Question about Braun Tassimo Coffee Maker
Tassimo-leaks water - Braun Tassimo Coffee Maker
  • Braun Master
  • 1,711 Answers
From experience in your model and also other espresso machines there are many possible points that you may have the leak. The pump, boiler, volumetric dozer, water/steam valve are connected together with Teflon pipes and supports at the ends with the clips and one "o" ring. In one of this point the clip can slip out so the Teflon hose to be loose and so the leak. There are also some cases if the machine is more that 2-3 years one of the above parts to leak itself due to tearing out and it might need to be replaced.
So you need to remove first the top panel and then the side panel and work the machine with extra safety since we have power wires and with visual check to find the point of leak.
If it is just the Teflon pipe and clip slip out the secure it back again, if it one of the part you can try to tight up and if the leak insist then you need to replace it.
Posted on Dec 01, 2010
2 Suggested Answers
SOURCE: Tassimo machine leaking water underneath
I'm having the same problem with my machine. I rang the Tassimo careline and they told me to descale the machine but, so far, this has only made matters worse. I'm now going to take it back to where I got it from because it's still within its warranty.
Posted on Nov 20, 2009
The lid won't open to get the used coffee pod out. It seems to be stuck.
Customer questions and answers for Bosch TASSIMO T10
answers.tassimodirect.com/answers/.../bosch-tassimo.../questions.htm?...
The TASSIMO T10 Single Cup Brewing System by Bosch brings the artistry ... the machine made some funny noises and now I cant open the lid to remove pod. ... When I went to remove the T-disc, the tassimo won't open so I cannot get it out.Missing: tas5542gb
Bosch Tassimo TAS4511UC Coffee Maker Open ... - Fixya
www.fixya.com > ... > Bosch Tassimo TAS4511UC Coffee Maker
Question about Bosch TASSIMO Coffee Makers & Espresso Machines ... colors, openthe lid, put disc with the cream in the machine and the green light won't come on, only the . ... Bosch Tassimo Tas5542gb Multi Hot Drinks Machine, Black.
Why has my Tassimo brewer stopped working?
www.coffeedetective.com/why-has-my-tassimo-brewer-stopped-working...
QUESTION: I have a problem with my Bosch Tassimo brewer. ... Now when I close the machine, I open it and remove that litte tin foil circle. ... Opened my new Tassimobrewer and won't brew and water dispenser leaking all over... an ... I have a problem with my tassimo coffee maker the lid wont lift up seems stuck any ideas ...Missing: tas5542gb
Jan 19, 2016 | Bosch Tassimo Tas5542gb Multi Hot Drinks...
How to repair water leak from tassimo base?
The water tank at the rear must make a proper seal. Make sure it is clean and lubricate with Vaseline. The cup tray also catches drips so remove it and empty any water into the sink.
Nov 04, 2014 | Braun Tassimo Espresso Machine/Coffee...
Water sat in the bottom tray of my tassimo t65 and now it has two red lights flashing can I fix it
Bosch Tassimo T65 Repair Questions,... - Fixya
www.fixya.com > ... > Coffee Makers & Espresso... > Bosch > TASSIMO
0 Answers. Water sat in the bottom tray of my tassimo t65 and now it has two red lights flashing can I fix it · Bosch Tassimo... ' Posted on Aug 23, 2014 ' Be the ...
Bosch TASSIMO red light water full Unsolved Problems - Fixya
www.fixya.com/unsolved_problems/red_light_water.../tassimo
0 Answers. Water sat in the bottom tray of my tassimo t65 and now it has two red lights flashing can I fix it. Aug 23, 2014 ' Coffee Makers & Espresso Machines.
Bosch TASSIMO cleaning condensation tray Unsolved ...
www.fixya.com/unsolved_problems/...condensation_tray/.../tassimo
Aug 23, 2014 | Bosch Tassimo T65
Tassimo low water light will not reset
The problem is because Tassimo water tanks have a floating magnet in them which operates the water level switch inside the body. The magnet gets weak over time. Replacement tanks cost too much to be worth the cost. The simple answer is to stick a fridge magnet on the back of the unit (just above the power switch) using blue tack or similar (you can experiment to find the right position). Our unit has been working fine like this for a few years now. :-)
May 24, 2014 | Bosch Tassimo TAS4511UC Coffee Maker
Bosch Tassimo TAS1000UC/01 Water leaking under the machine
check and see if there is a rubber seal under neath if there is replace the rubber probably the rubber crystalized.good luck
Sep 25, 2011 | Braun Tassimo Espresso Machine/Coffee...
Hi, i turned on my tassimo it went bang and now leaks water from the bottom.
I suspect the same thing happened to your Tassimo as happened to my friend's two previous machines! Fortunately I think I found the problem and it's easily fixable! Checkout http://www.stuartdalby.co.uk/miscellaneous/tassimo_repair/index.php
Stuart
Jan 22, 2011 | Braun Tassimo Espresso Machine/Coffee...
Oct 06, 2009 | Bosch Coffee Makers & Espresso Machines
Return it, I called Tassimo & it's a problem.
Sep 15, 2007 | Braun Tassimo Espresso Machine/Coffee...
Leaky Tassemo coffee maker
i think it's supposed to do that. the cup at the base is supposed to be catching all the water that the tassimo is 'leaking'. it should be dumped after every cup of tea/coffee. if you have taller cups, and do not use the cup base that comes with the machine in order to fit the taller cups under where the tea/coffee comes out, then you are right. it seems like it's 'leaking' because it is. there should be enough room in the base for one cup, but then it can also be removed so as to dump the excess water out after the cup is made. hope this helps!
Feb 03, 2007 | Braun Tassimo Espresso Machine/Coffee...
Braun Tassimo Coffee Maker Logo
1,031 people viewed this question
Top Braun Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Are you a Braun Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
