Question about HP LaserJet 4600dn Color Printer
Our school has a HP Laserjet 4600 dn printer. We started school in sept. and it worked fine then after the 2 week it would not print in color anymore. The page comes out blank. It will however print in grayscale but you have to change the preferences each time you use it. I have tried reinstalling the software, changing the toner, turning off and on, called Hp but it is out of warranty. I explained that this was for a school but they didn't care we would have to pay for online help. We don't have the option to pay any fees maybe someone has encountered this problem and maybe there is a quick fix solution. Would appreciate any help. Thank you
    Champion:
  • HP Expert
  • 202 Answers
Hello,,,,,,,,power on the printer with pressing the green button and hold the button till whole lights lit on,relese the go button & select the cold reset by the up & down arrow Then press the go button it will take some sec then restart automatically. your colour problem will be resolved.plscomment if problem resolved
Posted on Oct 04, 2010
HP color laserjet 4600 folds paper
Clean the inside and check for any gunk built up try unplugging it for atleast 2 hours if neither helps then probably will need to be changed also try doing a calibration on it before buying item
Apr 26, 2017 | HP LaserJet 4600dn Color Printer
How do you make an hp color laserjet 4600 dn recognize a quill remanufactured cartridge?
In 35 years of doing this for a full time living, I have never seen worse products thany toner or developer than Quill.
I would not buy that stuff if they were the last manufacturer in this solar system.,
Sep 12, 2011 | HP LaserJet 4600dn Color Printer
How do i adjust the margins from the printer? HP color laserjet 4600 dn printer
Usually in "page preferences" in the file drop-down bar. Then use "print preview" to see if the page looks OK.
Mar 22, 2011 | HP LaserJet 4600dn Color Printer
My network laserjet 4600 only comes out black not color both when printing and just a information page from the device
http://h10039.www1.hp.com/cpso-support-new/pq/4600/home.html
Try the above troubleshooting steps for each color page that prints out for test pages.
Try to click on 'magenta' for instance, and follow the leads to a solution for your black only print problem.
Feb 10, 2011 | HP LaserJet 4600 Printer
HP color laserjet 4600 dn printer How do I set
From the control panel of the printer, do the following:
1. arrow down once to highlight the 2nd item: "paper handling".
2. press the check button (turquoise color) to select this option.
3. arrow down 2x's until you highlight the "tray 2 size".
4. hit the check button to select this item.
5. You should see a size that is "letter" and there should be a ' * ' asterisk which means that is the default setting. If you see other paper sizes as well, then arrow up or arrow down to highlight the preferred size, and then press the check button to insert the asterisk ' * ' which will set that as the default.
6. you change the paper type as well as paper size for the other trays in the same fashion. Most HP printers will select paper according to the SIZE as well as the TYPE. The printer can "sense" the paper size in the paper cassette tray by the stops that hold the paper. Therefore the printer will choose that paper based upon the SIZE and what you define as its type.
Sep 24, 2009 | HP LaserJet 4600dn Color Printer
Need to have 4600 laser printer in just black ,because of broken
Sorry, my friend, there is no way to force it go B/W and override the error message.
Sep 09, 2009 | HP LaserJet 4600dn Color Printer
HP Color LaserJet 4600 Keeps Calibrating
Replace the Jet direct card in it. I had a similar problem and replaced the Jet Direct card, all was good never had that problem again.
Apr 15, 2009 | HP LaserJet 4600dn Color Printer
11 blue dots print out down the left hand side of documents
It's probably the toner cartridge again. See if you can spot defects at the cyan drum unit that matches the marks on your printout.
Apr 14, 2009 | HP LaserJet 4600dn Color Printer
Vertical dots on print output
1 1/2 inches apart would correspond to the diameter of the primary charge roller. You have one chrarge roller inside each toner cartridge so you need to determine which color the dots are and then replace that cartridge.
Oct 22, 2008 | HP LaserJet 4600dn Color Printer
HP LaserJet 4600dn Color Printer Logo
102 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
