove top cover, and the fuses are covered by a shield plate you have to unsolder. Fuses are very small and have letter codes like P or K
Mar 30, 2013 | Canon EOS 60D Digital Camera
The metering screen inside the viewfinder keeps flashing BUSY, and the display screen will not show anything.(Canon Rebel XS Digital SLR)
I can help you fix the BUSY Error or Error 99 of your Canon EOS Rebel XS / Canon EOS 1000D.
Installation of this Canon EOS Rebel XS / Canon EOS 1000D firmware version 1.06 update will solve these problems:
  1. Some cameras may exhibit a phenomenon in which the LCD monitor does not display, the shutter does not release, and the BUSY indication remains lit in the viewfinder.
  2. The message, "Err 99 Shooting is not possible. Turn the power switch to<OFF> and <ON> again or re-install the battery", appears on the camera's LCD monitor, and after the above operation is carried out,the LCD monitor displays in a language that is different from the actual language setting.
See the firmware instructions and download the firmware upgrade by following these Fixya Tips :
  1. Follow this link to download a pdf version of the firmware installation instruction guide.
  2. Follow this link to download the Windows Version of the Canon EOS Rebel XS / Canon EOS 1000D firmware version 1.06 update.
  3. Follow this link to download the MAC version of the Canon EOS Rebel XS / Canon EOS 1000D firmware version 1.06 update.
  4. Follow this link to download the Canon EOS Rebel XS / Canon EOS 1000D Instruction Manual.
I hope that helps.
Mar 01, 2010 | Canon EOS Rebel XSi Digital Camera
Canon Rebel XS says it's busy
I can help you fix the BUSY Error or Error 99 of your Canon EOS Rebel XS.
Installation of this Canon EOS Rebel XS firmware version 1.06 update will solve these problems:
I hope that helps.
May 29, 2009 | Canon EOS Digital Rebel XS / 1000D IS...
The built-in flash on my Canon EOS 450D camera won't pop-up
Had the same issue and just tried this....and it worls [PS dont use the littel plastic hotshoe cover as this keeps the microswitch depressed]
If you manually 'help' the flash to open and it doesn't pop; the microswitch under the rails of your hotshoe is probably stuck in the down position as mine was. I used a toothpick top pop it up and it works now!
May 15, 2009 | Canon EOS 450D Digital Camera with 18-55...
The only problem with SD card download stuff is that the LCD screen has to be working. If that is part of the problem, how can the instructions be followed?
Mar 22, 2009 | Canon EOS Digital Rebel XS / 1000D IS...
Keep getting ERROR 5. Dont know how to fix....also, cant increase shutter speed beyond 250. Not good enough for HS football action...
Depending on the flash you are using, 250 may be as fast as you can go. That may be the limit for the internal flash. A big external flash can go faster because it requires more power.
Dec 08, 2008 | Canon EOS-20D Body only Digital Camera
F stop on a Canon EOS 50
The EOS 50 is the same as the EOS Elan II, and you can download the manual here.
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=313&modelid=8196
Page 54 explains setting aperture in Av mode, and page 56 explains setting aperture in the Manual mode.
Dec 31, 2007 | Canon EOS-50E 35mm SLR Camera
The flash keeps flashing
hi sneakers
the camera is firing the flash to help it auto focus,the only way to stop it find an area of the picture that has more light/contrast or switch to manual focusing.
regards
ian
Dec 27, 2007 | Canon EOS 400D / Rebel XTi Digital Camera...
Canon EOS-50E 35mm SLR Camera Logo
137 people viewed this question
Top Canon Photography Experts
old marine
old marine
pontelemon
pontelemon
Are you a Canon Photography Expert? Answer questions, earn points and help others
