Why do I get a "Black Strip"on one side of my copy ?
    Champion:
  • 202 Answers
Clean the scanner if you have the laser printer with scanner & if you have flatbed scaner then replace the scanner unit trailling cable.
Posted on Oct 04, 2010
When making copies, only a part of the document prints; the rest is solid black.
Solid black in a copy typically means that the scanner is partially blocked. Open the top, where you'd place a sheet to be copied, and examine the small strip that runs down the side (left, most likely). See if it's clear, or if something is covering part of it.
Most copiers don't use the full size scanning plate for copies, but use a strip that scans the paper as it moves across it. If something blocks part of it, you get the black area.
Apr 12, 2015 | HP Officejet Pro L7780 All-In-One InkJet...
Getting black strip about 9/16"
it may be due to either malfunctioning of the scanner tube within the printer itself or whenever you copy a certain page the lid is not properly pace resulting to excess light on that side giving you black line when the copying is in process
Mar 06, 2011 | HP Officejet 5610 All-In-One InkJet...
Single narrow black vertical line about 1 3/4 inches from right side of copy. Line runs the entire length of the copy. Happens only during copying color or black and white.
The line issue is caused by something on the image sensor. To get to it and clean it just pull the front up where you put the paper into it to scan. Inside you will find a glass strip, this is the image sensor. Use a paper towel dampened with window cleaner and gently scrubbing the glass strip, After cleaning the strip let it dry for a minute or teo before you close the cover and try a scan. It should be clear and should copy great again.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
Jun 18, 2010 | HP OfficeJet V40 All-In-One InkJet Printer
When copying A4 sheet 1.5cm black strip appears
you may have a problem in your scanner assembly
Mar 30, 2010 | Office Equipment & Supplies
When using the ADF for scanning to pdf, it creates black lines vertically down the left side of the document. If I use the flatbed scanner, no lines.
Your machine ADF is dirty or dust in adf glass please clean it by soft cloth and scane again its clear and sharp.
thanks.
Nov 24, 2009 | Brother MFC-7820N Printer
In copy mode I am getting a back strip along the left hand side of the copy. The strip also shows up in the preview. Strip used to be half inch thick and is now an inch thick.
Is any part of the image missing under this black strip, or is it just margin from the side of the document to the end of the glass?
If nothing's missing, then probably you set a larger original size in the settings somewhere.
Try a sheet of white paper the size of the glass, put on top of the (smaller) copied picture or document; when scanning it is not a big deal, you can always choose the area to be scanned, right?
If however part of the document is missing, this can mean that the photosensitive element is faulty and doesn't read a couple hundred pixels on that side and the device needs repair.
Oct 27, 2009 | HP Photosmart 2575 All-In-One InkJet...
Black strip on right side when I copy
Check in your user manual how to reset the printer to factory default. This should clear up your problem.
Oct 09, 2009 | HP LaserJet CM1015 All-In-One Printer
Black strip down right side of page when scan or copy
try to align you printer..or print a maintenance pages..
if the problem still persist ...
wipe it on a wet cloth...
May 14, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Black strip 1.5 inches wide on right side of page
first, take drum unit out and make sure the blueish-purple colored plastic tab on top of drum is all the way to the left side. if thats not the culprit, then you are most likely looking at a bad contact image sensor or CIS.
hth,
ray
Apr 03, 2009 | Brother IntelliFAX 4750 Plain Paper Laser...
Black lines on copies when run thru fax feeder
There is a thin strip of glass that you will see when you lift the top feeder. There is most likely white-out on it.
When you use the top feeder, it doesn't use the large glass, it only 'rolls' the original document over this small strip of glass.
Jan 18, 2008 | HP LaserJet 2840 Printer
22 people viewed this question
k24674
jasbo
jasbo
