Question about World Marketing of America Heater-5 Plaque Infrared-Lp
Pilot light lights only with match. Pizo ignitor flashes but will not ignight pilot. Pilot goes out 5 to 10 minutes after ignighted.....with or wihout bricks lit up. Pilot Assy. replaced beginning of last season for similar problems.
  • World Market... Master
  • 8,220 Answers
Dust has built up in the ODS pilot safety. Blow out the pilot or flush it with Rust Buster. Let it dry and retry.
How it works/What to clean HERE
Posted on Oct 05, 2010
I have a Lennox furnace Model G19 and the pilot will not light.e You get the normal clicking sound and the ignitor lights but it seems to be a very small flame and the pilot does not light. The ignit
probably need a new control board. so it sparks but gas not coming on? usually you will hear a click then hear gas coming out. if you have a voltage meter check voltave going to gas valve while ignighter is clicking if you have voltage bad gas valve. you should read about 24 volts at gas valve.
Mar 09, 2014 | Heating & Cooling
The dryer does not heat up when we turn it on, was wondering if their is a pilot light to ignight?
That must be a gas dryer. Check if you are getting 120 V to the burner assembly. If you do check the ignitor. It is grey and sits next to where the gas comes out. It needs to get red hot to ignite the gas
May 20, 2011 | Kenmore Dryers
How to light the pilot light on a natural gas wall heater
SEt to pilot, Push knob, push pezio ignighter until pilot lights, hold for 30 seconds. if it stays lit turn to on, if it doesn't stay lit, you have a bad thermocouple
Mar 24, 2011 | Vulcan Heating & Cooling
The pilot light ignights but as soon as I let the knob out to light the heater the pilot goes out. I also noticed that when I depress the pilot knob I can not hear the gas coming out like I use too. I have...
i suggest you change thermocouple on heater it is the pilot control, firstly i would find where it attach's to valve and make sure it is screwed into valve properly (do not over tighten). If the pilot still doesn't go change the thermopile and if that don't work change the valve, but it most likely the thermocouple
Nov 22, 2010 | Coleman (5040B750) Patio Heater
Burner will not light. With the pilot light burning and the gas is turned-on to ignight the main burner the pilot light goes out.
call aservice tech your pilot light might be blocked therefore the pilot flame might not be strong enough to handle the puff of gas when the gas valve opens ps. if the unit is off in the summer spiders are usually the problem. Hope this helps
Aug 19, 2010 | Endless Summer Heating & Cooling
Old maytag gas dryer. Does not heat anymore, gas
Maytag dryer series 05. How do I light the pilot?
Apr 04, 2010 | Maytag Dryers
HEATER WILL LIGHT WHILE HOLDING IGNIGHTER BUTTON IN. GOES OUT WHEN LET OFF. IS IT THERMAL SWITCH?
Are you referring to the Pilot setting on the gas valve knob? if so, you probably have a bad thermocouple or it is not in the flame enough to sense flame. Inspect the pilot to make sure the thermocouple is in the flame. If so, change it.
Nov 02, 2009 | Heating & Cooling
Pilot will light but heater will not ignight
You may need to replace the Ignition Module. Have someone check to see if it is sending power. I have the same problem and need to replace the Fenwal automatic ignition system. The part cost $390 - check inside the heater for the model #
Jul 16, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
Electric ignighter does not come on in the oven at all
In most cases it is the ignitor itself. Eledtricity goes thru the ignitor and as it gets hot it allows more electricity thru to the gas coils, allowing them to open and let the gas go thru. The ignitors do get weak and will glow but that is all. Not enough electricity can get to the gas valve solenoids and let gas thru. Find a local parts dealer and give them your make and model # to order the part.
Jan 28, 2009 | Magic Chef 9122 Gas Single Oven
Dryer Ignitor turns on then back off with no flames afterwards
the government mandated that gas appliances start using electronic ignighters because pilot lights would keep blowing gas even after they blew out now the way they work is calibrated on how much amps the glow bar draws the rest of the amps go to the safety valve to open it when the glow bar is drawing enough amps to be hot enough to ignite the gas now what this means is even though the glow bar glows it can still not be hot enough to ig night the gas so the safety valves don't get the right amps to the solenoids to open so you could have a weak ignighter or bad solenoids on the safety valves now i would lean toward the solenoids but i would buy both and first replace the solenoids then the ignighter if the solenoids work take the ignighter back
May 22, 2008 | Kenmore 74602 Gas Dryer
World Marketing of America Heater-5 Plaque Infrared-Lp Logo
313 people viewed this question
Top World Marketing of America Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
Are you a World Marketing of America Heating and Cooling Expert? Answer questions, earn points and help others
