Question about Dishwashers
Unit wont drain. nothing appears to be blocked
    Brigadier General:
  • 3,513 Answers
Please check the link bellow to have a detailed idea to diagnose your problem:
http://www.repairclinic.com/Dishwasher-Troubleshooting#Thewaterdoesntdrainfromthemachine
Please accept the solution if it's helpful. Do get back to us for any further query.
Thanks for contacting fixya.com
Posted on Oct 04, 2010
Lcd schaub lorenz
E21 Code
Difficulties in draining
Drain hose kinked/blocked/incorrectly positioned; drain filter
blocked/dirty; drain pump faulty; wiring faulty; PCB faulty; current
leakage from heating element to ground.
Cycle paused. Start
May 06, 2014 | Whirlpool Washing Machines
ERROR CODE E24
E24 is linked to a drain error. You need to get the water out of the bottom and remove the filter by unscrewing it and it will raise up. Get all the water out of the bottom and you will see 3 grooves in the bottom sump area. Make sure nothing is blocking these. On the left side in the bottom you will see a cover and 1 screw.Remove this screw and lift the cover up and make sure nothing is blocking the pump and see if you can turn it by hand . If all of this looks ok the next thing to check is where the unit drains out under the sink. Take the drain line loose and see if anything is clogged where it drains into to the plumbing. Hope this helps and please remember to click accept
Mar 12, 2014 | Thermador DWHD64 Dishwasher
I have a kenmore front load washer and it will not operate in any mode, all lights come on, but nothing happens and it has about 3
pump is blocked, when it first comes on it pumps out. If pump is blocked it wont do anything but hum. Clean out the trap and your good to go
Oct 16, 2012 | Kenmore Washing Machines
Kude70fxss
Do you still have water down the bottom of the unit? Usually when you are hearing that pump noise that is from the drain pump and the reason it is constantly running is usually because there is an obstruction either blocking the hose or blocking the pump from evacuating all the water from the unit. This is a fairly common issue on all dishwashers. Remove the spinner on the inside of your unit and assure that there is nothing blocking the port exit hole. If there is not then you will have to de-install the dishwasher and pull the unit out and remove the drain hose to assure nothing is stuck inside the hose and at its connection point usually to the disposal under your sink. Remember to turn off the water as well as the power before you de-install. If you have any further questions message me back. I await your reply
Thank you,
Rick
Jan 10, 2012 | KitchenAid KUDE70FXSS Builtin Dishwasher
Referring to previous problem. I have defrosted the drip pan, but the water is still pooling up in it. I notice there is a drain hole in the back of the pan, but the water is not draining out of it. I...
It goes through the defrost tube to underneath unit. Poor very hot water in that hole and watch underneath unit where it comes out. If nothing is coming out, then it is still blocked.
Sep 26, 2017 | GE GSS25JF Side by Side Refrigerator
Washing machine wont drain
Hello,Do you hear the pump running when it is supposed to? If no and the machine is still under warranty, take advantage. If you do hear the pump running, but nothing comes out--lower the drain hose down near the floor to see if it will gravity drain into a bucket or pan. If it drains, then the pump isn't moving anything even though it is turning--it must be replaced. If it doesn't drain freely, then something is blocking the drain--a pinched hose either to or from the pump, or maybe a stray sock blocking the outlet from the outer tub.
Thanks
May 19, 2010 | Tecnik TKL9260 Front Load Washer
Whirlpool #907026 filled with water and wont
It is most likely that there maybe something blocking the drain. Check the pump and make sure there is nothing inside it preventing the water from draining properly
Mar 21, 2010 | Whirlpool Washing Machines
Wont drain, no pump
Hi it sounds like a blocked pump needs cleaning out
Feb 17, 2010 | Dishwashers
My Mitsubishi air conditioner has started to leak heaps of water from the side of the unit. It would appear to be something like a blocked drainage system, but I do not know how to open the unit to clean...
find the drain hole in the rear of the unit and take a piece of wire and rat the drain hole out, its got mold growing inside and plugging the drain
Oct 25, 2009 | Heating & Cooling
Code F02 in middle of cycle, wont finnish cycle,
unit is taking to long to drain brad,,check your drain hose not blocked of kinked,,,clean your pump filter,,check your pump,,onthejob
Jan 09, 2009 | Kenmore Elite 45986 Front Load Washer
Dishwashers Logo
Top Dishwashers Experts
