Question about Samsung PCH521R 52" Rear Projection Television
Convergence is completely messed up and Audio drops
I have a Samsung Tantus PCH521R since 1999 and now every time I turn on the TV, the top half of the screen is completely messed up. After about an hour, it clears up - but the top potion still is not 100%. Both speakers work, but only one plays most of the time. Sporadically, the audio shuts off and I have to raise the volume really high for it to come back.
The convergence problem is more of an issue and I would be grateful if someone knew exactly what needs to be done. Can it be a convergence board replacement or something of that sort? Samsung is no help as they only want to send out a technician which will be an arm and a leg. If I know what to replace, I'm technical enough to replace it myself.
Can someone help me?
-Wil-
  • slimice May 28, 2008
    Hello Dorothy - yes I have been able to configure the convergence myself (mute 1-8-3). I've done it numerous of times and now I think the TV convergence is just shot. I am unable to straighten out the top (2) lines - it has a constant jitter and is slanted. Plus the BLUE lines are no longer available to setup in the convergence mode. I'm only able to fine-tune the RED and GREEN. The entire top half of the TV has this jitter as well when I first turn the set on, so I know it has to be something much bigger.
  • Dorothy Fremder
    Dorothy Fremder May 11, 2010
    Greetings slimice,
    Have you been able to perform convergence yourself via the setup menu on this unit? Or is the problem of much larger scope?
    Awaiting your response,
    Dorothy
    Go Ahead. Use Us.
Can someone tell me how to fix the convergence the red and the blue are messed up and the picture perfect doesnt work.
Posted on Jul 27, 2008
My samsung tantus shows picture but no sound
there is "audio out" jacks on back side of television. connect it to an amplifier or other tv & hear if sound is comming. if sound is comming then audio amplifier is defective in your tv. if sound is not comming then audio processor may be defective.
Aug 30, 2011 | Samsung PCH521R 52" Rear Projection...
Samsung tantus blinking red light
you need to general service the whole unit. this will include re-soldering and changing some defective components from the board, which has been damaged through using from past years. my advice is to have a quotation from service tech and then think about repairing it..if it is better to buy a new one..
Nov 16, 2009 | Samsung PCH521R 52" Rear Projection...
Can't find convergence IC's in my Samsung PCH521R rear projection
vance baldwin.com has diagrams in there parts section of there web site .it sould be behind the front grill
Jul 10, 2009 | Samsung PCH521R 52" Rear Projection...
Television will not turn on
you wiull have to check it with a meter if its getting short the meter will show zero reading other wise the faulty low reading.if thats the case the part has to be replaced. you can get the required parts at www.radioshack.com or at  www.partstore.com
Feb 26, 2009 | Samsung PCH521R 52" Rear Projection...
Samsung 52" tantus pch521r convergence panel
I found a this SITE that carries that convergence assembly for your TV.
Good Luck.
Mar 10, 2008 | Samsung PCH521R 52" Rear Projection...
Samsung 52" tantus pch521r no picture
1) Loss of color = bad solder connects on signal board
2) Loss of pix = probable CRT coolant leak onto signal board
Have a technician check it out.....can be expensive......T.
Nov 24, 2007 | Samsung PCH521R 52" Rear Projection...
Samsung tantus oct. 1998 pch521r
screen control must be turned down ,called retrace lines
Sep 07, 2007 | Samsung PCH521R 52" Rear Projection...
Samsung PCH521R 52" Rear Projection Television Logo
145 people viewed this question
Henry  Thomas
Henry Thomas
