Question about ViewSonic VP930b 19" LCD Monitor
Monitor the light on my monitor blinks but the screen doesn't display anything
  • 1 more comment
  • monstrt Oct 26, 2008
    screen is black (blank) green light flickers and trying to plug it into my laptop gives me the same result. so does mean that both of my expensive, just past warrenty monitors are ****?! Can it be fixed for less than the cost of new?
  • gknoettner Dec 28, 2008
    Same problem here. Will chech refresh rates. Problem just started a week or so back. Screen eventually (2-5 minutes) comes up.
  • niteshmohite Feb 19, 2009
    Hi Its a brand new lg flatron 21 inch an new pc with good config
    Evrything is fine but the monitor just blinks and gets normal say after a interval of evry 4 secs.this happens.I am just not able to figure out
    new vitsa installed clean ,all drivers installed ,evrything possible freq checked .still the same.
    it just blinks for say 0.5 sec and comes back.Note monitor is not in sleep mode,no power save mode on.nothing.
    checked all device cabling perfect.
    please help me crack this one
    niteshmohite@gmail.com
  • 558 Answers
Did some thing change your refresh rates in the display section of your settings for the monitors? also have you tried to hook up another computer to see if it will display on the monitor? if nothing displays on the monitor then the monitor is faulty. if another computer (even a laptop) can display on the monitor then the video is set to high for the monitor to understand it. to reset monitor refresh with out a screen that will work you need to get into safe mode and reset the display settings to 60 hz and only 800 x 600 for starters and increase them until you cannot get a signal. if you cannot do this then a service shop will be able to assist you
Posted on May 28, 2008
  • Scott Hill
    Scott Hill Mar 21, 2009
    thanks for the low rating, it is the transistors in the monitor that are bad they can be replaced.
My Dell Latitude D630 has a blank screen.
Check your hardware light on the exterior of your computer and see if it is lit and blinking. If it is, you have an operating system, but just can't see it. That tells me it may be several things:
1. The LCD cutoff switch is in the off position
2. Toggle (Fn) the display to the internal settings of the LCD panel. It may be set to display an external monitor only
3. Plug in an external monitor. If it doesn't display on the external, after pressing the Fn key you have a failed video adapter. If it does display on the external it is most likely a back light or inverter failure.
Apr 05, 2012 | Dell Latitude D630 Notebook
My monitor screen is black and the yellow standby light is blinking. I can not get the light to stop blinking or get the monitor to show anything, but a black screen. What can I do to coerrect the problem?
mcdevito75 here, Press the SHIFT key, a screen should come up telling you too click on your user name, left lower side of screen. If this doesn"t work, press the yellow blinking light on the monitor see if picture comes back, then follow the directions. If this doesn"t work, shut computer down with switch on the computer itself. Hope this helps.
Jul 17, 2010 | Acer Computers & Internet
No display on monitor when powered,Light is on.
change caps 1000mf-10v to 1000mf-25v in power supply and 470mf-10v to 470mf-25 or 16v.
May 12, 2010 | ViewSonic E50C 15" CRT Monitor
I CANT GET MY MONITOR TO TURN ON
It could be the Monitor, the VGA adapter, or the PC itself. If you power on the monitor without anything connected to it, do you ever see anything on the display?
If not, it is probably the Monitor. If yes, it is likely the vga adapter and/or PC.
Mar 18, 2009 | SVA-USA VR 17S 17" Flat Panel LCD Monitor
Monitor : no display and blue led light is blinking
The power supply is the first thing that the 110v electric line goes into. The invertor is the next item past the power supply, or sometimes contained within it. I do not thing monitors are a DIY repair.      First substitute a different monitor to confirm that it is, in deed , the monitor and not the video card.
Jan 14, 2009 | Advueu Technology ADV178T 17" Flat Panel...
When it's turned on, the light on my monitor blinks but the screen doesn't display anything. Why might this be happening, and how can I fix it? my new lcd monitor blinks on for 1 second then off but my...
Refresh rate may be set too high for LCD
hook up crt monitor
1. Open control panel-display
Click on settings tab and set to a lower screen res such as 800x600
Try lcd
2. Open control panel-display
click advanced button
click on monitor tab
set screen refresh rate to 60 hz
Try lcd
May 20, 2008 | Computers & Internet
When it's turned on, the light on my monitor blinks but the screen doesn't display anything. Why might this be happening, and how can I fix it? Monitor will go on for a split second, then screen will go...
they normally turn off like this when they aren't receiving a video signal from the pc (same as when you turn off the pc). make sure that it is connected properly, and that the video output is activated. try disconnecting from the other monitor while its on and connect the problem monitor...if it still isn't working then there may be a problem with the cable or the monitor itself. Try another VGA or DVI cable. Hope this helps
Mar 29, 2008 | Computers & Internet
ViewSonic VP930b 19" LCD Monitor Logo
502 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
